23rd October 2014, 00:12 | #3046 | |
BHPian Join Date: Jan 2014 Location: Kolkata
Thanked: 424 Times
| Re: The KTM Duke 390 Ownership Experience Thread Quote:
I also plan to visit the SVC and let it be their head ache , for one if it is not a tire but rim/wall seal issue , they might lay blame on the 3rd party involvement . The dealership staff is not very confidence inspiring and can very well say that, the knowledge that I will be out of bareilly within 6 months was decisive . Last edited by basuroy : 23rd October 2014 at 00:13. | |
() Thanks |
23rd October 2014, 00:22 | #3047 |
Senior - BHPian Join Date: Jul 2009 Location: Calcutta
Thanked: 6,227 Times
| Re: The KTM Duke 390 Ownership Experience Thread |
() Thanks |
23rd October 2014, 03:22 | #3048 |
Senior - BHPian Join Date: Aug 2011 Location: Phoenix, Ariz.
Thanked: 2,839 Times
| Re: The KTM Duke 390 Ownership Experience Thread Those of you who are concerned about your Duke's cooling fan will be interested in this. Like most all liquid cooled engines, the engine has a thermostat which control's the coolant temperature by opening to release water thru the radiator (heat exchanger for the technically inclined) or closing to force the coolant to circulate only around the cylinder and thru the cylinder head. If the thermostat is operating correctly it will begin to open when the engines coolant reaches 88 degrees C (190.4 F). The thermostat should be fully open when the engine coolant temperature reaches 96 degrees C (204.8 F). At this same 96 degrees C.(204.8 F), the fan turns on. When the fan and/or riding the motorcycle has cooled the engine to 90 degrees C (194 F) the fan should turn off. Notice that the engine temperature must drop 6 degrees C (42.8 F) below the "turn on" temperature before the fan will turn off. While the engine is running, the metal parts are hotter than the coolant so although one can come to a stop and let the engine idle it takes some time for this extra residual heat to transfer to the coolant where it can be removed by the radiator. That's a good part of the reason the temperature guage doesn't show a drop in temperature immediately. When one shuts off the engine after a brisk ride this same residual heat will be transferred to the coolant but in this case, without the water pump circulating the coolant thru the radiator the cooling off time will take much longer even if the fan is still running. With the engine off, the circulation thru the thermostat and radiator with the engine off will be dependent on the archaic thermo-syphon principal that depends on the density of hot and cold coolant temperatures. (This method went out of favor for vehicles about 100 years ago.) The very slow thermo-syphon process can take a long time to move the coolant thru the radiator to remove the heat. http://what-when-how.com/automobile/...em-automobile/ I found an interesting Adobe file link about the Duke 390 engine/lube/coolant that you all may be interested in: https://www.dropbox.com/s/d4ld3kqno9...SSM_902_EN.pdf |
(7) Thanks |
The following 7 BHPians Thank ArizonaJim for this useful post: | abhinav.s, JayD, samschenker, shan_ned, theexperthand, unni.ak, VijayAnand1 |
23rd October 2014, 03:35 | #3049 | |||||||
BHPian Join Date: Oct 2013 Location: Hyderabad
Thanked: 166 Times
The job of the radiator and the fan is to simply prevent "overheating". it is not to cool the engine to ambient temperature. Infact, on the 390, for the best performance, the engine temp is supposed to be 2 bars shy of the top segment. (4 bars shy of full). This is the 'normal' temperature. Having said that, it is true that the cooling system was not a fully thought out process by KTM which was evident in the afterthought changes they made. However, you should not really worry so much because shutting the engine off is really dependent on the scenario. Let me explain: When you come to a stop, almost always the fan will kick in, this normally happens when the bar in the middle segment reaches the second last bar(4th bar from top in total). This is to obviously stop the engine from heating up further and it works. No matter how long you run the fan, the max it will do is go one bar down. The function doesn't cool, it prevents overheating. So, you have to make a choice weather to turn off or not depending on the situation. If you are going to be parked for more than 20mins or less than 2mins, the go ahead and turn the engine off right away, no harm done. This is because 2mins is too less for the engine to soak in the heat to overheat and on riding again will bring it to normal. More than 20mins is enough for the engine to soak heat and cool back to normal operating temperature through ambient heat exchange. However, if you have already hit the top segment (last 2 bars) and the fan is already running, only turn off if you are stopping for more than 20mins. Even if the stop is less than a minute in this case, it will overheat, so keep the engine running till it comes back