Team-BHP > Motorbikes
Old 21st January 2014, 00:27   #16
dhaval-mehta's Avatar
Thanked: 29 Times
Re: Royal Enfield Rigid Rear Frame OR Extended Swing Arm
Originally Posted by jeepster View Post
hi imbue,
i think you are referring to Delhi based manufacturer, right?
some pics of his work.
Attachment 837290
Attachment 837291
Attachment 837292
Attachment 837293
Attachment 837294
Attachment 837295
Attachment 837296
Attachment 837297
yes you are right, Indian after market parts industry is very small which uses very old school technology, thus resulting in less accuracy & quality.
IMO you should get a custom hard tail or extended swing arm from your locality, where its manufactured with better technologies like CAD/CAM, TIG/MIG , CNC BENDER, WATER JET CUTTING etc.
(or import form USA)
rgds
Nikhil
Sir, where can I get the hardtail frame, the pictures of which you have posted above.
dhaval-mehta is offline
Old 21st January 2014, 00:53   #17
Thanked: 425 Times
google for royalenfieldzone (also know as chawla auto spare)
or
vintageautoworld owned by rohan nino .
quality same in both , vintage auto world charges a lot more. There are a few others but i can vouch for chawla .
Now let me educate you on the quality , i myself purchased products from chawla and at one point was on the verge of paying 16k for a girder fork but the quality is so bad and i mean so bad that it is worthless , not even worth 500 bucks to risk your life on . I did make 10k worth of purchase but none which will risk my life . Delivery is fast though and u get what u are shown in pictures.
On hardtail frame , stay away from them . just because they look different and vintage doesnt makes them worth it , I felt the same way about girder fork at first but one look at the porous casted lugs(original girders were forged not casted) made me reach a decision .
basuroy is offline
Old 21st January 2014, 10:13   #18
Thanked: 3,011 Times
One can have the beauty of an extended swing arm , hard tail and the daily utility of a soft tail by using a covered/hidden mono shock within the swing arm. Please google the Harley version of the same.
apachelongbow is offline
Old 21st January 2014, 20:12   #19
Thanked: 29 Times
I am considering the mono shock... But I really need the vehicle to stand out. Performance is important, but that vintage look is all the more important as well.
Old 27th January 2014, 15:11   #20
Hi Mr. Dhaval-Mehta,
A hard tail on Indian roads can be a spine-cracker and can put you away from riding for ages if not for ever. What I could have said in 10 posts, basuroy has said in one with a good example (the grider).
If you, however, want the extended/low-slung look, you may go for the non-hydraulic shockabsorbers of older bullets of even an avenger.
Besides, if you want that stand-apart look, you may go for some neat airbrushing and well-made leather saddles than to play with the safety for passable features (I personally prefer a low slung soft-tail to a hard-tail anytime). You might throw in an ape-hanger instead of the regular handlebar as well (of course you'll need to source some extralong cables).
Of course, if you're building an exhibition bike, say as a specimen or something like that, then you could go for a hard-tail. But the cost/effort involved are simply not worth the salt.
End of the day, no matter how good your bobber looks, it has to be ridden hard, for the highway is where the true test lies, pal.
Hope this helps.
Happy riding!
Rhoads is offline
Old 27th January 2014, 20:43   #21
Rennjit's Avatar
Thanked: 177 Times
... the mono shock... But I really need the vehicle to stand out. ... .
Hope this helps
Rennjit is offline
Old 27th January 2014, 21:11   #22
Thanked: 29 Times
Originally Posted by Rennjit View Post
Hope this helps
Attachment 1197461
Do you have more pictures of this setup... the shock absorber seems to be fitted to the side and not the centre (with respect to the tyre)
Old 27th January 2014, 22:35   #23
Rennjit's Avatar
Thanked: 177 Times
Its an offset mono, built on regular swing arm but reinforced with a stiffener plate running along bottom. its the best pic i have, from ridermania 09.
Rennjit is offline
Old 27th January 2014, 23:51   #24
Thanked: 425 Times
I have seen quite a few specimen of monoshocked chopper enfields on the web , all look like a standard chop and weld job . One worth checking out is a cafe racer by rajputana customs which uses a honda unicorn monoshock , while it is beyond me how a unicor shocker can bear the load of an enfield , rajputana has a reputation of building better bikes than most .
My personal opinion is monoshock on old british bikes look completely out place and only worth considering if the build is a cafe racer . If you want your enfield to have a vintage stance , then there are 2 options -
1. hardtail , not suggested and if you insist , then get is constructed by a highly reputed mechanic .
2. chopping the shockers by 2" to get the original slammed stance of the bullet or other brit bikes , this is what I have done with my bike and will make a thread here showing the same. The outcome is remarkable , the bike 'looks' so much better with slammed suspension while retaining a decent shock absorbing capabilities.
basuroy is offline
