Team-BHP > Team-BHP Advice > On modifying a car
Old 26th September 2019, 11:54   #5356
Re: ARTICLE: Synthetic oil vs Mineral oil
Has anyone used used or heard about this 0W20 fully synthetic oil from Idemitsu- https://www.amazon.in/gp/product/B07...8MB9HFEI&psc=1 ?
The price is really attractive and the reviews on amazon seem to be good too. But, I still needed another confirmation if this is really as good as it seems to be especially for the price.
SydNaz is offline
Old 26th September 2019, 12:36   #5357
Thanked: 163 Times
Firstly it is NOT fully synthetic as claimed. Mobile super 3000 also falls in the same category. That should be a better buy. Moreover, please check if 0W20 is ideal for your car.
greendream is offline
Old 26th September 2019, 22:51   #5358
breezydrive's Avatar
Thanked: 126 Times
As I said in my previous post - In any case as you’re just on the second service and within the warranty period don’t get your own oils, use the dealer supplied oil and change a bit earlier if you feel it necessary.
Don't worry about the 5w30 - it works just fine for light diesels.
If you've got a ton of money to spend try the Amsoil 5w30 Diesel Oil https://www.amazon.in/Signature-Synt.../dp/B07NPCJ587
I can swear by this! Changed oil in my S Cross 1.6 to Mobil esp 5w30 at 50k service. Now the car is at 56k, the last 6k have been the best in terms of driving this car. The engine is delivering probably its best power at low noise/ friction and improved FE. Touch wood!
breezydrive is offline   (1) Thanks
Old 27th September 2019, 12:50   #5359
sgiitk's Avatar
Thanked: 4,791 Times
Idemitsu is the OEM to Honda. We have used it for over 9 years in our Civic. I see no issues here.
sgiitk is offline   (2) Thanks
Old 27th September 2019, 14:52   #5360
hserus's Avatar
Thanked: 9,180 Times
Many Hondas for example use 0w20. It is a good oil for the price don’t worry.
hserus is offline   (2) Thanks
Old 27th September 2019, 23:39   #5361
Thanked: 11 Times
I own a chevrolet spark (MY-2009, Mileage: 50000 k.m). During last service i changed the oil to 5W-30 and was very pleased with the performance. Can i continue with it or should i get back to the recommended 15W-40 oil grade ?
ankur_shar is offline
Old 11th October 2019, 18:08   #5362
An update to my post- Just got the oil and the filter changed today for my swift petrol. The difference is very much discernible right from the outset, the engine seems to be much more refined particularly at idle than it was previously and performance and acceleration seem to be as good as ever if not better. So, satisfied with the oil as of now, will have to wait and see how it ages throughout the year.
SydNaz is offline   (2) Thanks
Old 24th October 2019, 10:06   #5363
Thanked: 1,099 Times
I would really like to understand the 10k km rule and what is the maximum kms you can run your car without an oil change (petrol).
Sreesh1009 is offline
Old 24th October 2019, 10:51   #5364
hserus's Avatar
What does the oil change interval for your car say - it should be in your car's user manual? Follow that, and follow that spec of oil. It can be 15,000 or 20,000 km depending on the car, or even a lakh km for some buses and trucks.
hserus is offline
Old 26th October 2019, 07:49   #5365
sharktale's Avatar
Thanked: 796 Times
Need to get the engine oil changed in my 2014 Grand i10 Petrol, having an annual run of around 5K Kms. It's grade is 5w-30 SM API.
Earlier used mineral oil, but am planning to switch to Semi-synthetic or a Mineral oil from a better brand. Owing to the low usage, do not wish to invest 4k in the best synthetic engine oil.
I have shortlisted :
Motul 4100 Power 5w-30 Semi Synthetic or Shell Helix HX6 Mineral.
Also, am planning to perform an engine flush, and am eyeing "Liqui Moly Engine Oil Flush (200 ml)" for the same.
Any other recommendation or suggestion in both matters?
sharktale is offline
Old 26th October 2019, 10:50   #5366
hserus's Avatar
You need an a3/b4 5w30 and the synthetics in this range are max around 2000 or so
Shell HX8 5w30
Castrol Magnatec Professional 5w30
These seem to be the only ones that fit the bill
hserus is offline
Old 26th October 2019, 11:21   #5367
Turrrb0's Avatar
Thanked: 658 Times
You have mentioned magnatec professional 5w30 as a3/b4 but a search on amazon throws up Castrol magnatec stop-start 5w30 as a5/b5. I can't seem to find professional online.
Is there a difference between professional and stop-start? Or is it the same?
My tiago's manual shows magnatec professional as a recommended oil, with the recommended acea rating as a5/b5.
Hope you can understand my confusion.
Turrrb0 is offline   (1) Thanks
Old 26th October 2019, 11:37   #5368
hserus's Avatar
Sorry my mistake. There is a castrol edge a3b4 5w30. Magnatec Professional is only sold to dealerships in bulk.
This is also a3b4 5w30 and looks good Liqui Moly Leichtlauf HC7 5W-30 ACEA A3,ACEA B4 Fully Synthetic Engine Oil (4 L) https://www.amazon.in/dp/B078GDLD64/..._2j-SDbY73E13F
hserus is offline   (1) Thanks
Old 26th October 2019, 11:39   #5369
Turrrb0's Avatar
Thanked: 658 Times
Ah, okay. Do you know if professional and stop-start are the same oil, but different branding, one being for dealerships and the other for consumer?
Turrrb0 is offline
Old 26th October 2019, 12:31   #5370
R2D2's Avatar
Thanked: 5,770 Times
Also, am planning to perform an engine flush, and am eyeing Liqui Moly Engine Oil Flush (200 ml) for the same. Any other recommendation or suggestion in both matters?
Please dont use an engine flush. It is not needed especially if you change oil at recommended intervals.
R2D2 is offline   (3) Thanks