to the middle segment. The reverse fan operation was a non conclusive fix by KTM because this fixed the issue of heat onto the riders legs but it brought into the picture another concerning issue,i.e when stopped, the reverse flow of the air is only pulling in the hot air over the engine and putting it to the radiator. This is why the temperature never really goes down when the fan is running when you are stopped, the air thrown into the radiator it is just a few degrees cooler than the temp in the radiator because of where it is pulling in the air from. All in all, the current system does "satisfactorily" do it's job except in certain conditions like stop and go traffic. This is not just KTM specific scenario, even my tiny 135LS used to heat up like crazy and quite literally burn my skin in stop and go traffic thanks to it's high compression ratio. So, unless your everyday commute includes more than 15mins of stop go traffic, you should be golden. My thoughts are that adding a second similar fan would help the bike by leaps and bounds but then there is problem of electrical load. Remember, it runs of a puny battery. Another high amp fan would literally kill the battery in no time or add extra engine load for power generation. So, it is compromise of sorts. Quote:
Secondly, the jerking is not due to heat or fuel. It is due to the gear ratio. Understand that the 390 produces so much torque that the larger gears are invariably going to be jerky at lower speeds because they are meant to pull as quickly as they can, smaller gear notches will be less jerkier but the pull is going to take forever when you give gas. It will take practice and learning to know how to ride smoothest way possible on the 390 with gas and clutch usage simultaneously. It's a balance you will eventually find. Quote:
(2) Thanks |
The following 2 BHPians Thank Cyrus_the_virus for this useful post: | gharika, shan_ned |
24th October 2014, 07:14 | #3050 | |
Senior - BHPian Join Date: Feb 2010 Location: Wellington
Thanked: 5,701 Times
All said and done, I don't think the Duke over heats. In the said conditions, just about any motorcycle will run super hot. I am sure most of us have thrashed this motorcycle on the highway and the engine is well within safe limits of temperature. | |
() Thanks |
24th October 2014, 10:26 | #3051 |
BHPian Join Date: Jun 2010 Location: Cochin
Thanked: 127 Times
| Re: The KTM Duke 390 Ownership Experience Thread I just read that Bajaj has launched Kawasaki Z250 for 2.99 Lakhs. I just don't understand, why would people prefer a bike with a puny output of 32 bhp and a kerbweight of 167 kg for Duke 390??? other than for 17 litres tank it offers |
() Thanks |
24th October 2014, 12:25 | #3052 | ||||||||
Senior - BHPian Join Date: Feb 2010 Location: Pune
Thanked: 11,118 Times
Infractions: 0/1 (9) | Re: The KTM Duke 390 Ownership Experience Thread Quote:
But it reaches a steady state, on the brink of the warning zone. It arrests further escalation. It fails to bring the bike back from the brink. It leaves the bike too close for comfort to the danger zone. It removes any leeway or flex in case anything goes wrong in this delicate equilibrium (coolant levels low, fan malfunctions, battery low, bimetallic strip of thermostat malfunctions, etc.) Quote:
Such puppies should not be riding bikes. They should move from their cycles directly into their daddy's climate controlled air-conditioned SUVs or cars. | ||||||||
(1) Thanks |
The following BHPian Thanks ebonho for this useful post: | VijayAnand1 |
24th October 2014, 18:06 | #3053 | |
Thanked: 166 Times
The way the cooling works now works at the edge but ok for my riding patterns. But yes, there are those days where I have to go into the old city to get that one thing which you only get inside gullies jam packed with traffic and people, yes those days the cooling can be a bia**h but otherwise, my normal routes are free from stop go traffic and at times i have been able to adjust accordingly, like going low revs when the engine starts to exceed heat limits. But I can't complain, because I know for a fact that the Duke390 is not made as a city traffic commuter, so if I am not giving enough space for the bike to stretch it's legs, I am the one not doing justice to the 390 and cannot blame it for getting hot and angry. It's like blaming an angry bull for running over people in a crowded market. The owner that let it loose should be the one to blame. it just did one thing it does Last edited by Cyrus_the_virus : 24th October 2014 at 18:07. | |
() Thanks |
24th October 2014, 19:15 | #3054 |
Thanked: 424 Times
