Team-BHP > Motorbikes
Old 19th June 2013, 14:51   #241
n_aditya's Avatar
Thanked: 3,806 Times
Re: Motorcycle Tyres : Compared!
Originally Posted by Abeer View Post
Can somebody recommend a good 2.75/18 front tyre for my 4S Champion?
I used the Michelin M35 on my Fiero's front wheel and highly recommend it. Grip levels are brilliant and life of the tire is good too.
Better option is the M45 but not as long lasting as the M35, as per what i have been told.
n_aditya is offline   (1) Thanks
Old 19th June 2013, 18:58   #242
Gill's Avatar
Thanked: 16 Times
Where can one find M45? I have been looking for it for a while.
Gill is offline
Old 20th June 2013, 08:33   #243
kolimuttai's Avatar
None of the Michelin shops in bangalore have them. I finally settled for mrf zapper fs 42p rating.
Though you could find a year old stock at jc road but at a higher premium.
kolimuttai is offline
Old 20th June 2013, 08:46   #244
petroguzzler's Avatar
Thanked: 264 Times
Any reviews on the Ceat Milaze??? My dad had fitted it on the rear wheel of my 2002 Fiero. The grip doesn't seem too effective.
petroguzzler is offline
Old 20th June 2013, 09:35   #245
sagarpadaki's Avatar
Thanked: 6,789 Times
The name of the tyre itself says that its a mileage oriented and not grip oriented tyre. These are for people who want their tyres to last 30-40 thousand kms!
OTOH, have how many kms have the tyres done ? Do you maintain the tyre pressure recommended by the bike user manual or fill it up @ 36 rear, 28 front that the tyre wallah's fill up for all the bikes/scooters?
sagarpadaki is offline
Old 20th June 2013, 14:25   #246
Thanked: 264 Times
What could be suggested for the fiero??
What is the recommended air pressure for the suzuki fiero??
Old 20th June 2013, 16:16   #247
Abeer's Avatar
Thanked: 24 Times
Is M35 same as Sirac Street?
Abeer is offline
Old 20th June 2013, 18:50   #248
SriramEfunds's Avatar
Thanked: 54 Times
Clarification:-
Bike: ZMA
Tyre size: 18" Mag.
Stock size: Front 2.75, Rear 100/90
Current tyre: Front stock, Rear: Michelin M45 4.00 X18
Sooner or later might run out of this last piece of M45. Though I would not get another M45, however, looking at some options close to this.
I'm hearing Dunlop Geocruiser and MRF Vyde. Of these two I'm hearing Geocruiser is a soft compound and sticks to the road and offers better stability in wet conditions.
MRF Vyde, if not the known on the tyre compound, hearing that it also offers good round profile assisting while cornering. Yet to know if that is good on wet roads.
Both Dunlop and MRF offers the size 100/90 18" profile.
I don't want to go for Michelin Sirac Street which looks more of dry and offroad profile than proper tarmac and wet condition. Please correct me if I'm wrong.
SriramEfunds is offline
Old 20th June 2013, 19:39   #249
sai_ace's Avatar
Thanked: 778 Times
The Geo-cruiser is not recommended at all. Used to be a good tyre, but not anymore. I would suggest the Vyde. also do enquire about the meteor (?) from MRF.
cheers!
sai
sai_ace is offline   (1) Thanks
Old 21st June 2013, 08:46   #250
n_aditya's Avatar
Nope, the M35 is ideally for the front wheels and the Sirac Street is ideally for the rear. The treads are very different on both these tires. The Sirac Street has treads that resemble off road tires - chunky buttons, while the M35 is like a regular tire tread.
Here are a couple for pics for reference:
M35:
Sirac (has almost the same tread design as the Sirac Street):
Motorcycle Tyres : Compared!-sirac.jpg
The Sirac Street is a wonderful tire - soft on the sides and hard in the center. Cornering hard on dry tarmac is a breeze and lot of fun.
Old 21st June 2013, 15:42   #251
Abeer's Avatar
Thanked: 24 Times
I spoke with the dealer here and he mentioned that M35 and Sirac Street are the same.
Abeer is offline
Old 21st June 2013, 18:35   #252
Gill's Avatar
Thanked: 16 Times
Can some one confirm the availability of M35 front sizes! I need 90/90/18 or 3.00*18.
Gill is offline
Old 24th June 2013, 01:19   #253
amit_purohit20's Avatar
Thanked: 1,000 Times
I would only suggest brand either go for CEAT or MRF. Both provide sufficient grip and are good for most purposes. Particular tyre model you can choose from reviews available or be the first one to review it here.
