Old 19th December 2007, 17:00   #1231
Thanked: 16 Times
Went ahead and got Philips Rally 130/100 fitted with Roots Relay....now its amazing daylight all around
Pani is offline
Old 19th December 2007, 21:11   #1232
hrman's Avatar
Thanked: 1,065 Times
Originally Posted by gopinathann View Post
I am planning to move from Crystal Vision to Philips Extreme. Is it worth changing it.
Does Extreme produces white or yellow light?
Can you post some pics ?
The light is whiter than the stock, but not as white as maybe Crystal / Blue vision.
And oh yes, it is definitely brighter and street legal. I had my NHC stocks changed to Xtreme power and must say the difference is very evident and it gives almost 40% better light. I was unfortunately not able to take snaps of the before. Will take some of the after and post them soon..Watch this space.
And overall is it worth it? I'll say rather than spending 1100 on the 90/100 W+ the relay, spend a hundred less and retain your original headlight fitting. I got a friend to get them for me from singapore, it cost approx 1000 INR. It's costier from Lampsonline (about 1650 INR).
hrman is offline
Old 19th December 2007, 23:48   #1233
gopinathann's Avatar
Thanked: 22 Times
Thanks for the update. I will try to find whether any of my friend can bring it from Singapore.
Waiting for your pics.
gopinathann is offline
Old 20th December 2007, 10:21   #1234
straight6's Avatar
Thanked: 302 Times
Can someone tell me where i can get a wide range of HID kits in bombay? I want H4 & H7 kits. I want to checkout the cheap ones as well as the expensive ones.
straight6 is offline
Old 20th December 2007, 13:20   #1235
ashthedivx's Avatar
Thanked: 24 Times
I have got installed best of both worlds in my sweet Optra
HID Kit - H7 - Low Beam
Philips Blue Vision 90/100 - H1 - High Beam (Proposed to be done on Saturday)
Still very happy with HID performance.
ashthedivx is offline
Old 20th December 2007, 13:27   #1236
ashthedivx's Avatar
Thanked: 24 Times
Don't you think it will damage reflector which are actually meant for 55/60 Wattage temperature. Go through the thread, you'll find many examples for the same.
Old 20th December 2007, 17:21   #1237
jkdas's Avatar
Thanked: 1,495 Times
It may in the long run. My dealer was thinking of not ordering 130s in the future as he had 3 clients complaining of meltdown.
jkdas is offline
Old 22nd December 2007, 19:56   #1238
I have installed the Phillips DiamondVision Ultimate Blue in my SX4. The performance of this bulb is better than the stock bulb but it is not very bright as expected. I bought this pair for Rs 900/-. The good part is it does not need any rely. May be i should go for upgraded version of bulb (100/90 - i had a fear of spoiling my headlight reflectors, so i had opted for DiamondVision) later for a brighter light. The vendor had both CrystalVision which is 4300K and DiamondVision which is 5000K. Does this kelvin reading mean the increase in the brightness? I know DiamondVision produces more heat than CrystalVision based on the kelvin reading but does DiamondVison produce more brightness than the CrystalVision?
DineshKanna is offline
Old 23rd December 2007, 11:40   #1239
PRADEEP KUMAR's Avatar
Thanked: 29 Times
Pls read through this thread.You have enough updates to prove that 100/90 is any better than+60% versions of 60/55 and has to be used with relys and the works.I have used this setup in all my cars from M800/bolero/esteem/SX4/SCORPIO without any damge so far.
PRADEEP KUMAR is offline
Old 25th December 2007, 11:04   #1240
Thanked: 22 Times
I have Crystal Vision in my SX4, though its brightness is more than Blue Vision, I am not satisified with it. Planning to go for Philips x-treme 60/55 +80% more light.
Old 25th December 2007, 15:06   #1241
Thanked: 408 Times
Is Xenon bulbs RTO approved?
Hi, I have a question regarding Xenon lamps. Are the Xenon lamps RTO approved in Karnataka? Around a year and a half back(I guess), someone told me that they are not approved by RTO and police are catching cars with such headlamps. Any idea on this one guys?
Btw, Am using 100/90 halogens on my Swift with the cutout. Any wiring or cutout changes when I change to Xenons?
Awaiting you reply guys. Thanks in advance!
blue_pulsar is offline
Old 29th December 2007, 14:59   #1242
johy's Avatar
Thanked: 633 Times
Good brand fog lamps
I am looking to change my fog lamps in my Wagon R - stock location. The current ones are lame. Which is a good company to look for. Philips make a lot of good bulbs for headlamps, but I think it is a little difficult to get good stuff for the fogs. Any suggestions?
johy is offline
Old 29th December 2007, 17:11   #1243
Epic's Avatar
Thanked: 1,012 Times
Hi guys,
Has anyone tried out the Osram Nightbreaker? Ive been told that they are around 90% brighter than conventional bulbs but never experienced them yet. What is the colour temperature of these bulbs?
Epic
Epic is offline
Old 29th December 2007, 17:15   #1244
arpandiv's Avatar
Thanked: 62 Times
I would not recommend Fashtek, me and my friend have purchased 4 kits from Fashtek(over a few months) all kits have some issues or other.
Such as :-
Bulb loosing intensity after prolonged use(10,000kms)
HID stops working sometime(arbit)
arpandiv is offline
Old 2nd January 2008, 09:17   #1245
kARTIK IYER's Avatar
Thanked: 15 Times
Bumper lamps
I own a scorpio and have fitted standard Lumax lights on my bumpers , It really is not of great help and light thrown is average and is now use as a additional light . ( i do not want to call it Fog lamps as they are not but is the one which comes factory fitted .
Can you suggest a good bulb that i can replace this with current ones and what will be cost and any other impacts apart from the positives of better light throw .
Regards.. kat
kARTIK IYER is offline
