Team-BHP > Team-BHP Advice > On modifying a car
Old 31st March 2011, 11:04   #2911
Thanked: 141 Times
Re: ARTICLE: Synthetic oil vs Mineral oil
Any recommendation on engine oil for i20 Petrol? I searched this thread for i20 keyword but found none.
kalpeshc is offline
Old 31st March 2011, 11:15   #2912
Gansan's Avatar
Thanked: 5,916 Times
Refer your manual for the oil spec. Then buy an oil that meets or exceeds the API rating mentioned there. For instance, if manual specifies API-SH go for SH/SJ/SL/SM oil, but never SG. As for viscosity, ensure you stay at or above the upper figure, and at or below the lower one. Eg: If manual specifies 20W40, you can buy 20W50/15W40/10W40 or even 0W40, but never 10W30.
I recommend the Shell Helix Ultra if you don't mind the expense (RS 1000 per litre) or my favourite mineral oil - Shell Helix HX5 (~Rs 950 for 4 litres).
Gansan is offline
Old 31st March 2011, 17:07   #2913
nitrous's Avatar
Thanked: 333 Times
You can't generalise this way.
There's more to these numbers that one can see.
20W50 is a pretty crappy grade. Stay away from it.
15W40 is about the minimum grade that one should look at using.
nitrous is offline
Old 31st March 2011, 17:11   #2914
Thanked: 829 Times
The Swift Manual states: 20W40, Shell synthetic offers 5W40, can I go for it?
Happy Motoring !!
Torquedo is offline
Old 31st March 2011, 17:57   #2915
Thanked: 9,250 Times
Yep 5W40 is okay for your car. Mobl1 is good too, it's not hydrocracked, Shell helix iirc is.
Sankar is offline
Old 31st March 2011, 18:24   #2916
Thanked: 829 Times
Thanks a Ton! Sankar
Pardon me for my limited knowledge on Oils, but would be thankful if you throw some light on Oils being hydrocracked
So you would suggest Mobil1 over Shell Helix?
Thanks.
Torquedo is offline
Old 31st March 2011, 18:42   #2917
Thanks.
Hydrocracked oils are classified as group 3 oils, they behave like synthetics but they're not. Group 4 and group 5 are synthetic oils of which its the group 4 that's used in the engine.
Synthetic oil - Wikipedia, the free encyclopedia
Shell Helix Ultra 5W-40 is a group III hydrocracked oil
Read the synthetic oil part of Motor Oil Viscosity Grades Explained in Layman's Terms
I say, when a group 4 oil is available at almost the same price as a group 3 oil then why go for group 3? I, for my car, would go for Mobil1 10w40 over Shell. The MASS here is pushing Shell Helix Ultra at higher prices than open market rate of Mobil 1.
Sankar is offline
Old 31st March 2011, 19:05   #2918
Thanked: 829 Times
Thanks once again Sankar, but on the Shell website, the only oils available in India are:
0W40
5W50
Mobil Super 1000
10W40 as you suggested is not available.
Which one of the above mentioned would you suggest?
Regards.
Torquedo is offline
Old 31st March 2011, 19:19   #2919
0W40
5W50
Mobil Super 1000
Regards.
Its 0W40 indeed, bad memory. There is another oil, which i did not find at their website but is available at a car service centre here in Tvm, i took this pic sometime back and uploading it here for you. This super 3000 5W40 was slightly cheaper than the bottle next to it which is 0W40.
ARTICLE: Synthetic oil vs Mineral oil-26022011298.jpg
Do confirm that the oil match or exceed the grade recommended in your manual.
Edit1: Btw, i'm not sure if this Super 3000 is group 4 or group 3. Tryin to find that out. You're safe with M1.
Edit2: It seems Super 3000 is group 3 Esso Ultron 5W40. So Shell helix ultra 5w40 and Mobil super 3000 5W40 both are group 3. Here the Super 3000 was being sold at Rs850 iirc. Only M1 is group 4.
Sankar is offline
Old 31st March 2011, 19:36   #2920
1self's Avatar
Thanked: 334 Times
Guys, where does one buy "Motor Silk" oil & additives in India?
Thanks!
1self is offline
Old 31st March 2011, 19:43   #2921
condor's Avatar
Thanked: 16,800 Times
10W-40 not good ?
Saw this note about GM not recommending 10W-40. What do you guy say ?
Note:
Motor oils that have a wider range viscosity rating such a 5W-30, 5W-40 and 0W-40 are blended with more base stocks and additives. Because of this, it may be harder for a wider range oil to remain in grade as the miles accumulate (which is why GM does NOT recommend using 10W-40 motor oil. They say it breaks down too quickly and does not say in grade as long as 10W-30 or 5W-30. Also, an oil with a lower winter rating like 0W-20 or 5W-20 will contain a higher percentage of thinner base stock oil (which is typically a synthetic oil. This requires more viscosity improver additive to achieve a the same high temperature rating as a 10W-30, 10W-40 or straight 30 or 40 weight oil.
condor is online now
Old 31st March 2011, 20:16   #2922
Re: 10W-40 not good ?
I would say i'd go with the recommendation of German car makers like BMW or Porsche in using an even wider range oil like Mobil1 0W40 rather than GM. But wrt mineral oil grade like 20W50 or 20W40 i guess GM finding doesnt apply. Not sure about wide range semi-syn and goup 3 (which can be sold as syn in USA).
Sankar is offline
Old 1st April 2011, 06:25   #2923
sgiitk's Avatar
Thanked: 4,808 Times
@sankar: following your link above I find that now there is an API-SN! A who;e new ballgame. Can someone find and post the card of specs or a link to it. I am currently, at a location with very slow connectivity.
sgiitk is offline
Old 1st April 2011, 08:19   #2924
This came out last year. Hope this helps APISn.pdf (261kb)
Sankar is offline
Old 1st April 2011, 17:07   #2925
nishantgandhi's Avatar
Thanked: 156 Times
Has Mobil 1 increased prices recently? I used to procure it at Around 685-700 per liter, 1 year back. Recently, I was quoted Rs 1100 per liter! Can someone please confirm?
nishantgandhi is offline
