Team-BHP > Team-BHP Advice > On modifying a car
Old 8th October 2020, 12:25   #766
Yakuza's Avatar
Thanked: 192 Times
Re: ARTICLE: Choosing The Right Set Of Tyres for your Car
Originally Posted by kamilharis View Post
Thanks for your inputs Yakuza. 215/55/R16 will keep my profile same and width wider right, my stock set up being 205/55/R16 . Will that make any difference ? This week I will be checking out on 195/60/R16 & 195/65/R16. Hope it doesn't take away the looks of current 205 width.
Ok so your current tyre size is 205/55/16 which has a sidewall of 112 mm.
215/55/16 has a sidewall of 119 mm, so will definitely make a noticeable difference in the ride quality.
195/60/16 has a sidewall of 117mm which is still better than your existing tyres.
I would avoid 195/65/16, it is too tall and will give you a big speedo error and may touch.
215/55/16 seems perfect, will look better as well.
Yakuza is offline   (1) Thanks
Old 8th October 2020, 14:59   #767
kamilharis's Avatar
Thanked: 2,227 Times
Originally Posted by Yakuza View Post
205/55/16 has a sidewall of 112 mm.
Sorry if it's a noob question. Ride gets better with with the increase in profile or increase in width of an existing set up?
I've read somewhere that "Avoid bigger wheels if you want a smoother ride".
kamilharis is offline
Old 8th October 2020, 16:58   #768
kamilharis's Avatar
Thanks to all the BHPians for your inputs. Based on the valuable comments above, I think I must be going for 215/55/R16 for better ride quality.
Just attaching couple of data, if anyone could throw in some better suggestions, thanks in advance.
ARTICLE: Choosing The Right Set Of Tyres for your Car-props-tyre.jpg
ARTICLE: Choosing The Right Set Of Tyres for your Car-tyre-speed.jpg
Old 8th October 2020, 17:00   #769
Thanked: 21,428 Times
Larger wheels mean lower side profile which again leads to harsher ride. Larger side wall = cushioning is the ride quality.
Old 18th October 2020, 08:07   #770
JMaruru's Avatar
Thanked: 375 Times
Re: (185/70R14)?
I am looking to change the tyres on 'Swift VDi'. The existing tyres are of Michelin (185/70R14) profile. Looking out for decent tyres from domestic brands.
Please suggest!
JMaruru is offline
Old 12th December 2020, 02:06   #771
ptaneja's Avatar
Thanked: 1,133 Times
Pls help guys!
Need to upgrade 5.5 year old stock tyres of Ciaz ZDi+ , run for any 55k kms.
Existing size - 195/55 R16
Not looking for more broad tyres, but just want to increase ground clearance. Also, should not face mileage drop and heavy steering.
Finally, it should not scrape when 3 adults and boot is full of luggage.
How about these -
195/60 R16
OR
205/60 R16
OR
195/65 R16
Not sure !
ptaneja is offline
Old 12th December 2020, 19:11   #772
Thanked: 537 Times
Originally Posted by ptaneja View Post
Pls help guys!
How about these -
195/60 R16
OR
205/60 R16
OR
195/65 R16
Go to http://tyrestore.in/Upsizing.htm and check which one you should go for by ensuring you do not cross the recommended error margin of less than 2%.
sam264_2000 is offline
Old 12th December 2020, 19:19   #773
ptaneja's Avatar
I already tried this, and got confused. None falls under 2%, so what should be best one just for ground clearance.
Closest one is 195/60 , for which one tyre dealer said that it would scrape on speedbreakers. 2 more dealers said that 195/60 is OK, but not the other two.
195/60 R16 - 3%
OR
205/60 R16 - 5%
OR
195/65 R16 - 6%
ptaneja is offline
Old 12th December 2020, 19:53   #774
Thanked: 537 Times
None falls under 2%
In that case, I would recommend do not go for a tyre upgrade.
