Team-BHP > Team-BHP Advice > On modifying a car
Old 23rd February 2017, 22:14   #4651
anycatd's Avatar
Thanked: 151 Times
Re: ARTICLE: Synthetic oil vs Mineral oil
What does ACEA A5/B5 mean in engine oil terms?
anycatd is offline
Old 24th February 2017, 06:18   #4652
shankar.balan's Avatar
Thanked: 23,234 Times
My Gypsy has run past 120K Kms. Even when I bought it it was hovering near the 119K mark.
On its recent service at a Maruti Authorised Centre - Green Cars, I moved over to Mobil 0W40 Fully Synthetic Oil after a complete engine flush and I added an engine additive called Atomic engine coating too, to improve efficiency, compression and whatnot.
My Dad and I took the Gypsy for a solid 200km run last Sunday and every step of the way I felt that the Gypsy was performing very well indeed for a 15 year old vehicle.
The engine does run way smoother.
I also added in STP Fuel Injector Cleaner to the last full tank of petrol. I intend doing that again alternately (every two full tanks) over four more more tanks full, because this also, to my mind, really makes a difference to the vehicle.
The vehicle engine is feeling really much better and Im happy. Call it snake oil or whatever you want, it gives me peace of mind.
I think I am staying with Synthetic oil from now on!
shankar.balan is offline   (3) Thanks
Old 24th February 2017, 06:49   #4653
Leoshashi's Avatar
Thanked: 42,626 Times
I completely agree with you on all mentioned points, but in my honest opinion, you should have skipped the engine flush part. It doesn't come out 100% and I am not exactly confident about it circulating in the lubrication system.
I also recently switched to 5w40 grade fully synthetic in my 17 year old MPFI M800, and the improvement was noticeable. I skipped the flushing part though.
Also adding fuel injector cleaner every alternate fuel tank would be overkill IMO. You can use it once in a year, that should be more than enough.
How much did 0W40 Mobil cost you??
Shashi
Leoshashi is offline   (5) Thanks
Old 24th February 2017, 09:40   #4654
R2D2's Avatar
Thanked: 5,771 Times
STP (I assume you use STP) recommends certain intervals for use of their FI cleaner. Depending on your running it would about once or twice a year @ an interval of every 3000 miles/5000 kms (check the label). I stick to this frequency.
http://www.amazon.in/STP-Petrol-Inje.../dp/B0081RYUNC
R2D2 is offline   (1) Thanks
Old 24th February 2017, 10:30   #4655
sgiitk's Avatar
Thanked: 4,793 Times
As SAE is the American Specification (Society of Automotive Engineers) similarly I think the specs quoted by you are German or maybe European. By and large you can find (near equivalence) between the two. Quite often you will see dual labelling on the containers.
sgiitk is offline   (1) Thanks
Old 24th February 2017, 11:22   #4656
anycatd's Avatar
Thanked: 151 Times
Read this on a PDF
A5 / B5
For use in high performance car and light commercial petrol and diesel engines designed for low viscosity oils where extended oil change intervals are specified by the vehicle manufacturer.
anycatd is offline
Old 24th February 2017, 17:08   #4657
sgiitk's Avatar
Read this on a PDF
A5 / B5
means nothing. Can be said for all lubes. This type of terminology is used by firms to push their own products.
Old 24th February 2017, 18:40   #4658
anycatd's Avatar
Thanked: 151 Times
From whatever I read online I feel it specifies the type of vehicle in which the oil is to be used.
anycatd is offline
Old 24th February 2017, 21:17   #4659
nitrous's Avatar
Thanked: 329 Times
Read this on a PDF
A5 / B5
This is an ACEA specification.
nitrous is offline   (1) Thanks
Old 24th February 2017, 22:17   #4660
Vikram Arya's Avatar
Thanked: 2,210 Times
Shankar, I would suggest that you use 5W-40 in your Gypsy engine next time when you change your oil.
