Old 28th January 2020, 12:16   #1726
Thanked: 446 Times
Re: Power Horns!
Upgraded the horns on my EcoSport to Hella Red Grille Supertones. They are absolutely amazing!! Its loud and sharp. Physically they are almost twice the size of the stock horns.
I am even more careful now in blasting them around housing complexes.
suku_patel_22 is offline
Old 28th January 2020, 12:56   #1727
mukeshgoel's Avatar
Thanked: 2,412 Times
Re: Power Horns!
Originally Posted by rayjaycleoful View Post
Bob's Auto Mall, located exactly at Atul Kataria Chowk sector 14.
I got Hella Chrome Trumpets installed from Bob which I bought from Amazon. They did a nice job and installed it in 15-20 minutes.
Incidentally, I had my Autoform seat covers in Jan'19 from them.
mukeshgoel is online now   (1) Thanks
Old 28th January 2020, 13:03   #1728
Thanked: 601 Times
Re: Power Horns!
Yes their staff is quite fast and courteous.
I prefer buying horns from them because they replace it no questions asked if something goes wrong (within six months warranty)
Do share pictures of the seat covers and details about their comfort.
rayjaycleoful is offline   (1) Thanks
Old 9th February 2020, 20:42   #1729
Thanked: 1,116 Times
Re: Power Horns!
Had changed my Amaze's Horns to a set of Bosch Symphonys a few months back. Last month, the low tone stopped working and only the high tone works, which makes it sound horrible. What could the issue be? Should I replace the horns?
Thank you.
Sreesh1009 is offline
Old 9th February 2020, 22:49   #1730
paragsachania's Avatar
Thanked: 27,204 Times
Re: Power Horns!
Thank you.
Check the connectors on the affected horn. If possible, try to isolate wiring by testing that horn by directly connecting to battery terminal. If it is working fine, the horn of course is not to be blamed. If horn doesn't work when connected this way to battery, if is the horn that's gone.
To isolate relay/wiring issues, swap both the horns with the connectors and check. If the other horn doesn't work on the swapped connectors, it's wiring/relay issue.
paragsachania is offline   (2) Thanks
Old 15th February 2020, 17:36   #1731
Re: Power Horns!
So I found the culprit. How do I go about repairing it?
Old 15th February 2020, 18:07   #1732
revvharder's Avatar
Thanked: 1,219 Times
Re: Power Horns!
Just get a new connector crimped at the end of the wire by any car electrician.
revvharder is offline
Old 28th February 2020, 16:43   #1733
Thanked: 601 Times
Re: Power Horns!
I understand Honda City has "Honda" horn connectors. Did Bob's cut the wires or use connectors?
Old 28th February 2020, 17:15   #1734
mukeshgoel's Avatar
Re: Power Horns!
Absolutely no wire cuts. Stock horns (not sure both or one) are connected with only one pin connector and aftermarket horns have two pins. So, he made a small cable for second pin that is connected to car body for grounding.
PS: I didn't like Hella Chrome Trumpets unlike most people. I like cheaper Minda Trumpets in my other car.
mukeshgoel is online now   (2) Thanks
Old 29th February 2020, 18:30   #1735
DebarshiSharma's Avatar
Thanked: 132 Times
Re: Power Horns!
Hello everyone,
I am looking for a good and reliable horn replacement for my Ignis stock horns. The stock ones fitted in the Seltos and the Creta sounds fantastic. Can anyone please suggest me a similar type for my vehicle? Also, I am based in Pune. It would be great if you could suggest any stores in the city.
My car is under the extended warranty though. So, will changing horns lead to any issues regarding the same?
- DS
DebarshiSharma is offline
Old 29th February 2020, 19:08   #1736
ashis89's Avatar
Thanked: 12,153 Times
Re: Power Horns!
Originally Posted by DebarshiSharma View Post
Hello everyone,
- DS
You can try Bosch Symphony dual tone horn. I have it on my WagonR for the past 3 years now. It's louder than the stock horn of my Seltos.
Since my WagonR had dual tone horn as stock setup, this Symphony was a plug and play replacement without affecting warranty.
Edit: Here's the product listing : https://www.amazon.in/dp/B01H078EEO/..._FMMwEbZ7P2J33
ashis89 is offline   (1) Thanks
Old 1st March 2020, 01:07   #1737
Thanked: 132 Times
Re: Power Horns!
Thanks a lot for the suggestion.
Sorry, just one last doubt. Do I need to fit a relay as well?
- DS
Old 1st March 2020, 02:12   #1738
ashis89's Avatar
Re: Power Horns!
- DS
If your OEM horns are dual tone(like the one on my WagonR), you wouldn't need a relay. The existing relay would be sufficient. These Bosch horns are rated 3A and hence were a simple replacement of the existing horns on my car.
Old 1st March 2020, 02:13   #1739
Thanked: 132 Times
Re: Power Horns!
Yes. The stock ones are dual tone indeed. Thanks a lot for the help!
- DS
DebarshiSharma is offline   (1) Thanks
Old 14th April 2020, 18:31   #1740
Reinhard's Avatar
Thanked: 18,118 Times
Re: Power Horns!
Found the Tata cars' horn wire coupler!!
I will be replacing the stock horns in my Nexon with the wind tone trumpets that I have with me. Obviously the connectors are totally different. I don't want to splice the wires for 2 reasonss -
  1. Primary reason - the horns are placed quite precariously and any servicing needs the bumper to be removed. I don't want to do this often due to connection issues.
  2. Not so important in my case - Technically such wiring can void the warranty. Although I have a nice kitty full of goodwill with my TASC place, I don't like to use it!
I had spliced the wires in the Vista, but it was well out of warranty then and also had the horns located very easy to access. So was trying to find the right coupler for this connection since quite a while but no luck. Stumbled upon it finally here at AliExpress -
Link - Tata cars' horn wire coupler.
I'm quite sure this is the one but haven't tried yet due to lockdown! If anyone has already tried it, do let me know.
Its the same unit on all cars from the brand since a long while! And guess what - its actually the EV1 coupler used quite regularly for the electrical wiring connections of the fuel injection systems of the engine!
Points to note -
  1. Car harness has female socket fixed.
  2. Horn wire will need male socket, order just the male one from the link above.
  3. If 2 horns - you'll need 2 couplers.
  4. Solder 2 wires of this new coupler with the 2 pins of the horn in right polarity & you are good to go!
Unless someone reports that this is not the right product, I'll order it once the COVID19 emergency subsides from all places & lockdowns are over. I'll wait a while longer to ensure all postage / shipping backlogs are cleared and then will order. Meanwhile - I'll be scouting the CNG retrofit shops once the open. I suspect they'll have these available for their use with the kits. Worth taking a chance.
Reinhard is offline
