Team-BHP > Team-BHP Advice > On modifying a car
Old 30th March 2010, 09:51   #2446
rakesh_r's Avatar
Thanked: 3,428 Times
err does anyone from Mumbai know where i can purchase shell engine oil for my 98 carb zen.The shell station is going to shut down from 1st april.They are shifting to Pune
rakesh_r is online now
Old 19th April 2010, 10:33   #2447
Thanked: 67 Times
Yesterday I put Toyota recommended synthetic oil in my Innova, they say change period i.e 10K remain same. I would like to know from experts, is it really same? Then what's the point paying triple amount.
sam003 is offline
Old 19th April 2010, 10:47   #2448
Sahil's Avatar
Thanked: 7,999 Times
Mineral oil is recommended to be changed at 5000kms, with synthetic you could 50% kms.
I thought the service period for the Toyota diesel cars is 5000kms while the petrol are 10,000?
How much did Toyota charge you for the oil?
My Fortuner is due for it's 1000km service this week- Should I switch to synthetic now itself?
Sahil is offline
Old 19th April 2010, 11:13   #2449
nick17s's Avatar
Thanked: 103 Times
@ sahil: if you wish to you can, it wont hurt anything, but I'd suggest do that after your car is run 5000kms, as the oil is still new.
nick17s is offline
Old 19th April 2010, 14:34   #2450
Thanked: 67 Times
Service period is 5k, but they generally wash and do general checkups on 5,15,25,35... and 10,20,30 etc they do oil change and other things too.
They charge around Rs 670/ lt and total 7 lt it takes so 670*7. As off now I haven't seen any difference is driving, ya just felt like new oil.
sam003 is offline
Old 19th April 2010, 14:59   #2451
R2D2's Avatar
Thanked: 5,848 Times
You pay more for much better lubrication and protection that synth oil gives you. I saw the Toyota synth when I had my car's free service done in Oct 09. With 5W-40 API SM/CF specs, I felt it was more suited for petrol rather than diesel engines. Why? You get better API spec diesel engine oil in CH and possibly even CI or CJ. While SM is top slot for petrol engine oils.
If synthetic pricing pinches (as it will for most of us) go back to mineral and stick to the normal oil change schedule. Either way, never extend oil change intervals to justify the additional cost of synthetic.
Cheers!
R2D2 is offline
Old 19th April 2010, 15:22   #2452
Twiny's Avatar
Thanked: 62 Times
7ltr for Innova oil change, true ?
Twiny is offline
Old 19th April 2010, 17:46   #2453
Thanked: 67 Times
Yes this is what I know, as they show 4ltr *1 and 1 ltr *3 in bill. so total 7 ltr oild required.
sam003 is offline
Old 19th April 2010, 20:28   #2454
Thanked: 320,308 Times
Best to switch after 10,000 kms. Over the initial coupla thousand kms, wear & tear is good.
GTO is offline
Old 20th April 2010, 00:38   #2455
Thanked: 23 Times
Hello everyone!
My verna crdi is due for its 3rd service. Its done 18000km and i am planning to change the engine oil. I would like to know some things.
1) What grade?
2) Which brand is the best? Mobil delvac MX or delo 400 or some other which you all recommend.
3) Do i need to do flushing again, had done it after 10000km i.e for my 2nd service.
Present verna owners who have changed over to this can shed some light.
shreyasMAX is offline
Old 20th April 2010, 03:58   #2456
Thanked: 216 Times
I had changed over to Mobil One in my Baleno sometime ago. Wanted to have the toyota approved synthetic oil in my Innova Diesel for the 10k service. Ordered it but when I realised that they have to put in 7 litres and the drain interval remains at 10k kms, I shifted back to normal oil. Rs 5k extra per oil change, compared to the regular mineral oil, makes the deal very tough for the innova.
Buffetfan is offline
Old 20th April 2010, 06:18   #2457
ph03n!x's Avatar
Thanked: 6,156 Times
Originally Posted by shreyasMAX View Post
Hello everyone!
1) What grade?
Mobil Delvac MX is pretty good mineral oil - stick to 5000 KM oil change intervals. If you can find it, Mobil Delvac 1 is a good synthetic choice - if you choose any other synthetic, ensure it is API-CI4 rated or higher, oil change intervals should not exceed 75000~10000 even on synthetics. The recommended grade for most common uses is 15W40, but check the user manual and find which grade best suites your ambient temperature of application.
You need not have flushed at 10000 KM, and do not flush now either - flushes are not required unless the engine has clocked a lot of KM - I'd say 50k+ or even more. Too frequent a flush can actually cause more damage than good.
ph03n!x is online now
Old 22nd April 2010, 23:45   #2458
Thanked: 67 Times
I am not sure which synthetic oil toyota put in my Innova. But frankly now I have experienced the difference. Engine response has improved(specially pickup), seems more refine then before. Mileage improved by 1km as off now. Does this true with change of synthetic oil or I am feeling like that (due to high cost which I have incurred )
sam003 is offline
Old 23rd April 2010, 10:33   #2459
Twiny's Avatar
Thanked: 62 Times
Yes smoothness, refinement can be easily felt when shifting to Synthetic oil.. that is why I am also sticking to synthetic.
Twiny is offline
Old 23rd April 2010, 11:49   #2460
sgiitk's Avatar
Thanked: 4,808 Times
We tend to attribute a lot of smoothness etc. to the new oil, while it is the general tightening, etc during service.
sgiitk is offline
