Team-BHP > Team-BHP Advice > On modifying a car
Old 18th January 2021, 11:49   #5716
R2D2's Avatar
Thanked: 5,849 Times
Re: ARTICLE: Synthetic oil vs Mineral oil
Signature is a 5w30 a5b5 The acea b5 spec above means it is fine for light Diesel engines as well
Ok. Does Ford specify ACEA, API specs or both?
R2D2 is offline
Old 18th January 2021, 14:24   #5717
hserus's Avatar
Thanked: 9,318 Times
Ford WSS-M2C917C/D or A5/B5 as an alternate. The WSS-M2C917C/D spec is only available in Mobil Super 3000 X1 5w30, in the open market, but A5/B5 5w30 works well enough.
hserus is offline   (2) Thanks
Old 24th January 2021, 23:34   #5718
Thanked: 1,007 Times
for the Diesel cars, Amsoil has few variants, with CK spec :
a) Turbo Truck 4x 5w40
b) Signature Max Duty 6x 5w30
c) Signature Max Duty 6x 5w40
regards,
pcpranav is offline
Old 29th January 2021, 23:05   #5719
Kpzonwheels's Avatar
Thanked: 180 Times
Hi
Which is the recommended grade of engine oil for elite I20 petrol 2018 model?. And please suggest a suitable fully synthetic oil for the same
Kpzonwheels is offline
Old 30th January 2021, 06:22   #5720
hserus's Avatar
Originally Posted by Kpzonwheels View Post
Hi
Please check several past posts on this very thread? Or the Hyundai website / your car manual?
After that it is a simple matter of searching Amazon or your local lube store for the right grade
hserus is offline
Old 30th January 2021, 11:29   #5721
Thanked: 180 Times
I checked on Hyundai website and it shows 5w30 API SM as the recommended grade. I searched on Amazon and Mobil 1 esp 5w30 is the only fully synthetic oil which comes with SM rating, but it's cost is above 4000 for 4 litres
Old 30th January 2021, 11:36   #5722
hserus's Avatar
So look at the 5w30 requirements for slightly newer Hyundais it is a3b4 5w30
Get shell helix taxi - despite the name it is a good oil. Or shell hx8. Both are 5w30.
hserus is offline   (1) Thanks
Old 31st January 2021, 05:56   #5723
straight6's Avatar
Thanked: 305 Times
Anyone have experience with Mannol oils? I see them on Amazon these days and they even have a 0w16 option that is API SP. Quite expensive too.
straight6 is offline
Old 2nd February 2021, 21:07   #5724
I own a 2015 Hyundai Elite i20(Petrol) which has run 28k kms. Based on recommendations in this thread, I tried to source Shell Helix HX8 5W-30, but could not find it in Hyderabad. Drove down to Shell outlet in Habsiguda, but it was out of stock there as well. Does anyone know where I can source it from in Hyderabad? I am trying to avoid buying it online as I have doubts about the authenticity.
Is there any good alternative to the Shell HX8?
nawazlive is offline
Old 2nd February 2021, 22:05   #5725
hserus's Avatar
Shell Helix Taxi is also good and the same grade. HX8 is phased out now
hserus is offline
Old 2nd February 2021, 22:33   #5726
I have tried for Helix Taxi as well, but was not available at all the places I tried. Any other alternative?
Old 3rd February 2021, 15:20   #5727
hserus's Avatar
It is slightly the wrong rating and weight but your older Hyundai engines will happily run on parachute coconut oil, if that doesn’t sound like a good idea just get shell helix ultra 5w40 and enjoy life.
Old 4th February 2021, 23:12   #5728
Thanked: 180 Times
Is this suitable for elite I20?. It meets API SN, ACEA A5/B5. Also attaching the screenshot of i20's owners manual
ARTICLE: Synthetic oil vs Mineral oil-screenshot_2021020423074540_fd1e8ef594b195c55a3bba4818d0ce35.jpg
ARTICLE: Synthetic oil vs Mineral oil-img_20210204_231111.jpg
Old 5th February 2021, 08:52   #5729
R2D2's Avatar
What viscosity is mentioned in the manual? API and ACEA are only classifications. You need to ensure the oil meets viscosity requirements too. It should be either xW-30, xW-40 for synthetic or mineral oil. This parameter is more important than the API/ACEA label.
R2D2 is offline   (1) Thanks
Old 5th February 2021, 09:03   #5730
hserus's Avatar
Yes! Go ahead. Excellent choice though very expensive, just get their signature series instead