| Re: The KTM Duke 390 Ownership Experience Thread 250km clocked so far , enjoying the bike A LOT now as getting hang of the control . Sometimes I feel I may be a little too confident on the saddle but hard to control oneself all the time The engine braking is hard but I find it very good for controlling speed , low rpm performance leaves a lot to be desired but then I have so far avoided any prolonged first gear crawl so no issues . The left side heat at this time of the year is at worst a minor botheration but I guess it will be a lot more in summer , the culprit being the exhaust bend pipe . Braking is good , coming from an CI enfield , it is a whole other universe and allows one to ride aggressively (within reason of course) . ONE QUERY - the rear brake is very weak in my opinion , it is hard to quantify but I feel that "front only" can stop the bike in half the distance if not less than "rear only" application takes . I am aware of sports bike brake distribution but is such a gap in braking prowess normal or should I get it checked ? I should mention the rear pad is more or less brand new as I rarely use it , does it gets better with use ? And , how accurate is the on board mileage calculator and the fuel indicator(bike being held upright of course) ? Is it OK to wash the bike with garden hose (no pressurized jet ) or does it demands special care where to and not to spray water ? For example I feel water might seep into the battery compartment while washing the seats, can that potentially harm the bike in any manner ? Do brake pads require any maintenance in the form of washing ? If so can I use car shampoo allowing enough time for the pads to dry under the sun ? On the topic of the ongoing radiator/fan discussion - Maybe the engine oil pump is not powerful enough for the bike ? end of the day this is from outside same engine as a 125cc and 200c bike and maybe the design in some form didn't allow for a pump powerful enough for 375cc hence resulting in less than desirable oil circulation . Last edited by basuroy : 24th October 2014 at 19:23. |
() Thanks |
24th October 2014, 21:09 | #3055 | ||||
Thanked: 166 Times
(1) Thanks |
The following BHPian Thanks Cyrus_the_virus for this useful post: | basuroy |
24th October 2014, 22:20 | #3056 | ||
Thanked: 127 Times
| Quote:
Fill the fuel untill the fuel reaches the brink of the tank opening. Ride for say 100kms in your normal riding style( you have to watch the odometer) . Note the mileage figure in the onboard display. Go to the fuel pump and fill it to the brim. But this time measure the quantity of fuel needed to fill up to the brim. Suppose it is say 4 litres. Then you got a mileage of 25 kmpl. If it's same as that shown in the onboard display, then the display is accurate. I guess you already know the process. The fuel guage in most economic vehicles, are exponential. They tend to show the fuel consumption at a faster rate, initially. It is due to the float design used in the fuel gauge, in most economic vehicles. Quote:
(1) Thanks |
The following BHPian Thanks mithunvvijayan for this useful post: | basuroy |
24th October 2014, 22:30 | #3057 | ||
BHPian Join Date: Oct 2014 Location: Bangalore
Thanked: 751 Times
In another forum, there was a guy who simply replaced his stock fan with an aftermarket fan and he found the solution to be more effective in controlling the engine heat, but I am not sure if that is well accepted. Quote:
() Thanks |
24th October 2014, 23:51 | #3058 | |
Senior - BHPian Join Date: Dec 2010 Location: electricity
Thanked: 3,497 Times
Dr...i wish some of them took a long ride on those old 500s for i actually felt a slightly higher temperature with 390 but was anyway used to the warmth of the engine Those early morning rides at 4Am and the warmth these engines provide is such a boon for me or for some. If its too hot, a great time to take those tea or coconut water breaks | |
() Thanks |
26th October 2014, 11:03 | #3059 | |
My largely unsolicited advise to Bajaj on this one. Observe. Learn. Internalize. Ride piggyback and take giant steps. Short circuit the long arduous very expensive learning curve. But for God's sake, do not overreach ..... | |
(3) Thanks |
The following 3 BHPians Thank ebonho for this useful post: | howler, VijayAnand1, VW2010 |
27th October 2014, 13:54 | #3060 |
BHPian Join Date: Oct 2009 Location: Chandigarh
Thanked: 143 Times
| Re: The KTM Duke 390 Ownership Experience Thread Thanks to the friendly and informative people on this forum, I went ahead with the purchase of the Duke 390 and got it under me today . This is my fourth bike but this time it was after a gap of 10 years. My last one was a CBZ (1999 make). This is the second time that the forum has helped me in making my buying decision and I have the confidence in the people here to get me out of any machine trouble. So much so that the first time I rode the Duke was after I purchased it. The recent discussion on the cooling system of the Duke was fresh on my mind during the ride out of the showroom and I experienced it first hand. I am still in doubt what to do on the traffic stops, the only time I have to stop actually and the speeds come down below 40. The stops range between 30 seconds to 110 seconds. So should I switch it off? Let it idle? Cyrus_the_virus provided good tips, I will follow them in the meantime. |
() Thanks |