Just check out CEAT Zoom tyres. I got the feedback that they are good too.
Last edited by amit_purohit20 : 24th June 2013 at 01:20. Reason: Additional point to be added.
amit_purohit20 is offline
Old 1st July 2013, 22:32   #254
Thanked: 24 Times
Folks, Need help. Its time to change the tyres of Pulsar 150. This was my cousin's bike and has run about 43K kms & I have started to use this bike only from last year or so (1k kms or so). Current options are Michelin Sporty or Sirac. Mech says go for Sirac for better grip and he is also intent on changing the rims! which would cost me another 3K approx. His reasoning: rear breaks are getting jammed, the break shoes/pads are not fitting in. Is it really needed to change the rims also ?
pranxter is offline
Old 7th July 2013, 14:27   #255
Originally Posted by amit_purohit20 View Post
^^The author is more interested in proving that one should not ride a car tyre in a goldwing motorcycle, which is not important to us. (Kyonki Goldwing sapne mein bhi nahin aati because of its price )
So here are the salient points important to us:
1) First I apologize for putting down few points without doing a proper indepth research (balme it to the lack of time and laziness). I had directly/indirectly stated that for deformable bodies like rubber the friction is also dependent on area due to the simple logic that more the area more the asperities (refer my earlier post for its meaning http://www.team-bhp.com/forum/motorb...ml#post2853071 ). Its true and I am not wrong completely but the contribution due to this factor is marginal and for all practical purposes it can be neglected.
2) So now what dominates the rubber and tarmac contact? Well the ideal friction laws still hold good here. Frictional force= Coefficient of friction x Weight of body.
3) To make things more complex Coefficient of Friciton of Rubber and tarmac changes with respect to pressure. ( I would not like to go into the details now.)
4) If you increase the area of contact by a wider tyre, you also landup reducing the pressure on the contact patch as Pressure= Force/ Area. So the benefits of a wider contact patch is lost because of reduced pressure on the contact patch. This is proved by the research that snow tyres are made less wide to increase the pressure at the contact patch and thus compacting the ice for a better grip.
5) Rubber tyre friction depends on Normal laws of friction, adhesion and rolling resistance. The stickiness of the rubber compound to the tarmac will determine the adhesion.
6) For wet grip its not that only a soft compound will give more friction. Silica (sort of refined sand) is added to the tyre compounds to enhance its wet grip but it reduces other desired properties (dry grip and rolling resistance) of a tyre and hence its a well balanced trade-off. Refinement of silica also plays a major role in enhanced wet grip and so using just any silica sand doesnot help. Cost involved in refinement of silica raises the cost of tyre.
7) The more the depth of the tread grooves (not necessarily the width of the tread groove) is better for pumping water out of the contact patch and thus increasing wet grip.
8 ) Wide tyres have more probability of acquaplanning at least in cars.
So to sum it up its not necessary that a wider tyre will provide more grip than a thinner tyre.
Then why do we have wide tyres and what are the benefits of wide tyres:
1) To increase structural strength of tyres for higher pay load its required to increase the width and other dimensions.
2) One more aspect of having wide tyres is that the manufacturer can add more rubber to it with a softer compound and this extra rubber increases the wear life of the tyre. Otherwise thin soft compound tyres will have worn out easily leaving very less useful tyre life.
3) Wider tyres with higher ply ratings can take up more higher loads.
4) Wider tyres ensure that even in the worst conditions we have some rubber left on the ground.For eg. a tyre going have the way over the curb end. A motorcycle tyre in a high inclination lean.
So practically whats left for a common man after understanding all this tyre gyan:
1) Simply nothing.
2) A buyer can not by anyway understand whats the compound of the tyre and whether its good for wet or dry grip. We can get a vague feeling of the softness/hardness of rubber compound by piercing our nail on the tyre tread and looking for the depth and time required for the tyre to fill it up. But though the rubber may be soft it still may not be the best compound for a wet grip.
3) So we have to bank upon the tyre manufacturers and the actual tyre users ( although they too are vague in their predicaments).
Sorry to say but whatever the tyre study I have done till now has hardly helped me enough to choose a on-road tyre for my requirements. So again the saying " To experience heaven you should die first"
PS: I have recently bought a new tyre for the rear wheel of my Apache RTR180.You can soon expect a review for the same.
Disclaimer: All the above points mentioned above is the amalgamation of my research on internet and my engineering common sense which can be wrong.
Last edited by amit_purohit20 : 7th July 2013 at 14:37. Reason: Additional points added
