Team-BHP > Motorbikes
Old 1st July 2016, 22:14   #5626
schakravarthy's Avatar
Thanked: 4,489 Times
Originally Posted by Vignesh_N/A View Post
The grab rails are not of much use either. Even a firm grip on grabrails wont make things better.
With precisely this in mind, plus the added advantage of a luggage rack, my friend bought this:
It cost him Rs.3000/- including shipping. He says the quality, fit and finish is very good.
Link: http://faasterwheels.com/product/raw...-carrier-rack/
schakravarthy is offline   (4) Thanks
Old 2nd July 2016, 12:54   #5627
noo.b's Avatar
Thanked: 167 Times
Re: The KTM Duke 390 Ownership Experience Thread
[/list]IMO Duke is not exactly suited for doing long trips with a pillion. Given the acceleration, the pillion has to sit closer to the rider at all times. Else they will be in constant fear of toppling over, every time you start from standstill. The grab rails are not of much use either. Even a firm grip on grabrails wont make things better.
Vignesh I do feel the same way bout touring on the Duke but a little modulation of the throttle would ensure that the pillion doesn't fear falling off everytime. One doesn't really have to whack the throttle open all the time and the grab rails were ok too.
Attachment 1523030
While this looks great and I might consider this to mount a top box on longer journeys, but I think the rod connecting the base plate to the rear cowl may bother the pillion
noo.b is offline
Old 2nd July 2016, 16:36   #5628
Vignesh_N/A's Avatar
Thanked: 328 Times
That looks pretty neat. Would be high on practicality for touring purposes.
Ah yes, throttle modulation would make things simpler. But the bike in question happens to be a DUKE. Those were the practical issues faced by me when riding with a fully built pillion. Fully built as in 6+ feet and 120kgs :P. While the cruising part wasn't much of worry, riding withing city limits, particularly in traffic was tedious. I had to consciously increase the throttle and by the time I gain momentum, I would be at the back of the bunch. It is sort of frustrating at times.
Vignesh_N/A is offline
Old 3rd July 2016, 07:35   #5629
sps
sps's Avatar
Thanked: 30 Times
exactly my concern.can anyone clarify on this?
It will be greatly helpful if one can post a picture of pillion sitting on the bike fitted with this rack
I knew duke was not going to be pillion friendly, still i bought the bike since it is too good at every other department.
sps is offline
Old 3rd July 2016, 12:17   #5630
... but I think the rod connecting the base plate to the rear cowl may bother the pillion
Originally Posted by sps View Post
.. exactly my concern.can anyone clarify on this?
I checked with my friend and he says it's not a problem.
He's currently off-roading in Wayanad, so additional details can be had only after he returns.
Old 3rd July 2016, 18:08   #5631
Thar4x4's Avatar
Thanked: 772 Times
This carrier is designed by a Pune based KTM guy, I purchased the same for my last trip and it is 100% VFM. There is no issue for pillion at all as there main intention of designing this is pillion friendly for touring. The weight carrying capacity is 25 KG but if you balance the bags from rear seat till carrier end when there is no pillion then it can take lot more weight.
There is saddle bags supporter as well which fits on the pics coming out from crab rail mount and rest on rear foot peg however I didn't bought it.
Some snaps on my bike:
Thar4x4 is offline   (5) Thanks
Old 7th July 2016, 12:32   #5632
Well, I hope these pics will clear any lingering doubt.
schakravarthy is offline   (5) Thanks
Old 9th July 2016, 16:31   #5633
What does this mean? Any idea?
Old 9th July 2016, 23:05   #5634
Thanked: 328 Times
Could be an experimental powder that might have been used in powder coating of metal products. In the above case, orange colored plate. Is that what you meant to ask ?
Vignesh_N/A is offline   (1) Thanks
Old 10th July 2016, 20:29   #5635
Thanked: 328 Times
Is that marked on your bike? where was it? Did you change the part lately?
Old 10th July 2016, 21:56   #5636
My friend's new bike.
The part just behind the radiator and is a factory oe and hasn't been replaced.
Even if it's a production line corrective measure, that still doesn't warrant why the notes have been retained till delivery.
Old 10th July 2016, 22:42   #5637
Thanked: 328 Times
It amuses me. If it is meant to be for trial, then why is it on the production motorcycle ?
Since the powder used is fairly meant for testing, it would definitely take more than 1 month to verify its effectiveness. something is not adding up.
Old 12th July 2016, 18:38   #5638
Siddy's Avatar
Thanked: 106 Times
Hi Dukers,
Riding has taken a hit since monsoon started.
Primary reason? The duke gets really really dirty after a wet ride! The amount of dirt thrown below the radiator area is scary & cleaning the bike is not easy. It has so many inaccessible corners around the engine/radiator area!
Pressure washed the bike and the tyre pressure indicating sticker is gone .. There is a small area under the starter motor where water accumulates after washing & is difficult to remove!..Been checking the radiator and I can see a few disfigured fins due to flying debris. The OE radiator protection still works well. I think flying debris is inevitable. Cleaning the bike in rains is such a pain, the chain goes dry after a wet ride. There was dirt stuck in between the rear foot pegs and made noise when I tried to close them, cleaned with running water and sprayed WD40.
Any advice/tips regarding monsoon maintenance?
TIA!
Siddy is offline
Old 12th July 2016, 19:20   #5639
Thanked: 422 Times
TIA!
Except for chain maintenance at a more frequent interval, everything else's similar to talking care of other bikes during rains. Water may tend to make its way into the tank in very heavy rains, so it may be a good idea to put one of those ugly tank cover plastic thingies. You mentioned WD 40 application, so I hope you are using it for the switch gear as well. Otherwise everything's sorted with the 390 for monsoon fun. That includes riding in deep water with the exhaust submerged fully
anilp is offline   (1) Thanks
Old 12th July 2016, 21:25   #5640
Darth Sid's Avatar
Thanked: 119 Times
Attachment 1523033
Attachment 1523032
Attachment 1523031
Attachment 1523030
I had bought mine 3+ weeks back and had to send the mounting brackets and the upper support pipes (no, they are not solid rods) back to get them replaced. The holes in the mounting plates did not match the holes in the chassis in my 2012 Duke 200 so I had to get them drilled wider. Similar defect in the left side upper arm. Alignment of that arm was also an issue. They received the defective parts 2 weeks back and I haven't yet received the replacement parts. Might get them by this weekend. Maybe.
Otherwise, the quality is good. Sure, there are some stray spatter of filler metal around some weld joints but that is minor. Once I get the parts I can comment further on quality. However, it seems good enough.
Darth Sid is offline   (1) Thanks
