Old 1st December 2014, 19:22   #1411
saadat1992's Avatar
Thanked: 387 Times
Originally Posted by batterylow View Post
Changed the Roots wind-tone 90 to the Hella red grills.
Paid 1350 for the horns as wiring was reused from the wind-tones.
BL
Exactly what I did 10 months ago.
The roots windtone got damaged during the service. I felt the roots wasn't that good or striking.
The hella Supertone red grills are very powerful & penetrating. They are very useful on the highways where people trying to cross the road turn to see your car & the bigger vehicles move out of your way without hesitating.
These horns combined with my 100/90 headlamps make my highway trips a breeze! I got mine for 1500 bucks including installation charges.
saadat1992 is offline
Old 6th December 2014, 13:51   #1412
Kappa's Avatar
Thanked: 16 Times
re: Power Horns!
Hi guys!
Just wanted to know if I could get the Pulsar's dual horns in my Honda Activa?
Kappa is offline
Old 9th December 2014, 14:13   #1413
Mr.ASG's Avatar
Thanked: 18 Times
re: Power Horns!
Originally Posted by Kappa View Post
Hi guys!
Pulsar no-longer comes with the original dual horn, I think its better to go for aftermarket brands.
Mr.ASG is offline
Old 9th December 2014, 21:02   #1414
Kappa's Avatar
Thanked: 16 Times
re: Power Horns!
Are there some low pitched horns available, just like the VW Polo ? I like their sound and they seem to be very effective too. Moreover, being low pitched, they are not a pain to the ears despite being loud.
Please suggest.
Thanks!
Kappa is offline
Old 10th December 2014, 12:09   #1415
sushrutha's Avatar
Thanked: 334 Times
re: Power Horns!
Hi guys!
You can, but ther's very little space in Activa battery compartment to accomodate dual horns. If you fit one make sure you fix a relay(cutout) too, to reduce the burden on battery & wiring.
I have seen/heard some Activa been fit with PNP/Roots horn (Horn sound similar to Skoda, VW, Merc horns)
sushrutha is offline
Old 10th December 2014, 12:12   #1416
rakesh_r's Avatar
Thanked: 3,433 Times
re: Power Horns!
Hi guys!
I would suggest three options (w.r.t space constraints)
1-Pulsar 220 horn set
2-Apache RTR horn set
3-Suzuki GS 150 horn set
rakesh_r is offline
Old 10th December 2014, 12:13   #1417
Thanked: 135 Times
re: Power Horns!
What is the best place to fix the trumpet horns (The skoda sound ones?) in a Dzire? If anyone has a picture, please share here. TIA
ILTDrive is offline
Old 10th December 2014, 12:50   #1418
Kappa's Avatar
Thanked: 16 Times
re: Power Horns!
If these are dual horns (set), then how can I fit them in the activa's small compartment which has space only for a single horn?
Thanks!
Kappa is offline
Old 10th December 2014, 15:38   #1419
gendarmee's Avatar
Thanked: 32 Times
re: Power Horns!
Thanks!
Check out the pics below. The relay is under the odometer.
I've done the same on the Activa as well, but the horns had to be fixed directly to the plastic body(without the metal extension/patti). Getting the placement of mount holes right is tricky though.
Last edited by GTO : 11th December 2014 at 14:11. Reason: Re-uploading pictures as attachments
gendarmee is offline   (1) Thanks
Old 10th December 2014, 15:51   #1420
Kappa's Avatar
Thanked: 16 Times
re: Power Horns!
I've done the same on the Activa as well.
Thats nice! But where's the separate switch for those dual horns? I dont see it anywhere..
Last edited by FlyingSpur : 11th December 2014 at 01:20. Reason: Please do not include images in quotes.
Kappa is offline
Old 10th December 2014, 16:04   #1421
gendarmee's Avatar
Thanked: 32 Times
re: Power Horns!
Uses the same horn button, and to switch b/w the two(single horn/trumpet horns) I've fixed an extra dipper switch on the right side of the odometer. Please see the 2nd image.
Old 10th December 2014, 17:54   #1422
Kappa's Avatar
Thanked: 16 Times
re: Power Horns!
Man, thats clean! BTW, which ones are those horns?
Thanks!
Kappa is offline
Old 11th December 2014, 09:12   #1423
vinod_namakkal's Avatar
re: Power Horns!
Hi Guys,
Can we use trumpet horns in cars. I believe these trumpet horns are banned by RTO in Tamilnadu. I always wanted to have a pair of these in my Maruti 800. I currently have the Roots Horns (bigger one). It sounds loud but the problem is that while the headlights are on, the horn doesn't blow properly. There is no problem in the battery. Self start and all other electrical components are just fine.
Can you please suggest a good pair of horn for my car.
vinod_namakkal is offline
Old 12th December 2014, 11:04   #1424
rakesh_r's Avatar
re: Power Horns!
Thanks!
Sorry for the late reply,you might have to remove the front cover and hunt for a place in the recess ahead of the front storage compartment. I had a KI-HO marvel and had installed roots windtones . I had to drill a hole on the fibre body to mount the horns. Worked well till I sold the scooter to a scrap dealer after 15 years of usage.
Originally Posted by vinod_namakkal View Post
Hi Guys,
Since you already have loud ones, you can try the stock Hella horn pair that comes in swift. About the headlight going dim,please check the Horn Relay.
rakesh_r is offline   (1) Thanks
Old 13th December 2014, 14:48   #1425
re: Power Horns!
Thanks rakesh, Will check the relay. also how about having a trumpet horn. I prefer an economical one. and also please suggest a better place to place it in my Maruti 800.
another problem with my current roots horn is that on honking it echos back inside the cabin.
