Team-BHP > Team-BHP Advice > On modifying a car
Old 12th September 2007, 16:50   #556
Knight Rider's Avatar
Thanked: 28 Times
Can anyone tell me the recomended grade for an alto please, I have used castrol previously however do not remember the grade. -
Thanks in advance
Knight Rider is offline
Old 12th September 2007, 18:20   #557
rohan_fonseca's Avatar
Just changed over to castrol edge fully synth from magnatec semi synth. Engine seems a lot smoother now.
rohan_fonseca is offline
Old 13th September 2007, 21:15   #558
chetanhanda's Avatar
Thanked: 49 Times
Guys do we get Amsoil or Redline synthetic oil in India ? anyone heard of it in India ?
chetanhanda is offline
Old 13th September 2007, 21:20   #559
rjstyles69's Avatar
Thanked: 845 Times
Originally Posted by leodelg View Post
I am going to give my car for the 20K service in about 2 weeks. I enquired with Bimal Motors, Bangalore, about the Mobil1 synthetic oil for the Baleno and they said it'll cost me Rs 1000 per litre and that I would need 4 litres for it. Also, they said that it has to be changed after about 20,000 kms. Are the rates and the change period mentioned correct?
Thats damn steep dude. Now that you have picked up Shell Helix go with it.
Whatta day I had, the dude's at 3 shell outlets had no clue of this oil grade 5w50. Above all they give you gyan saying "Saar this is recommended for Bangalore" .
Originally Posted by nitrous View Post
In Chennai, Mobil1 costs 800 rupees for a litre.
Nitrous anna bangy is 20 bucks cheaper .
rjstyles69 is offline
Old 13th September 2007, 23:00   #560
Jaggu's Avatar
Thanked: 16,842 Times
Originally Posted by toiingg View Post
So you mean to say that change to Synthetic will not bring about much difference to a 90+K run engine. Why so ?
hmm all the wear has happened and nothing much to salvage on that front apart from feel good factor
@chetan: nope havent heard the names yet
Jaggu is online now
Old 14th September 2007, 00:25   #561
BUSA's Avatar
Thanked: 21 Times
I got Mobil 1 for Optra API SF, what does the Swift D require?
BUSA is offline
Old 14th September 2007, 11:11   #562
Jaggu's Avatar
Post 453
Ok swift d following is said:
"Be sure that the engine oil you use comes under the quality classification of ACEA B3. The recommended engine oil is SF 15W 40, API CG4 or above."
Oil gurus please recommend options.
Jaggu is online now
Old 14th September 2007, 11:13   #563
mclaren1885's Avatar
Thanked: 46 Times
Infractions: 0/1 (10)
Busa, Jaggu last time I was at RNS they were looking at using some synthetic/semi synthetic oil from Shell for the Swift D. Jaggu, why don't you call up RNS and talk to the works manager? He should be able to give you what oil they recommend.
mclaren1885 is offline
Old 14th September 2007, 11:27   #564
Rtech's Avatar
Thanked: 366 Times
Jaggu, tough to find a oil here that has both B3 & CG rating. Delvac has CG rating, but E3. Mobil 1 Supersync has B3 but CF rating!
Last time I changed my oil, I put in this:
Rtech is offline
Old 14th September 2007, 12:14   #565
BUSA's Avatar
Thanked: 21 Times
So that means no syntetic avilable for Swift D?
BUSA is offline
Old 14th September 2007, 12:18   #566
Rtech's Avatar
Thanked: 366 Times
No. It meets B3 & B4 (direct injection i.e. CRDI engines) standards which is specific for European Diesels. And API SM as well which is the latest for all passenger vehicles.
So this oil would be perfectly fine.
Rtech is offline
Old 14th September 2007, 12:48   #567
BUSA's Avatar
Thanked: 21 Times
Thanks Rtech, so i should buy a can of 4L of Mobil1 Supersyn 5W50 API SM for the Swift D?
BUSA is offline
Old 14th September 2007, 13:08   #568
Thanked: 28 Times
Sorry for Re-posting, Hope this one catches someones attention.
Can anyone tell me the recomended grade for an alto (3cyl) please, I have used castrol previously however do not remember the grade. -
Thanks in advance
__________________
Old 14th September 2007, 13:40   #569
Thanked: 313,291 Times
@ Knightrider, best to refer to your owners manual.
GTO is offline
Old 14th September 2007, 16:21   #570
nitrous's Avatar
Thanked: 329 Times
5W50 is good for the Alto.
nitrous is offline
