Team-BHP > Team-BHP Advice > On modifying a car
Old 16th July 2009, 10:37   #1711
srikant's Avatar
Thanked: 12 Times
So which one can i use for the DDiS now? CI or CG? As far as i know, CI may not be a problem to use in CG rated. So can i change to Mobil Delvac 1 5W-40/API CI-4?
srikant is offline
Old 16th July 2009, 10:46   #1712
Eddy's Avatar
Thanked: 14,497 Times
Yes, you can always go higher !
Eddy is offline
Old 16th July 2009, 11:59   #1713
sgiitk's Avatar
Thanked: 4,808 Times
Originally Posted by mdesai_1981 View Post
hi guys ,
well i have e small query i'm right now in us and i'm getting castrol syntec 5W-40 API-SL ...
API-SL is normally a mineral oil and not a semi- or full-synth. These are API-SM. I have both Magnatec as well as Petronas mach5. Both as SM and API-SM.
sgiitk is offline
Old 16th July 2009, 15:50   #1714
mdesai_1981's Avatar
Thanked: 29 Times
thanx sgiitk,
thank you sir
mdesai_1981 is offline
Old 16th July 2009, 18:32   #1715
Thanked: 21 Times
How good is Shell helix Super 15W-40? Is it a mineral oil or semisynthetic?
The sales person at shell pump is saying that this oil can be used around 12000KM inteasd of normal 10K.
I am thinking to use this oil for WagonR which is completing 20000 Kms. My use is 70% highway. I am also thinking to use engine oil additive from OWS with oil change. Please let me know is any other oil is suggested.
shabahmad is offline
Old 17th July 2009, 06:40   #1716
Thanked: 29 Times
hi guys another idiotic question.
waht is the difference between MOBIL 1 OIL FILTERS and OEM OIL FILTERS?
does mobil 1 oil filter really help if one switches over to synthetic oil?
Old 17th July 2009, 06:54   #1717
Thanked: 1,280 Times
Shell Helix super is a mineral oil which is API-SL/CF.Just check in your Wagon R's service manual what's the minimum required specs by Maruti.If API SL meets/exceeds the requirement,you can safely use it.
rb2399 is offline
Old 17th July 2009, 10:18   #1718
Thanked: 21 Times
Thanks RB for replying. Manual says oil should be SF, SG or SH. I think these grades are obselete now. So moving to SL or SM.
Shell sales person claims that this oil can be used for extended time. Did anybody used this and extended there drain period. My car is mostly used for highway driving.
Any other semi synthetic suggested and available in pune
Old 17th July 2009, 10:22   #1719
gpa
gpa's Avatar
Thanked: 345 Times
I think its best to stick to your vehicle's OEM filter and switch to the synthetic oil. Also, I don't think Mobil 1's performance oil filters are available for all brands of cars. Would be great if someone would throw some light on this.
gpa is offline
Old 17th July 2009, 10:55   #1720
srikant's Avatar
Thanked: 12 Times
Can anybody help me with this question? Which is the CG rated fully synthetic oil for swift DDiS and whats the cost for the same?
srikant is offline
Old 17th July 2009, 10:59   #1721
tsk1979's Avatar
Thanked: 23,484 Times
Castrol Edge turbodiesel is API-CI4 and exceeds the required specification of your car. You can go for it.
Cost for 4 liters should be around 2000rs
tsk1979 is offline
Old 17th July 2009, 11:28   #1722
Which engine oil ?
Hello all,
This is a MAYDAY x 3 for information.
Have given my Palio Stile 1.6 for fourth service. Done close to 17k on the clock. Planning to change over to fully synthetic engine oil.
Request all "oil raja's" to provide some insight on the best brand available in India. I have looked and found Mobil1 (5W-50), Shell Helix Ultra (5W-40) and Castrol Magnatec (10W-40). Are these suitable to my car at all?
Please respond asap. Gotta hand deliver the goods to the service station by 15:00 hrs today.
Last edited by Jaggu : 17th July 2009 at 11:52. Reason: Please use search before opening a new thread! Thanks
meremortal is offline
Old 17th July 2009, 11:32   #1723
jkdas's Avatar
Thanked: 1,496 Times
http://www.team-bhp.com/forum/modify...neral-oil.html
http://www.team-bhp.com/forum/techni...ade-palio.html
jkdas is offline
Old 17th July 2009, 14:26   #1724
Raccoon's Avatar
Thanked: 116 Times
Originally Posted by meremortal View Post
Hello all,
Why is it that so many people thing Castrol Magnatec is a fully synthetic oil?
Bingo! I guess I know the answer - dubious marketing!!
Raccoon is offline
Old 17th July 2009, 14:36   #1725
sgiitk's Avatar
Exactly SF was the basic grade. SG had additions to qualify it as fuel saving. SH was for semi-synths (if I remember right). You can still find SF in good old Servo while BP claims to have launched SG! Since the minimum called for is SF any of SJ (obsolescent but still current), SL or SM will do. Incidentally SF was the first grade to permit once a year /10000mile oil changes.
sgiitk is offline