Old 12th December 2020, 19:56   #775
ptaneja's Avatar
Yes, for now I have ordered RogerAbs for suspension -
https://www.rogermotors.com/productdetail/rogerab-duo
Will get it installed and will then see the space available in wheel well before deciding on size.
ptaneja is offline   (1) Thanks
Old 11th January 2021, 15:13   #776
Thanked: 188 Times
I am looking for upgrading tyres of Micra cvt. Currently they are 175/60 R15. I am looking for 175/65 R15 or 185/60 R15. For slight increase in ground clearance. Which tyres are best? 175/65 R15 or 185/60 R15? Please suggest some good tyres for less road noise too.
Anxiousblock is offline
Old 14th January 2021, 02:37   #777
I posted this in another thread, but it seems this thread is more appropriate, so posting here. Moderators may kindly delete the other post if necessary.
Dear fellow BHPians,
I had a small sidewall bulge in one of my tyres and I need to replace it. I have alloy wheels and a spare tyre with exact same size but with steel rim. The tyres are 36 months old but have done only 7000 kms. The tyres are 175/60R15
I have few questions:
1. I have not used the spare tire at all, would using it as regular tyre with alloy wheel a good idea? I plan to replace all tyres together after 4-5 years as I understand that you should replace tyres irrespective of kms because of change in rubber compound due to aging.
2. I will use the bulged tyre as spare. I have two roadside assistance subscription.
3. If indeed I have to change the tire, can I change the bulged tyre with one of the 185/60R15, 175/65R15, or 165/60R15? If yes, then which would be a better choice? This from pure financial consideration. There is only one manufacturer (Bridgestone) for my current 175/60R15, so cost is very high (6275/-), while other mentioned tyres are atleast 1500 Rs. cheaper a piece.
4. In longer term, I would like to switch to one of the three suggested tyre sizes because of competitive price and better availability.
It would be very helpful if you can provide some insight.
maksins is offline
Old 14th January 2021, 08:36   #778
mayankk's Avatar
Thanked: 8,472 Times
Originally Posted by maksins View Post
I
Cheaper ones are available on Tyresnmore.
https://tyresnmore.com/catalogsearch..._tyre_rim=5697
mayankk is online now
Old 18th January 2021, 17:18   #779
Hi team,
I am about to buy the Grand i10 Nios Turbo and I was reading on the Team bhp review (Hyundai Grand i10 Nios 1.0L Turbo Petrol : Official Review) that upgrading the tyre from the standard (175/60 R15) is a need and not want.
the car's 175/60 MRF ZVTV tyres are too thin for the turbo-petrol (this flagship engine should have gotten 185 / 195 mm tyres). The car understeers easily if pushed, with the tyres giving up much earlier than the car does. Because of the thin tyre size & rubbish MRF ZVTV Ecotred budget rubber, getting the tyres to squeal is easy. BHPians should most definitely look at upsizing to 185 / 195 mm tyres from a superior brand; it's not a want, but a need.
I was thinking of upgrading the tyres as soon as I take delivery of the car.
I was wondering if the tyre upgrade prescribed in the review would be good or not. If yes, then which one to go for between 185 and 195?
Also, do tyre dealers accept these 'almost' brand new tyres and provide some exchange value?
analogthoughts is offline
Old 1st February 2021, 11:05   #780
Thanked: 579 Times
Hi Everyone,
I could use some suggestions on which tyres to put on our Jeep Compass 4x4. The current Firestone tyres haven't run alot, but they've gotten punctured a bunch of times and the ride quality isn't great at all. I've been wanting to get rid of them since quite a long time and since I have a pretty long road trip coming up, thought its best to take the leap now.
From what I've found on other threads the Yokohama Earth-1s' are good. I'm looking for something that will improve the ride quality, I'm already happy with the handling so not looking for more grip. I also intend to take it off road once a month (though nothing too off roady due to the bad approach angle).
Any suggestions are welcome.
Turbolove is offline
