Team-BHP > Team-BHP Advice > On modifying a car
Old 19th August 2007, 01:01   #526
BUSA's Avatar
Thanked: 21 Times
In tvpm CH 1 costs just rs 921
Is that for a can of 4 Liters? Does not Mobil manufacture CF and CH sepcs?
BUSA is offline
Old 21st August 2007, 11:55   #527
Akshay1234's Avatar
Thanked: 12,766 Times
my getz needs only 3.3 liters. will i be able to get the exact amount or 3.5 liters or will i have to buy 4 liters? also sorry for asking so many times but ive still not decided which oil im gonna buy. castrol or mobil 1?
and rtech you had mentioned 650 per liter of oil at city motors, for which oil is that?
Akshay1234 is offline
Old 21st August 2007, 16:06   #528
Originally Posted by BUSA View Post
Getting 5W-50 aint easy.
I spoke to Mobil1 head office, they had only 5W-40.
Spoke to Shell, they had 5W-40 and 15W-50(Skoda uses it)
Now what to do, stick to 5W-50 and go all the way to Opera house or change grade.
Car - Chevrolet Optra 1.8
Flush GM uses - OWS
Saw a online report which says that 5w-40 is the upgraded version of 15w-50 and I can confirm that Skoda in Bangalore atleast is using the 5W-40
deepakvrao is offline
Old 21st August 2007, 16:25   #529
BUSA's Avatar
Thanked: 21 Times
650 per liter is Mobil1. You wont get 3.5Liters, you will get 4L can.
Go for Mobil1 better then Castrol IMHO.
BUSA is offline
Old 21st August 2007, 16:37   #530
Akshay1234's Avatar
but what do i do with the other 700ml?? and is a 4l can cheaper than 4 1l cans?
Old 21st August 2007, 17:22   #531
panky12345's Avatar
Thanked: 171 Times
Do i need to flush my engine before using semi synthetic?? my engine is app 97K old and I havent flushed even once.
panky12345 is offline
Old 21st August 2007, 18:17   #532
Jaggu's Avatar
Thanked: 16,842 Times
There are two types of flushing:
1) Using regular flushing oil (approx 100 rs/lit), just put in the recommended quantity (same as engine oil capacity) and run the car at slightly raised idle (1500-2000 rpm) for 10-15 mts, drain and refill.
This is pretty safe and recommended for high milaege engines
2) Using flushing products (OWS, STP etc) for flush.
These are detergents/chemicals which will clean the inards, if done every 20,000 kms will be ok but for older engines it can cause issues at times.
So @panky: get some flushing oil and flush and then put the semi synthetic oil in.
Jaggu is online now
Old 21st August 2007, 22:42   #533
csateesh's Avatar
Thanked: 176 Times
Engine Oil for Accent CRDi
Oil specification as per the manual
Multigrade : 15w40
Standard : API-CF4 or Above
And I use Mobil 1 5w-50
Am I using the right oil?
Sateesh
csateesh is offline
Old 21st August 2007, 22:46   #534
nitrous's Avatar
Thanked: 329 Times
Yes,Satheesh.
Mobil1 5W50 is ok for the Accent CRDI.
nitrous is offline
Old 22nd August 2007, 01:36   #535
razor4077's Avatar
Thanked: 299 Times
Originally Posted by Jaggu View Post
Using engine flush might be a bad idea and do you really wanna put so much of money (read sysnth oil) on 93 k kms engine?? wont make so much of difference and risks are higher.
Could you explain this? I was under the impression (and do correct me if I'm wrong) that the added protection synth oil provides would be beneficial to an old engine. What risks are you referring to? I agree that flushing might lead to removal of some deposits that act as seals, but why is using synth oil a risk in itself?
razor4077 is offline
Old 22nd August 2007, 10:35   #536
prince85's Avatar
Thanked: 123 Times
jAGGU, could you name a few brands of flushing oils that are good and available in india
prince85 is offline
Old 22nd August 2007, 11:40   #537
nitrous's Avatar
Thanked: 329 Times
This is what the OWS flush does.
nitrous is offline
Old 22nd August 2007, 12:38   #538
panky12345's Avatar
Thanked: 171 Times
thanks Jaggu.... any particular brands?
Old 22nd August 2007, 13:00   #539
vrooooooom's Avatar
My Indica(Petrol) has done 35K Kms...Planning to switch to synthetic...any suggestions??? I want to know about the recommended grade.Where can I get that?
vrooooooom is offline
Old 22nd August 2007, 13:44   #540
nitrous's Avatar
Thanked: 329 Times
For the Petrol Indica, U can use 5W50 of a reputed brand like Mobil1,OWS, Shell helix ultra,etc.
Do flush ur engine before changing to synthetic.
nitrous is offline
