Old 29th October 2007, 19:44   #1021
horsepower's Avatar
thank you simply_sunny001 and suman for the information.
horsepower is offline
Old 29th October 2007, 23:30   #1022
This question would have been asked number of times. I'm aking again & need a suggestion:
I want to replace my Optra Royale's company fitted lights (including fog lamps) with a white light. I don't wanna go with the cheaper version.
1. Whats the recommendation?
2. What various options do I've along with their prices?
3. Any contact person in Gurgaon?
4. What do you think about HID kit from Bosch or Hella? Hos good & whats the cost?
Thanks,
Vik
rendezvous is offline
Old 30th October 2007, 18:28   #1023
guys...i have got a quote for Bosch Low beam HID for rs 10,500 for honda civic. is it worth it or i can get it cheaper. is it advisable to go for Low and high beams or would a low beam be just fine.
sanchits is offline
Old 30th October 2007, 18:30   #1024
Akshay1234's Avatar
Thanked: 12,914 Times
it depends which car its for. if its for a civic then just low beam will be fine. but make sure you change your high beam to a white bulb also.
Akshay1234 is offline
Old 30th October 2007, 21:14   #1025
harjeev's Avatar
Thanked: 296 Times
is it possible to fit HID's for low beam and white lights for high beams? I mean how could 2 diff set of bulbs be installed in the same headlight assembly.
harjeev is offline
Old 30th October 2007, 21:43   #1026
Akshay1234's Avatar
thats because the civic has separate bulbs for low and high beam.
Old 31st October 2007, 12:49   #1027
simple bro, just buy Xenon HIDs from some good company like philips. the bulb size would be H4. make sure you get 6000k xenons.
Thanks Mate. Would fitting these upgrades require any change in electricals?
ot - you have an a6 3.2? ive driven one and its mighty quick.
Yeah it is a fast car but the the real deal is S6 5.2 FSI Quattro. Hopefuly will think about it when changing the existing A6
no_limit is offline
Old 31st October 2007, 16:38   #1028
Akshay1234's Avatar
forget about that. the rs6 is out now.
Old 31st October 2007, 19:48   #1029
harjeev's Avatar
Thanked: 296 Times
thanks man. I was always confused as I had put 100/90 in my accent and thought of putting HID in my Optra. But as there are 2 different set of bulbs in each of the headlight assembly I was always keeping myself back cauz of the cost factor.
Now please guide me if I put HID low beam in place of one set of bulb and normal 100/90 in lieu the high beam, and as we know the normal bulb has both the high and low beam. What will happen when I am driving on the low beam? Will only the HID glow or the low beam on the 100/90 will also glow. Please advise?
harjeev is offline
Old 31st October 2007, 20:01   #1030
Akshay1234's Avatar
for your optra the low beams are of bulb size H7. get HIDS for these. you will get decent quality HIDs for around 6-10k. for your high beam of bulb size H1 get philips crystalvision, bluevision or diamond vision whichever matches with the HIDs that you buy. make sure you get 6000k HIDs.
Old 31st October 2007, 20:08   #1031
harjeev's Avatar
Thanked: 296 Times
Thanks for the info. Will I need to attach a relay along with the philips H1 bulbs? I understand that HID come with complete packing and there is no need to attach any relays etc
harjeev is offline
Old 31st October 2007, 20:18   #1032
Akshay1234's Avatar
the HIDs come with everything. if you go for 100/90w H1 bulbs then you will need a relay and cutout. and remember only buy 600k HIDs. 8000k and 10000k are less bright.
Old 31st October 2007, 20:50   #1033
hrman's Avatar
Thanked: 1,104 Times
Guys, I ve just got my hands on a set of Philips HP+ 60/55 H4 Bulbs. Any idea what these are? I had asked a friend to send me Xtreme plus and he has sent me HP+ without the cover. I have asked him about this as well. I wanted to know before he replies .. Was curious.
hrman is offline
Old 1st November 2007, 13:14   #1034
harjeev's Avatar
Thanked: 296 Times
I would like to change the fog lamp bulbs on the tata safari (EX) from stock to white light. Could anyone please tell me the specifications for the company provided lamps. Secondly till what high wattage could I go without burning the company fitted fog lamps assembly.
harjeev is offline
Old 1st November 2007, 13:56   #1035
ashthedivx's Avatar
Thanked: 24 Times
Thankx for sharing the info... A Wild Guess... What if we'll try to do it either way i.e. HID in HIGH Beam and Philips for LOWER Beam... ?? Will the lighting me more effective or not ??
ashthedivx is offline
