Re: A green Ninja 250R it definitely is! Quote:
Originally Posted by n_aditya The stock pipe on the ninja costs around 18k. |
All the more reason not to change it man. Personal experience tells me that once something comes off the bike, no matter how much you promise yourself that its only temporary, very rarely does that part find its way back on to the bike. Because then you will feel miserable about your 30K after market pipe gathering dust. Quote:
So coming back to the question, the stock exhaust weighs quite a bit, around 8 kilo's i've heard. Aftermarket ones weigh around 2 kilos or so. Also power bump with a slip-on is negligible, one bhp at the most, but coupled with weight reduction, the bike does get a wee bit faster.
These modern bikes are so bristling with tech and millions of dollars in research, that its nearly impossible for a regular Joe rider to improve on factory settings on a regular Joe budget. And as the budgets stretch, its a classic case lof law of diminishing returns as you go up the performance curve. From what you tell me, you guys are already close to the topof that curve.
In bikes like the Bullet with their stuffy exhausts and super leaned out carbs, its much easier to get bang for buck - for quite awhile. Not to mention that a Bullet sniffs at 10-20 kilos here or there. The mudguard/stays assembly alone would weigh that much. And it would be way cheaper to lose a few kilos in weight yourself while you're at it. Quote:
Power commander prices range upwards of the $200 mark. K&N filter costs around $70 in the USA. Here its sold for around 4.5k IIRC.
These sound reasonable. But at the end of the day, to go the whole hog and maximise your costly pipe, you land up spending close to half a lac. For what sounds more like subjective gains on the butt dyno. Quote:
The ninja is a modifiers money pit |
If I ever spent over 3 lacs on a bike, I would ride it bone stock for at least a couple of years if not more to suck as much value as possible out of all I have paid for. Quote:
I've hit 170kmph. Its really quick till about 160kays and after that progress is a bit slow. All these are speedo indicated speeds. There is a video on Youtube where a ninja clocked 190kmph. I've clocked 170 kmph only ONCE in my two years of ownership but have hit 165 kmph on almost every ride.
Really impressive speeds. Its no doubt a gem of a machine. I would still pick up a used one if it came at a good price. Quote:
That said, the bike is rock steady on these speeds. It's best to cruise at 140kmph since FE doesn't suffer much either.
So on rides out to the hills, on the straights while getting there and back, cruising at 140, and an aggressive session in the twisties in between, how much do you guys realistically get in terms of tankful to tankful kmpl? |
