I suggest you start by measuring the performance drop. Do 20-40 in 2nd and 40-100 in 4th runs at different times on different days, always shifting the same way, on the same road, and note down the time taken. That will give you an idea of the actual 'drop' in performance. My guess is it will be more perceived than actual. Though a cool night will see a definite and noticeable increase in performance.
When someone mentions psi or bar on a modded engine, it is in terms of increased pressure. For absolute pressure, add 14.7 psi or 1 bar -- since you live at MSL.
A bigger intercooler will also lead to a drop in boost, upto 5 psi depending on size, and an increase in lag as well.
I doubt you can get a better material in the same price range. The DDiS intercooler is actually pretty good quality for the price.
Clutch you will need to go custom, in which case you're looking at over 25k, excluding the flywheel. If the DDiS runs a dual mass flywheel, your clutch costing has now doubled to 50k. You could experiment with the Linea VGT clutch, and I'm sure the 1.6 120 bhp MJD abroad must use a better clutch and similar gearbox.
Think logically, a heat scoop will never solve a TMIC heatsink problem.
There are no silly questions. But you may want to take all my words with a bucketload of salt. Quote:
Originally Posted by rippergeo Ok. you asked for the location, i gave it! ![Smile](https://www.team-bhp.com/forum/images/smilies/smile.png)
I was thinking about a bigger Intercooler, and was wondering if there was space to install it in the stock location, hence the TMIC discussion started.
So, do you think the performance drop in the afternoons that I experience currently will be controlled if I get an intercooler that has more surface area and made out of materials that have more favourable thermal characteristics?
Especially, since I'm thinking of a boost controller to be added on in the future.
when you say 15 psi- that will be 1Bar+15psi in absolute terms right? sorry for all the silly questions.
Any suggestions from your side on the clutch? In case I need to replace it. currently, everything is fine on that front(touchwood)
I did think of the convection effect heating up a TMIC, but thought, that should be solved with ventilation/hood scoops. | |
