Team-BHP > Motorbikes
Old 17th April 2006, 19:12   #1
primary reduction and secondary reduction
hello folks,
what is primary as well as secondary reduction, plz... provide detail stuff , and what it's importance.
devsus is offline
Old 17th April 2006, 19:21   #2
revharder's Avatar
Thanked: 57 Times
Originally Posted by devsus
hello folks,
who knows reduction better than you?
you reduced your post to such a short thing even the rear overhangs of Smart looks much more bigger than that!
and you are asking us to provide you with detailed stuff!
well, is it about the reduction of gear ratios or else?
revharder is offline
Old 17th April 2006, 19:29   #3
u are joking bro, no matter............i will repeat PLZ... provide detailed knowledge of primary and secondary reduction
devsus is offline
Old 18th April 2006, 20:42   #4
veyron1's Avatar
Thanked: 54 Times
well, can't give the exact details because even i've forgotten, but here goes the gist- forgot whether they are right, though;
primary ratio/reduction- the ratio between the clutch shaft/input shaft idle gear and the idle gear on the layshaft.
secondary ratio/reduction- the ratio between the drive gears of the layshaft and the output shaft (1st gear, 2nd gear, etc.)
final drive ratio/reduction- the ratio between the output shaft revolutions and the differential revs. (in case of cars; in case of bikes, the ratio between the front sprocket and the rear sprocket).
the differential has reductions too....
veyron1 is offline
Old 19th April 2006, 17:35   #5
so, less timing means better performance ......
devsus is offline
