Team-BHP > Motorbikes
Old 21st September 2011, 21:00   #1
pramodkumar's Avatar
Thanked: 2,268 Times
The mysterious pink powder to fix rust issue on chrome
The mysterious pink powder to fix rust issue on chrome, today found one guy selling it got 2 packets and used half packet to rub off the rust off my rx and trust me it has magical properties. the front wheel and the front mudguard were beyond magic to fix, so have to replace them, electroplating is more expensive than a replacement.
Pramod
pramodkumar is offline
Old 21st September 2011, 21:13   #2
Thanked: 110 Times
Re: The mysterious pink powder to fix rust issue on chrome
Pramod,
No brand name , no information on who the manufacturer is? I could really use this powder!
Ashok
ashphil is offline
Old 21st September 2011, 21:19   #3
Originally Posted by ashphil View Post
Pramod,
Ashok
It was sold on the street by a hawker, he had some gleaming mudguards and rims, all done up using this powder, if you want some find out anyone from Trivandrum who shuttles to Chennai and i will gift you a pack. due to the contents of the pack courier operators will not let me courier it.
and the best part i paid just 20 bucks and 2 hours of rubbing the bike and its gleaming
Pramod
pramodkumar is offline   (1) Thanks
Old 21st September 2011, 23:30   #4
rajeev k's Avatar
Thanked: 1,954 Times
Occasionally this powder is sold on the footpaths on the Railway Station Road in Ernakulam. Demonstrates and sells. Seen in Trivandrum also years back. But boy, it works.
rajeev k is offline
Old 21st September 2011, 23:38   #5
SunnyBoi's Avatar
Thanked: 4,460 Times
Its nothing but chalk powder. It will remove the rust but make surrounding areas more rust prone. Its a band aid fix that will ruin the parts in the long run.
SunnyBoi is offline   (1) Thanks
Old 22nd September 2011, 09:44   #6
schitre05's Avatar
Thanked: 177 Times
So any good brand recommendations....... the handle bar has got small annoying rust spots
cheers!!
schitre05 is offline
Old 22nd September 2011, 09:56   #7
ArizonaJim's Avatar
Thanked: 2,845 Times
I learned long ago that the easy way is usually not the best way.
Of course, I have no idea what is really in the magic pink powder but I'm guessing it is some sort of hard abrasive material which may range in hardness from chalk to garnet. As it works so easily it is probably much harder than chalk.
The harder the material the faster it removes rust.
The harder the material the faster it removes metals like chrome.
Once the protective chrome plating is removed, instant rust will be the result unless the metal surface is coated with some sort of "clear coat" paint which is a temporary fix to say the most.
In my opinion it is better to use the least abrasive material. This is why I suggest using either steel wool or better yet if you can find it, "brass wool".
Both of these are matted material consisting of very fine, almost hair like wires and neither of them are as hard as chrome.
Because they are softer, they will not remove chrome plating unless a great deal of energy is expended in rubbing the surfaces.
The chrome plating on my Royal Enfield leaves a lot to be desired as it is very thin but it is better than nothing. That is why I wax it using the best auto wax I can find.
This auto wax is the kind made specifically for use on "clear coated" auto finishes. It contains no abrasives at all.
Wax is temporary but when it is newly applied it helps the thin chrome to keep water away from the steel underneath it.
The only place where wax or "clear coat paint" won't work is on the exhaust pipe and silencer. These get too hot for either material to last for over a few seconds after the engine is started.
They will work to protect the exhaust or silencers chrome if your not going to use the bike for a few months.
Waxing the cooler plated and painted areas often will keep your motorcycle looking new for years.
ArizonaJim is offline   (3) Thanks
Old 22nd September 2011, 10:20   #8
Thanked: 9,251 Times
Agree!
Brasso - Wikipedia, the free encyclopedia This is a better alternative to take out rust spots and in preserving the original chrome. It is available locally.
Sankar is offline
Old 22nd September 2011, 11:01   #9
vasanthn21's Avatar
Thanked: 524 Times
Pramod
Pictures would help, especially if you have before and after pictures. Some close up pictures (After) would help the experts here gauge if there is any damage due to the hardness if he powder.
vasanthn21 is offline
Old 22nd September 2011, 11:30   #10
Thanked: 3,643 Times
Stay away from the Pink Powder, as others have rightly said. I have found out, from experience, that this is a quick-fix and results in complete damage to the whole part, later on. After you have used this a few times, you will notice small Pits getting formed on the whole surface and these Pits would develop and spread Rust.
Just throw these away into your Garbage Bin.
roy_libran is offline
Old 22nd September 2011, 18:47   #11
Ripper's Avatar
Thanked: 38 Times
Ive used a similar powder here in Mumbai. The difference is it is white and not pink. It costs something around 20 bux and is available at almost all bike spare part shops. Ive been using it for a few years now on my bro's Karizma (silencer heat shied and handle bar) and am sompletely satisfied. It not only removes rust spots but shines the chrome parts. If im not mistaken its called Chakachak Fatafat chromium polish.
Ripper is offline
Old 22nd September 2011, 19:28   #12
Its not that bad, when a rust spot appears its usually a small rust spot and then it grows, so what this powder does is it scraps off the excess growth around the spot and also scrapes the rust from the spot leaving it to be barely visible, i have used it and it works, the mechs in my area swear by the quality of results and any chrome part is prone to rust over a period of time. See i just do not want to discourage you but using stern statements like
is little uncalled for, you might have had a bad experience so enlighten others but dont just kill an idea like this. My bike is 19 years old and it still has the original shocks, rims and silencer that it came with and my house is just 3 kms away from the sea and this bike has gone around india with my bro and hence has taken a lot of abuse and this powder really showed its magic and those parts look like new now, i know i have to take preventive measures like rubbing a thin film of grease on those chrome parts else it will get rusted soon.
Good to hear from a long term user, and the name is quite catchy .
Today i took the front mud guard for plating and it will cost 375 (a new one made locally is 250-350) and all he could guarantee is 5-6 months, this is usually the lifespan of chrome anyway.
I will take some pics and post it tomorrow.
Pramod
Old 22nd September 2011, 19:45   #13
noopster's Avatar
Thanked: 13,244 Times
Rust= iron oxide. When you say "fix" rust you're just chipping off the oxidised iron layer that may in some cases be holding the whole thing together. So, like a lot of folks have said, it's a temporary and illusory solution and sooner or later your bike will return it (worse than its) original state, as long as the factors causing it to rust in the first place exist (mostly environmental).
No offence but what on earth would prompt you to try a mysterious pink ANYTHING on your bike, presumably teh love of your life? Some of these magical cures do more harm than good. Treat the advice in the right spirit.
noopster is offline
Old 22nd September 2011, 19:46   #14
Pramod
I've been unfortunate then, but parts not scrubbed with this powder repeatedly, did not rust as much as the ones that were!
And I paid for it by having to replace those parts. So, I'll stick to my guns.
Old 22nd September 2011, 20:30   #15
I am not talking about rust in the frame and all, i am talking specifically about the rust on the chrome parts and if rust is holding things together then the obvious choice is to replace the part. This so called fix is better and cheaper than plating the part
True, but what i am suggesting here is not a permanent solution. But doesn't it hold true for newly chromed articles as well?
See i just tried something which most of the people recommended and it worked, so i am just spreading a word of mouth, its up to people to decide whether to use it or not, no guns pointed at any one
Taken in the right spirit and just wanted to higlight the word "some" used by you in the above line.
Here are some before pics
After pics will be uploaded tomorrow, it didn't work on the front end
Pramod
