Team-BHP > Team-BHP Advice > On modifying a car
Old 2nd March 2008, 16:27   #796
Thanked: 9,224 Times
its another name
300V is for Bikes right? The one we bought?
Come on man.. lawn mowers are 2 stroke engines mostly.... mine is a water pump
Yes it is. And according to that article it's a 100% ester based oil. It's as good as it gets.
I suggest you read that article. It's a good source of information regarding oils. Most of the basic gyan holds good for cars too.
Sankar is offline
Old 6th March 2008, 14:14   #797
bluenest99's Avatar
What is the procedure to flush the engines n how much flush is required for 3.75 L of engine oil. Hope 1 can(443ml) of flush is sufficient.
bluenest99 is offline
Old 6th March 2008, 16:00   #798
bluenest99's Avatar
Is Mobil-1 5W/50 fully synthetic perfect for optra 1.6? the manual recommends 15W/40. Help guys..
Old 6th March 2008, 17:47   #799
Jaggu's Avatar
Thanked: 16,842 Times
@blue: i have replied to your PM and yes to both posts
Jaggu is offline
Old 6th March 2008, 17:57   #800
Akshay1234's Avatar
Thanked: 12,766 Times
asking this again guys. which synthetic oil should i get for my innova?
Akshay1234 is offline
Old 6th March 2008, 18:14   #801
nitrous's Avatar
Thanked: 329 Times
@akshay: http://www.team-bhp.com/forum/738115-post780.html
nitrous is offline
Old 7th March 2008, 14:40   #802
Akshay1234's Avatar
Originally Posted by nitrous View Post
will they work for diesel?
Old 7th March 2008, 15:33   #803
bluenest99's Avatar
Jaggu, actually i had posted this before you replied. Anyways one more question. Can flush be used for 2 wheelers as well and which is the best oil for a 4 stroke bike. I use castrol power one. Good enough?
Old 7th March 2008, 16:14   #804
Jaggu's Avatar
Careful while using flush for 4 stroke 2 wheeler coz the clutch also lives in this oil, can lead to slippage and other pain. Best is to use good oils like castrol and change every 1500-2000 kms. Worth the 100 odd bucks.
Jaggu is offline
Old 9th March 2008, 12:59   #805
wolfinstein's Avatar
Thanked: 20 Times
Originally Posted by PatienceWins View Post
Dont worry. Its normal. That means the oil is doing its job of collecting impurities in the engine.
The Magnatec in my CNG XETA, hardly changed colour from when it was poured in 6000 KM back.
I first replaced the Engine Oil from Mobil Mineral OEM TATA to Castrol Magnatec at 10,000 KM and been following it. ( First Oil Change-First STP Flush)
The Second replacement was dirty, at that time the CNG system was going an upgrade and Most XETA's had Black Smoke and Unburnt residue issue on the plugs. So 20,000 KM oil was dark brown. ( Second Oil Change-Second STP Flush)
The Third will come up soon-As said, I keep checking the Oil level on the dip stick and also the engine Oil cover on the head, Hardly find a deep change in the colour, Maybe from Golden Yellow to Mild Tobacco Yellow.
wolfinstein is offline
Old 10th March 2008, 11:19   #806
joe_mclaren's Avatar
I changed the oil in my MPFI esteem from mineral to Mobil 1 synthetic.
Was running for 3K kms and then gave it to a Maruti workshop for servicing.
the workshop guy noticed a drop of nearly 1 litre of oil in the car and he topped it up with 1 litre of mineral oil ( which he should have asked me but didnt )
Will there be any problems in running. Would i need to flush it completely and fill it up fresh?
joe_mclaren is offline
Old 10th March 2008, 14:40   #807
DieselFan's Avatar
Thanked: 259 Times
Joe,
Any mixing whether in Oil or in Drinks shouldn't be done. After saying thus would it affect you car performance - it may not for a short duration usage. Hence you need not flush it but just drain it and change the oil back to Synthetic.
Also you may check out why there is a 1L decrease in the level of Oil. Has engine started consuming more oil (This is a clear sign of problems in the engine).
DieselFan is offline
Old 10th March 2008, 16:25   #808
Jaggu's Avatar
Joe first check for any leaks and see if there is something wrong with the engine that its consuming oil.
Once this is cleared, drain the oil. Replace the oil filter and fill fresh oil and ensure the level is correct.
How much has your car run till date?
Jaggu is offline
Old 10th March 2008, 19:08   #809
bluenest99's Avatar
I got the engine oil of my optra flushed and changed the oil with Mobil1 fully synthetic oil. Yet to see the change in performance.
Do i have to keep flushing the engine every time i change the oil?
Old 10th March 2008, 20:30   #810
Akshay1234's Avatar
no. only when you change from mineral to synthetic or vice versa.
