Old 29th July 2008, 18:35   #421
cyclops's Avatar
Thanked: 12 Times
Has anyone in pune installed a stebel? Where are they available?
cyclops is offline
Old 29th July 2008, 18:47   #422
Amit and Akroy thanks for replying.Yes I make sure that I wont do it myself.But one problem is in SX4 the slot provided for fitting additional swiches is completely filled.
D.V.R is offline
Old 29th July 2008, 20:15   #423
amit_mechengg's Avatar
Thanked: 2,263 Times
Originally Posted by cyclops View Post
yes i have fitted it from nana peth cost Rs.950 + Rs100 installation + Relay + wiring costs. in pune its very useful to make your way through autowalas and PMTs. mainly to scare bikers who speak on mobile and drive in between. Full Paisa Wasool
dont worry the fitter will attach the switch somewhere, or else he may drill a small hole if u permit.
amit_mechengg is offline
Old 29th July 2008, 20:50   #424
akroy's Avatar
Thanked: 88 Times
Originally Posted by JayD View Post
The Skoda does NOT use roots horns, it has a Klaxton 'Made in France' horn, which looks similar to the windtones.
I dont know but during my search I went into Roots website where it clearly mentions Skoda India as one of its OEM customers. Since the sound is similar I thought it is the same (I think I got a second confirmation from a Maruti dealer as well, dont know whom!!)
Anyway, my purpose is getting solved quite well with those horns specially helpful in highways.
Abhi
akroy is offline
Old 29th July 2008, 21:28   #425
ankitahuja's Avatar
Thanked: 99 Times
Originally Posted by me_sid View Post
Hi ankit! Hella red grill is uncomaparable, hehe do i see some frowns? Kidding. Roots Vibrosonic is load and decent, Megasonic loudest and downright bada** Well, good for highways, you can buy them as you have the provision of repair in roots which stebel doesnt have unfortunately
Cheerscheers:
Hmm, but why is the Megasonic cheaper than the Vibrasonic?
How about a review of both by someone? (I presume that the Vibramax is a lower version of these 2).
ankitahuja is offline
Old 30th July 2008, 14:35   #426
Chevy_lover's Avatar
Thanked: 130 Times
Hella Red Grill
Hi Guys,
I installed a Hella Red Grill yesterday. The total cost was Rs. 1350. The installer removed the stock horns, which were of Fiamm, and installed Hella in its place. He insisted that there are relays installed by the company for the Fiamms, so a new relay was not required. Do I need a new relay?
Please advice.
Chevy_lover is offline
Old 30th July 2008, 16:07   #427
Thanked: 108 Times
On Power Horns, I have a simple question.
I want to install it in my Swift. What I am planning is to get it toggled on/off with the switch for my reversing horn. Is it possible?
What I mean to say is that presently I have a reversing horn in my swift with a switch. I am plannning to install the power horns (I dont know if I need a seperate relay for it ) which will function with the same switch of the reversing horn. When reversing horn is switched on, power horn is off, and when the reversing horn is switched off, power horn is on. Is it possible ?
Can anyone shed light on this please ?
lambuhere1 is offline
Old 30th July 2008, 16:18   #428
bblost's Avatar
Thanked: 17,953 Times
Unless you dont want to use your power horns only and only when reversing, I dont see why you would do this.
bblost is offline
Old 30th July 2008, 16:24   #429
Thanked: 108 Times
During Reversing, I shall use my Stock Horns which don't scare the hell out of people during reversing, wherein the vehicle speed is slow. Effectively, I want to keep my stock horns, power horns and reversing horns and use their full functionality
Old 31st July 2008, 11:28   #430
me_sid's Avatar
Thanked: 208 Times
Originally Posted by Chevy_lover View Post
Hi Guys,
Please advice.
Just check in your manual the ratings for the OE relay ( it might be written on the rlay casing under the bonnet) and correlate with the horns rating as in current consumed if they match then its ok if its not then change the relay.
me_sid is offline
Old 31st July 2008, 11:47   #431
Thanked: 130 Times
Thanks Sid. My stock Fiamm horns were also 12V and about the same size as the new Red grill. Both are dual horns. So I guess it should be fine. I will also check the rating on the relay.
Old 20th September 2008, 14:56   #432
sonic_boom's Avatar
Thanked: 16 Times
Guys , stebel nautilus desperately needed in delhi for my alto....
Please specify location and price ??
sonic_boom is offline
Old 22nd September 2008, 09:33   #433
Thanked: 268 Times
sonic_boom : Go for Roots Vibrasonic. Price 600-700
mithun is offline
Old 22nd September 2008, 23:43   #434
sonic_boom's Avatar
Thanked: 16 Times
Mithun bhai... got Roots fitted this Sunday from Driven already. Sound is pleasant and effective. A relay and switch for switching between OEM and roots was also fitted.
Overall....I'm loving it !!
Old 23rd September 2008, 10:23   #435
sudipt123's Avatar
Thanked: 70 Times
I've used a steibel nautilus on my Indica for more than 3 years with the relay it comes with and new wiring. It worked like a charm. It had survived the Mumbai rains of July 2005! Unfortunately it died out a year back. When I went for a replacement, I saw a another steibel with dual pipe horn for about 1200Rs. though was apprehensive to use it in the city. So, installed minda horns. Man, i really miss the steibel.
sudipt123 is offline
