Old 22nd January 2008, 01:00   #1291
razor4077's Avatar
Thanked: 299 Times
Originally Posted by dinoo82 View Post
I have heard that the Philips Xtreme is better than Osram. Does it belongs on the reflectors or the solely on the bulbs itself.
Even on the forrum I drew an conculsion that Philips outdo Osram.
I don't know the answer to the Osram vs Philips question, but I do know that the reflectors play a major role in the quality of light.
Case in point, I have Philips Xtreme Power (+80) on my Lancer and OE bulbs on my Santro. The Santro's clear lens headlights are brilliant, while even with brighter bulbs the non-clear lens Lancer headlamps struggle.
So please keep in mind that the reflectors play a vital role in the light spread and quality.
razor4077 is offline
Old 22nd January 2008, 01:10   #1292
iraghava's Avatar
Thanked: 272 Times
Oh agree with you completely Razor just came back tonight from a long drive in my mother's Santro with stock headlight setup & the throw & spread of these lights is simply unbelievable compared to even the clear lens headlights & 100/90 bulb setup in Dhanno!
It lights up the road fantastically & makes fast driving a doodle since you can literally see more than you need to! Must say, very impressive piece of design from Hyundai.
iraghava is offline
Old 23rd January 2008, 01:55   #1293
abhibh's Avatar
Thanked: 39 Times
Altos comes with Halonix as OEM?
Yes sir alto comes with Halonix as OEM.
abhibh is offline
Old 23rd January 2008, 15:18   #1294
ram_hyundai's Avatar
Thanked: 53 Times
iraghava,i completely support this and i believe even my verna lights are not as good as the santros.and its even better than most of the cars ,sub 10 lakh bracket.the best part is that we can easily identify a santro during night drives comming in the opposite direction just by the illumination its creating,other cars having the same quality would be skoda laura,or say a double ligt merc and elantra to mention common cars.
ram
ram_hyundai is offline
Old 24th January 2008, 01:31   #1295
Are Philips Xterme Vision available in Pune City? I am not sure whether they are compatible with the Palio Stile SLX Light Assembly.
Please friends help me in this matter.
dinoo82 is offline
Old 24th January 2008, 09:10   #1296
RufRoc's Avatar
Thanked: 28 Times
It would be compatible depending on whether the Palio uses H4 or H7. I assume it's H4 in which case it would work just fine. I've no idea about availability in Pune but I haven't even seen it around Bangalore. You can order it online from AutoLamps.
RufRoc is offline
Old 24th January 2008, 13:25   #1297
Hey,your Palio Stile should be having the same bulb layout as the previous Palio,H1 for high beam and H7 for low beam. Sorry,I don't have any idea about the availability in Pune. But if its available in Pune,they should be offering it in a H7/H1 option.
No,the Palio Stile has two separate beams for low and high. So definitely NOT H4.
cya
A
Absar is offline
Old 24th January 2008, 14:09   #1298
RufRoc's Avatar
Thanked: 28 Times
Thanks for that information. Well, in that case Philips X-treme Vision bulbs won't be an option since they only come in H4 & H7.
RufRoc is offline
Old 24th January 2008, 14:25   #1299
vijit.gangwar's Avatar
Thanked: 78 Times
While doing some googling came across this Halonix site...are these bulbs any good. I was interested in upgrading for my Swift LDi.
Phoenix Lamps Limited
vijit.gangwar is offline
Old 24th January 2008, 16:55   #1300
No worries about this issue! Why not he do a combination of Philips X-treme Vision bulbs H7 for the low beam and GE H1 140w for high beam! That should give a scare and a burst of brightness
cya
A
Absar is offline
Old 24th January 2008, 21:44   #1301
cya
A
I guess they are H1s and H7(May be I am wrong) The presnt light is fine but not good enough on Highways.
I enquired about Philips Vision Plus in Pune and a dealer quoted me around 1250/- for a pair.
I think these bulbs are not that costly.
Any inputs on these guys?
Thanks.
dinoo82 is offline
Old 24th January 2008, 21:46   #1302
cya
A
Hey Absar,
That is too much light on the road........ May be I would be driving under Flood Lights. Anyways thanks for the advice.
dinoo82 is offline
Old 25th January 2008, 08:27   #1303
RufRoc's Avatar
Thanked: 28 Times
I think they are way overpriced. I remember seeing them on ebay (around 6 months back) for approx 550 bucks (for a pair). Are you trying to stick to the 55/60W? In that case check out other options like Narva, Osram & Halonix. If it's 90/100W that you want to upgrade to, then my choice would anyday be the Philips Rally bulbs. In my opinion, the best halogen bulb in that category.
RufRoc is offline
Old 25th January 2008, 14:31   #1304
Thanked: 74 Times
Originally Posted by Epic
I will be fitting Bosch H8 HIDs in my fogs.
Originally Posted by s0uljah View Post
I finally did some jugaad and installed the H7 kit in my fogs, heheh. H8 will be a perfect fit. How much is the kit costing you?
Guys please post some pics and the pricing details
Lord Lucan is offline
Old 26th January 2008, 06:22   #1305
_abhay_'s Avatar
Want to know if any one has installed a BRAKE LIGHT FLASHER on their car or bike , how to install is not an issue , want to know if it is LEGAL in india to have a flashing brake light ,
also for moderators is there ne thread to discuss the motor law of india ?
_abhay_ is offline
