Team-BHP > Team-BHP Advice > On modifying a car
Old 28th June 2007, 18:44   #361
Akshay1234's Avatar
Thanked: 12,766 Times
hey guys.. need help.
will shell helix ultra 15w50 work on my innova diesel. where in bombay shouldo get this??
also what do you recommend for a getz. which synthetic oil should i use and where can i get this? and how many litres do i need?
Akshay1234 is offline
Old 28th June 2007, 19:36   #362
nitrous's Avatar
Thanked: 329 Times
Akshay, if your getz has completed 10,000 kms, U can use 5W50 grade Synthetic oil from Mobil1 or OWS or Motul or any of the reputed brands. Don't forget to use an engine flush before u do the change.
Diesel engines' oil needs are different and so, if u can source Castrol GTX Diesel,it would be apt.
nitrous is offline
Old 28th June 2007, 19:41   #363
IMP
Thanked: 30 Times
1. EDGE etc., are also good, if you are on a budget go for it
2. 40K is a new engine not old, esp in a modern car
3. De-carbonising is removing carbon deposits. I think they flushed your engine
4. Go for a good synthetic oil 15W40/15W50/20W50/10W40 etc., make sure higher number is 40 or 50.
I didn't say old, rather i asked whether it is advisable to go for a flush for an engine which has done 40k kms.
Decarbonisation is different as compared to engine flush, just found that out, just search for engine decarb in our forums.
Thx for moving the post to the right thread!
After reading through the thread, i have prepared a list of oils in order of preference given by members.Correct me if i'm wrong guys.
1. Mobil 1 5W50 API SM,SL,SJ,CF
2. Shell Helix Ultra 15W40 API SJ/CF
3. Motul 8100 5W40 API SL/CF
4. Castrol Edge ???
5. Valvoline SynPower 15W40 API SL, SJ, or CF
and if you want to stick to sanely priced oils
1. Castrol GTX Magnatec 10W40 API SM/CF
Just check out this page, it allows you to select your vehicle, and it recommends an engine oil.
Choose the Right Motor Oil
I tried many cars that are available in india, and it recommended mineral for all cars. It also says "we do not recommend SynPower (aka synthetic) for your car" This from a manufacturer! what do you think guys?
IMP is offline
Old 28th June 2007, 19:45   #364
Sam Kapasi's Avatar
Thanked: 2,453 Times
1. Mobil 1 5W40 API SM,SL,SJ,CF
and if you want to stick to mineral
Just two things IMP.
The commonly sold Mobil1 is 5W50.
And GTX magnatec is a semi-synth oil.
Sam Kapasi is offline
Old 28th June 2007, 19:57   #365
IMP
Thanked: 30 Times
Thanks for the info, sam. Didn't know it was semi synth.
IMP is offline
Old 28th June 2007, 20:03   #366
razor4077's Avatar
Thanked: 299 Times
Did you select the right area in the US (this influences the climatic conditions)? I used that tool and it recommended SynPower for my car.
Car: Mitsubishi Mirage (aka Lancer in India) 1.5L, 2000 model
Zip code: 33607 (Tampa, Florida - coz it has a tropical climate similar to India)
Car been modded for performance? Yes
Other stuff - self-explanatory
Recommended fully synth for me.
razor4077 is offline
Old 28th June 2007, 21:14   #367
IMP
Thanked: 30 Times
I checked yes for "I consider my vehicle to be a high performance vehicle and/or I have made performance modifications to my vehicle" for 3-4 vehicles and it too recommended synthetic. But if you check no, then it recommended mineral. (Same zip code)
Modifications on your engine, mean more wear and tear on your engine, so maybe it recommends, synthetic. I selected an Audi RS4, and again checked no to "consider vehicle as high performance" and it still recommended synthetic.
OT: What mods do you have on your car razor?
Cheers.
IMP is offline
Old 28th June 2007, 21:57   #368
razor4077's Avatar
Thanked: 299 Times
@IMP: Check this link. The modding process is currently in progress:
http://www.team-bhp.com/forum/modifi...t-phoenix.html
Old 29th June 2007, 00:02   #369
BUSA's Avatar
Thanked: 21 Times
Guys which specification of Mobil1 Supersync should i go in for my Optra which is nearing its 40000kms service, the engine will be decarbed first. Which flush to use and mostly where in Bombay can i get them at a good rate, i heard the rate varies from 600 - 800, is shell cheaper?
BUSA is offline
Old 29th June 2007, 01:30   #370
tsk1979's Avatar
Thanked: 23,186 Times
Wrong Magnatec is not a synthetic oil, its a mineral oil, atleast thats what the company brochure says for 10W40 which is available in India.
Highly refined mineral oil (IP 346 DMSO extract < 3%). Proprietary performance additives.
As for motul mobil etc., API-SM synthetic oil better than API-SL since API-SM is a newer standard.
tsk1979 is offline
Old 29th June 2007, 09:43   #371
IMP
Thanked: 30 Times
The most recommended, and widely available spec is 5w50. i'm planning to get it for my optra also. Also, engine decarb is different from engine flush. If you are getting the engine decarb done, you still have to get the engine flushed, before you pour synthetic in the car. You can read about engine decarb here http://www.team-bhp.com/forum/techni...html#post54682
IMP is offline
Old 29th June 2007, 15:20   #372
BUSA's Avatar
Thanked: 21 Times
@ Imp ya i am aware what engine decarb is, got my engine decarbed at 20000kms too, i just said that next service i will get engine decarbed and then add systhetic oil, any pointers on the following.
BUSA is offline
Old 29th June 2007, 15:28   #373
Sam Kapasi's Avatar
Tsk, I am not wrong. I did not say Magnatec was synthetic, I said it's semi-synthetic. In India GTX Magnatec is described clearly as a semi-synthetic oil.
The castrol website also describes GTX magnatec as a "Part-synthetic" oil.
Here
There are more sites that discuss it too. The GTX variant is mineral, Magnatec is sold as a semi-synth and Edge as aSynth.
Old 29th June 2007, 15:49   #374
nitrous's Avatar
Thanked: 329 Times
Sam is right.
And Castrol also markets a product called "Syntec" in the US which is a fully synthetic oil.
nitrous is offline
Old 29th June 2007, 15:54   #375
tsk1979's Avatar
Here
Originally Posted by nitrous View Post
Sam is right.
I went to the Castrol UK site.
There is says Castrol Magnatec 10W40 is "highly refined mineral oil with additives". This is the castrol web site, no some third party vendor!
Another funny thing is that this oil is about 10% more expensive than GTX, thats it while edge costs 4 times as much.
I also found a Castrol UK link for 0W30 Castrol magnatec which is Synthetically engineered oil with chemical name being "Alkyl Phenol"
tsk1979 is offline