A lot of polymers has to be added as a part of the adpack to achieve the 0W which is primarily for achieving the cold flow characteristics however as a result of that these oils are less shear stable than let’s a say a 5W-40. Majority of the OEM’s actually don’t recommend 0W-40 oil on account of that reason. The difference in pour point of a 0W-40 and 5W-40 oil is barely 4 to 5C (-47 C vs -53C), something that you don’t need in India.
I actually used to recommend 5W-40 even for my clients in Northern geographies such as Fort McMurray where winter temperature dips to -45C in peak winter.
I have dealt with a number of OEMs including GM, FCA & Ferrari & no one recommends 0W-40 except FCA. FCA only recommends 0W-40 for the SRT engines such as the 6.2 ltr. Supercharged HEMI that pumps out 707 bhp and has extremely high compression ratio. This is an engine with extremely close tolerances something which is not applicable for the 21 year old Gypsy G13BB engine (it was introduced in March 1995).
A full synthetic 5W-40 formulation would give you all the benefits that a 0W-40 would provide and then some more with none of the downsides.
My two cents.
Vikram Arya is offline   (6) Thanks
Old 26th February 2017, 09:48   #4661
sgiitk's Avatar
@Vikram Arya; I tend to agree with you on the 0W40 and 5W40 in a different light. For my less knowledgeable brethren, let me add that 0W is a misnomer, like a 0W light bulb. I will classify it as <5W. As pointed out by you,Next unless you are in high altitude Ladakh this is almost irrelevant.
Basically and multi-viscosity oil is the low viscosity oil with additives to keep the viscosity of the hot oil above the limit. So a 5W40 is essentially a 5W oil with additives to ensure that the hot oil stays above SAE40. Any oil thins down very rapidly when heated. As a demonstration, in a different context, put some Olive Oil in a pan and warm it up.
I agree that a 5W or a 0W are about the same in real life. Only 0W sounds better marketing wise!
Old 6th March 2017, 08:24   #4662
Thanked: 203 Times
My 10 k service is due. For last 4 services, I am using Mobil 1 fully synthetic & am fully satisfied with its performance. This time I want to go for semi synthetic or mineral oil. Any suggestions. My car is Verna Fluidic CRDI.
I have 1 lit Mobil 1 left with me seal packed. Want to use that too this time. Can I mix fully synthetic with semi synthetic or mineral oil. IMO it should not be a problem. Your take please.
Chitta Pradhan is offline
Old 6th March 2017, 08:26   #4663
hserus's Avatar
Thanked: 9,187 Times
You don't need to replace your oil every 2500 km!!
Typically a good fully synthetic will last you a year / 10k kilometres
hserus is offline
Old 6th March 2017, 12:37   #4664
R2D2's Avatar
Why are you downgrading to semi synthetic? Is it due to the cost?
If you want a less expensive but fully synthetic oil try Shell Helix Ultra.
Mixing is not recommended. Synthetics/semi synthetics/mineral have varying types and quantities of additives which may not play well with each other.
Since the Mobil 1 can is sealed, ask your dealer (assuming the same dealer you bought it from) to set it off against the price of a new can of oil.
R2D2 is offline
Old 6th March 2017, 15:36   #4665
devarshi84's Avatar
Thanked: 211 Times
I have heard that Liqui moly Oils are good options to mix with other oils. But it is mostly recommended to mix oils of the same brand. So you can mix mobil1 with a mobil semi. A lot of people mix oils for multiple reasons with good results, but there are no proven formulas.
When was your last oil change? 4 oil changes in 10K mileage are a lot of oil changes. If the oil change is less than 2000 kms old on mobil1 and the manual does not call for it, persuade the Dealer to skip it unless it leads to warranty issues.
There are a lot of reasons including cost that make semi synths a good choice. Good quality blends are almost half the price of PROPER Synthetic oils. A lot of oils claim to be fully synthetic but are high quality blends. For a car that does not run 15K in a year, semi-synths make a good case. My most recent use of a Semi have been Veedol and Liqui Moly.
Shell helix ultra is a good quality oil. but shell hx7 is less than half the price of Helix ultra.
devarshi84 is offline
