Originally Posted by rpunwani Tyre pressure will have to be maintained the same, though Load Rating may be higher. Please note that a low tyre pressure will lead to increased flexing of sidewalls and therefore heat build-up in the tyre will be more. |
rpunwani,
My logic is that a tyre designed for more load will end up behaving the same as an overinflated tyre because it has a larger contact patch and can carry more at the same pressure.
If we take a linear view of load carrying capacity vs. inflation pressure and compare 2 tyres, say a
205/55R16 91Y setup and a
235/45ZR18 94Y setup, the tyres have a load rating of 615Kg and 670Kg respectively (both at 51PSI).
Considering a Skoda Laura as the test candidate, the stock 615Kg tyre comes with a manufacturer recommended pressure of 2.2bar or ~31.91PSI.
Now, 615*31.91/51 = ~385Kg per tyre or
~1539Kg total for 4 tyres.
Given the car weighs 1465Kg including 90% fuel, a 68Kg driver & 7Kg of luggage (the standard Euro spec for Curb Weight) the suggest pressure makes a lot of sense for an average usage condition with 2 persons in the car.
With this logic, keeping the tyre pressure the same on the oversized tyres would yield the following calculation:
670*31.91/51 = ~419Kg per tyre or
~1677Kg for 4 tyres.
That puts the gap at ~138Kg, which is not very far out but still formidable in my opinion since we are comparing 2 tyres with a relatively small difference in load rating. Take a
225/50ZR17 98Y (@50 PSI) and the calculation is:
750*31.91.50 = ~479Kg per tyre or
~1914Kg for 4 tyres.
Gap = ~375Kg which is just too far out.
What say?
I feel that the fuel economy would increase
I agree that rolling resistance is not purely a function of size but I do feel that an increased contact patch and likely higher weight of the oversized tyre will most certainly make the case for lower fuel efficiency, unless you're considering always running lower revs and no change in driving style can offset the losses. Honestly, I cannot come to terms with this.
Am I missing the logic here?
Originally Posted by ramzsys Last time when i went to Ford service, i saw a 2012 ford fiesta classic's both front shocks being replaced owing to noise from the suspension. The owner lamented that Ford has refused warranty because he was using Qualis tyres(195/70 R14) instead of stock 175/65 R14. |
ramzsys,
No offence, but I'll have to call 'irrelevant' on this one. Some workshops are so stupid that they will first try to con a customer that warranty is not valid even if you put in a manufacturer recommended size, like a 225/40R18 in place of a 205/55R16. Secondly, I do not agree that oversized tyres will cause shock-absorber/strut damage, especially if the wheel size is the same.
I can tell you for a fact that the ride quality is loads better and can only be attributed to the tyre itself damping more of the road aberrations since suspension and wheels remain the same!
Originally Posted by dhanushs bharatsomany, cons will also include:
Higher un-sprung weight, which has surprisingly big and bad effects on higher speeds, when compared to lower speeds. |
dhanushs,
I am sure you will agree that very minor increase unsprung weight is mostly if not entirely offset by the fact that the same speed can be attained at a lower RPM. What matters is inertia/momentum, not just absolute weight, although I am not trying to imply that heavier is better. I say if Circumference increases at the same percentage as the weight, the final effect is zero. This does not even take into account the reduced intertial force due to lower drivetrain revs at the same speed. Still, I'd be happy to take a physics lesson in the unlikely case that I'm wrong.
More load on tie-rod end due to more wight and contact patch/friction. If ends fail, can prove to be fatal. These cons, compromise safety for a daily use passenger car. Hence, I would not advice upsizing beyond a limit.
Increased wear on tie-rod ends sounds plausible but nowhere close to as dangerous as being fatal. If they were so weak and broke at the drop of a hat then a bad rubble hit, pothole or bump would have the very same effect.
Furthermore, if you consider the fact that larger wheels would typically add to the weight even without an oversize, I don't see a threat to safety.
Originally Posted by Santoshbhat Upsizing may help reducing revs while cruising on the highway in cars with short gearing, but what about those that have tall gearing? You will end up driving in a lower gear to compensate the lack of torque. |
Santoshbhat,
100% Agreed. This makes no sense for cars with tall gears (& dated transmissions) like the old generation Cruze. But most newer cars (including the new 6 speed Cruze) come with more and more gears with relatively short (& sensible) ratio spacing. As another example, even the VW Vento is coming out with a 7 speed DSG on the 24th (24-09-2014).
Also I would not advise upsizing on cars equipped with ABS, ESP and other complicated electronics. The increased wheel dia will mess up the readings and I would not want to take risk with these critical safety related equipment.
ABS, EBD, ESP, EDL, BAS, etc. do not work on the basis of ride height but in the basis of faster than mathematically possible acceleration. Given that a larger circumference would make the same force take longer to accelerate the wheel, it is impossible for slippage detection to fail.
This is easily tested. Put a Nano Tyre on a Safari and the ABS will fail, guaranteed. Put a Fortuner tyre on the same Safari and I openly challenge anyone to make it fail.
1) Increased contact patch, 2) better cushioning from taller profile and 3) fuller wheel well can be achieved even by maintaining the same outer wheel dia. 4) There are far too many downsides in oversized tyres just to increase the ground clearance IMO.
1) Substantial increase of contact patch can almost never be achieved simply with wider/softer tyres.
2) You cannot have a taller profile without REDUCING the wheel diameter if outer diameter is the same.
3) It is impossible to have a fuller wheel well without an increased diameter, unless we're talking of a lowered suspension which still does not help close the gap on the front and rear sides (just the top).
4) I don't see any real downsides besides accelerated suspension wear yet.
LETS GET DEEPER INTO THIS FREINDS... MORE OPINIONS REQUESTED.
