Team-BHP > Team-BHP Advice > On modifying a car
Old 21st November 2008, 10:31   #1246
Swifty2008's Avatar
Originally Posted by zerocritical View Post
1. Shell helix Ultra is fully compatible with Santro. Go for 15w50.
2. It is recomended that engine is flushed while switching from mineral oil to Synthetic oil.
Pls refer to earlier posts to get more details on Synthetic oil.
I have a Swift Petrol. Can I use Shell Helix Ultra from Swift aswell? How much is the cost?
Swifty2008 is offline
Old 21st November 2008, 10:46   #1247
Yes, I am personally using Shell Helix Ultra in my Swift Petrol. Same Grade - 15w50 can be used.
It cost me around 2700 for 4ltrs when i purchased. But now I guess the price is around 3500 for 4ltrs.
zerocritical is offline
Old 21st November 2008, 10:52   #1248
vikram_d's Avatar
Thanked: 1,188 Times
Yes you can use shell ultra helix for your swift. Costs 700 - 800 per litre.
vikram_d is offline
Old 21st November 2008, 10:58   #1249
Shakensoul's Avatar
Thanked: 241 Times
Originally Posted by gpa View Post
  1. Am planning to go for Shell Helix Ultra.. is this compatible for the Santro? Which grade should I go for? (earlier, I wanted to switch to Mobil 1, but decided I'd use that for my Alto)
  2. The engine will be decarbonized as a routine process that I follow every 20,000 kms. Should the engine also be flushed prior to the switch to the synthetic oil?
  3. Any other inputs for me that I should bear in mind while making the switch to synthetic?
Thanks in advance,
gpa
  1. Yes. Shell Helix Ultra in 5W40.
  2. Yes
  3. Advisable to keep using synthetic going forward.
Helix Ultra comes in 5W40, Helix Super is 15W40 which is not synthetic.
Yes, it can be used in all petrol and diesel cars.
Shell in India - Shell Helix Products
Shakensoul is offline
Old 21st November 2008, 11:38   #1250
nishantgandhi's Avatar
Thanked: 156 Times
A quick question - Does Mobil manufacture mineral oils as well? I could not find on their website.
nishantgandhi is offline
Old 21st November 2008, 11:45   #1251
Shakensoul's Avatar
Thanked: 241 Times
Yes, here is the range
Mobil Products
Old 21st November 2008, 11:59   #1252
Thanked: 156 Times
Mobil Products
That was quick!
I think there is a communication gap between me and my mechanic. I had asked him to put Mobil1 5W-50 (fully synthetic) which, AFAIK, retails for about Rs 650+ per ltr (i.e. approx. 3k for 3.3 ltr+flush). However, he told me today morning that he has put Mobil xx-xx ( wasn't sure of the grade) but at a total cost of around Rs 800+. Hence I presume he has put mineral oil and not fully synthetic. What adds to the confusion is that I could not find 5W-50 grade in Mobil's mineral (convention) oil product range.
Will check in evening when I collect the car.
Old 21st November 2008, 12:02   #1253
Shell Helix Ultra come in 15w50 Grade as well.. Will post the pic of my oil can soon..
Old 21st November 2008, 12:20   #1254
Shakensoul's Avatar
Thanked: 241 Times
AFAIK, all mineral oil grades start with 10W40, 15W40, 15W50, etc..
Only synthetic come in 5W40 or 5W50.
Old 21st November 2008, 15:55   #1255
nitrous's Avatar
Thanked: 333 Times
Shell Helix Ultra used to come as a 15W50.
Its now been replaced with 5W40.
@zerocritical: What's the mfg date on your can?
nitrous is offline
Old 21st November 2008, 16:43   #1256
its some where in mid 2007 I guess.. will check and confirm the date
Old 22nd November 2008, 00:01   #1257
[list=1]
Here's the pic of Shell Helix ultra Grade 15w50, very much purchased in Bangalore.
ARTICLE: Synthetic oil vs Mineral oil-dsc00852.jpg
Old 23rd November 2008, 22:27   #1258
Its jan of 2007. by the way, no reply for my previous question yet. Does anyone have any idea if synthetic oil has any expiry/best before date? Nothing is mentioned in the can.
Old 23rd November 2008, 23:27   #1259
vikram_d's Avatar
If it has an expiry date then it will be mentioned on the can.
vikram_d is offline
Old 30th November 2008, 14:26   #1260
adityamunshi's Avatar
Castrol GTX diesel isnt available anywhere, Im only getting GTD.
Saw Mobil Delvac MX 5l for 1170/- Isnt that a bit overpriced ?
Now searching for Chevron Delo 400, where can i get dealer addresses ?
adityamunshi is offline
