Re: Honda CBR 250R : Answers to some commonly asked questions No offense, but easy to track when answering point by point... Quote:
Originally Posted by nosfreak Which Radiator coolant do you use? Is Honda's coolant one better or a different one, i do remember somebody posting a Pic of a Motul coolant. Any suggestions and cost of it? |
I'm using stock coolant for nearly two years, I'd replaced it only once in the last 47K km, but will be replacing for every 15K km going forward for no specific reason, may be paranoid. As you may already know, I've been riding properly during peak bone melting summers to cool (not cold) Winters & monsoons; no troubles so far. I'm not discarding Motul or any other coolant type, but, I would like to spend my money else where. Quote:
Originally Posted by nosfreak 2. How many times have you change your chain and your chain sprocket? |
4, but you can actually count 3; the one that Rolon supplied was absolutely crap Quote:
Originally Posted by nosfreak 3. The stock handle bar ends, do they really do their job by absorbing the road vibrations? or a aftermarket would be better? |
Sorry, I don't know about this one. I tend to assume that they do the job Quote:
Originally Posted by nosfreak 4. Have you or any member here anytime used IRC tyre? How many kms Zapper is till on? |
IRC Zapper? I thought Zapper was MRF's product. Pls clarify Quote:
Originally Posted by nosfreak 5. How is the radiator, do you see any wear or tear yet for the kms you have run? |
Wear & tear on radiator? Pls educate me, I don't know how a radiator is prone to wear & tear. Quote:
Originally Posted by nosfreak 6. The stock airfilter, how long did the first one last you or are you still running on the same? |
47K on ODO, owner's manual says replace every 12K km, do you think I should be using the first one till now ![Smile](https://www.team-bhp.com/forum/images/smilies/smile.png) ? Quote:
Originally Posted by nosfreak 7. Now that i got my hands on Petronas 10w40 fully synthetic... would one notice that its time to change. |
Don't think so; I've personally used HMSI's 10W30 for 5890 Km & the engine oil was still looking good. After searching for so many engine oils, I finally found Shell 10W40 Advanced Ultra is simply worth every paisa I pay for. It's superior to Motul 7100 10W40 & Motul 300V Factoryline 10W40.
Per owner's manual I guess it's 12K km for engine oil filter change
If you can be specific about Petronas 10W40 fully synthetic? It will help me to compare Shell & Petronas & if found superior, I can switch to Petronas. Tks
Nosfreak saar - to answer all your questions in one sentence...just stick with service interval of owner's manual & DO NOT take anything lightly (including fuel filter etc). If you're replacing anything earlier than recommended interval, nothing wrong in it, just that it's waste of money. For instance, I replace airfilter every 6K against 12K as Chennai is way too dusty & these days I'm contemplating to change for every 3-4K. The filter gets tard dirty by 6K. Hope you got the point & let me know if you need anything more to be elaborated. Tks
