Team-BHP > Motorbikes
Old 11th February 2013, 15:45   #661
Thanked: 546 Times
Originally Posted by ebonho View Post
Dukers, how many of you have found the bite on the front brake to have gone down?
tting it? Is it normal (or is there a leak somewhere)?
Doc, Ive noticed the bite of the front brake reduce but it can be cause Ive completed 3k kms on them although I see the pads are ok.
Havent noticed a sound yet. Will try listening today.
Also, i notice that my front brake disc gets heated a lot after evry journey whereas the rear stays warm( and I can place my hand on it without getting burnt) although I use rear brakes most of the time. Is this normal? [Ive had my front tyre changed at 900kms, so maybe the pads werent placed back right??]
Parthasarathig is offline
Old 11th February 2013, 15:56   #662
n_aditya's Avatar
Thanked: 3,742 Times
Re: KTM Duke 200 : Baby Duke 222 unites with her new family!
Get the brake pads and the assembly cleaned. You might want to bleed the lines as well to improve the efficiency.
Brake disc's get heated up since the pads are always in contact with the rotors, but if your rear rotor is cooler than the front despite using the rear brakes more, do check if the brake assembly was fitted properly in place.
n_aditya is offline   (1) Thanks
Old 11th February 2013, 16:07   #663
Thanked: 28 Times
Same here, 3700kms on the odo.
More importantly, when you press the front brake, do you get a typical crackling sound - as if fluid is being forced/sucked through a narrow tube.
I don't hear any crackling sound. All I hear is a whistle which is commonly associated with the drum brakes.
gk01 is offline
Old 11th February 2013, 16:10   #664
ebonho's Avatar
Thanked: 11,095 Times
Infractions: 0/1 (9)
Partha, front rotor is always HOT bro.
Aditya, I am also thinking of getting my front and rear lines bled and the fluid replaced. I am missing the crazy bite the brakes had when the bike was new.
Guys any idea about the chirrrrrrrrrrrrr sound on pressing the front brake?
ebonho is offline   (1) Thanks
Old 11th February 2013, 17:15   #665
n_aditya's Avatar
Has to do with dust accumulation. Get the brake pads and the related components cleaned and the sound will disappear.
New pads will have a faint whoosh sound on hard braking and this will disappear once the pads break in.
n_aditya is offline
Old 11th February 2013, 17:27   #666
ebonho's Avatar
Bro these pads are 7000 kms old (been cleaned once on zero grit paper some 1000 kms ago).
This is not the sound of a glazed pad or dust. Its not a squeaking sound.
The pads are fuly broken in.
It is only when you press the brake lever.
The sound is very typical.
ebonho is offline
Old 11th February 2013, 17:49   #667
Sheel's Avatar
Thanked: 14,729 Times
Some dust seems to have accumulated in the are where the brake pad rests. I usually (try to) clean it with a hose. The domestic one with as much pressure as can be exerted. Should help.
Try that from the right area as your brake assembly is to the left, right?
Sheel is offline
Old 11th February 2013, 18:01   #668
voodoochild's Avatar
Thanked: 180 Times
Doc, is the sound from the disc/pads or the lines/reservoir?
I've heard this on a Duke yesterday at the Mariott signal on SB Road. It was a couple of thousand km's old, and the loud, high-pitched gurgling from the fluid reservoir was all too evident. To me it sounded very much like air in the system. A proper bleed and replacement of fluid should sort this out IMHO. I've heard this sound on quite a few disc-braked motorcycles, but it wasn't anywhere as loud as on yesterday's KTM.
Have you had signs of leakages of brake fluid?
Cheers,
Rahul
voodoochild is offline   (1) Thanks
Old 11th February 2013, 18:06   #669
ebonho's Avatar
Cheers,
Rahul
This is not a rotor/pad sound. It is more like a lines/reservoir sound. Read an apt description elsewhere - Sounds like a bicycle chain over the rear free wheel sprocket when you stop pedalling (or pedal backward).
No signs of leak anywhere. A bleed and fluid replacement does seem to be in order (even if not indicated till the 10 or 15K km service).
Thanks Rahul - that was helpful!
ebonho is offline
Old 11th February 2013, 18:28   #670
Thanked: 28 Times
Ah, that's indeed very apt. I find it quiet frustrating sometimes explaining the sounds to the people at the SVC. I simply try to record it on the phone if it doesn't involve a stunt, which is sadly not the case when the brakes are involved
But Doc, isn't this the same sound one would hear when there is air in the lines? Please confirm.
gk01 is offline
Old 12th February 2013, 10:49   #671
ebonho's Avatar
Yes, it sounds a lot like air bubbling through fluid in the lines.
Any ideas on how air can get into the lines if there is no leak? (I cannot see any obvious air bubble through the reservoir inspection window)
ebonho is offline
Old 12th February 2013, 11:36   #672
Thanked: 28 Times
I don't have an explanation either, it is supposed to be air-tight.
In my case though, I do see a bubble in the reservoir.
gk01 is offline   (1) Thanks
Old 12th February 2013, 14:50   #673
ebonho's Avatar
Getting the brakes checked up by the Brembo guys (hopefully tomorrow).
Will keep you guys updated.
Old 12th February 2013, 20:32   #674
Thanked: 546 Times
Thanks n_aditya and doc.
Hey even I have this bubble, but I dont seem to have the noise that Doc is having.
Doc in all probability someone must have messed with the brakes when the bike was parked and air has entered the system. Do let us know what the diagnosis finally is.
BTW, I had a screeching sound coming from the front wheel when I pull the bike backwards out of the parking. Someone on the India KTM page suggested to apply grease to the front axle. My friend did that on his Duke but the sound came back after a while. What can be the solution?
Also, my bike is getting hot these days very easily. Almost at every signal the fan is always on. The coolant level is still 1-2cm from the MIN mark. And the temp indicator is just one bar less in the first box. Although after running for sometime, the temp level drops to midline. Is my bike normal or is something wrong, doc? What levels does your temp usually stay at?
Also, what intervals are you lubing the chain doc?
Thanks.
Old 13th February 2013, 09:59   #675
Thanked: 180 Times
Partha, this will be her first summer
This will be the first summer for a lot of Dukes. The way the weather's already turning stuffy in Pune, it isn't a good sign at all!
Cheers,
Rahul
