Old 28th May 2007, 22:58   #421
razor4077's Avatar
Thanked: 299 Times
Originally Posted by s0uljah View Post
Hmmm, I assumed it would have a lower throw and hence not be as bad as xenon headlamps. You faced fogs or regular lamps
Fogs. Have seen a few more people with such setups. Ended up cursing all of them
razor4077 is offline
Old 28th May 2007, 23:12   #422
nikunj_cal's Avatar
Recently i put fog lamps in my Swift Ldi , although he did not cut any wires to fit the same , he did peel part of it , will the same void warranty ??
nikunj_cal is offline
Old 28th May 2007, 23:35   #423
shuvd's Avatar
Thanked: 7 Times
@ razor - Uh-oh. I was planning to get these for the Silver Bullet
Guess I'll get the Phillips Crystal Visions instead.
shuvd is offline
Old 1st June 2007, 17:01   #424
hi guys.
i bought a xeta 6 months back.i wanted to put a set of strobes on my car.was also thinkin of putting led's under the car.
1)just wanted to know if i do the above things will my car's warranty become void??
i mean will the service people create any problem?
amar_y is offline
Old 2nd June 2007, 13:54   #425
badboyscad's Avatar
Thanked: 479 Times
guys,what are HID lights?? can i get them for my ride(scorpio)?? what about the cost and availability in chennai?? i've seen a few skoda's in my city with a bluish white headlights..are those HID?? suggest the appropriate light bulbs for the scorpio..
badboyscad is offline
Old 2nd June 2007, 15:20   #426
BUSA's Avatar
Thanked: 21 Times
HID - High Intensity Discharge
BUSA is offline
Old 2nd June 2007, 15:47   #427
Thanked: 305 Times
yes they are HID the skoda laura has it as stock....here you can read about it here...
High-intensity discharge lamp - Wikipedia, the free encyclopedia
Headlamp - Wikipedia, the free encyclopedia
low_bass_makker is offline
Old 2nd June 2007, 17:18   #428
cheap_deal's Avatar
please get projectors if you plan to get a HID conversion. im just tired of getting blinded by fast and the furious honda civics and jettas with cheap HID kits in stock headlamp housings. should get an 18 wheeler and run them over twice!
cheap_deal is offline
Old 2nd June 2007, 21:19   #429
badboyscad's Avatar
Thanked: 479 Times
guys , tell me where can i get HID s for the scorpio in chennai??? and should i have to change the stock headlight domes?? any ideas about the pricing????..
hey cheap_deal, what are projectors???
Old 3rd June 2007, 15:38   #430
Wanted Fog lamps for my Scorpio. The workshop is giving Lumax (55W) for around Rs2300. Wanted to check if there are other options available. The workshop guy was (obviously) recommending these instead of Hella which he says is 100W and could put additional load. Please share opinions. Thanks
thisispb is offline
Old 3rd June 2007, 21:23   #431
razor4077's Avatar
Thanked: 299 Times
This is an extremely informative thread, but to be honest, I'm more confused than informed right now.
I want to improve the lighting on my Lancer headlamps (H4 I believe), and have narrowed it down to the following:
1. Philips X-treme power (+80%) 55/60W
2. Philips Vision Plus (+50%) 55/60W
3. Philips/Osram 90/100W with relay, wiring harness & ceramic holder
Ideally, I would like to go for #1, because it's the easiest to implement and the most effective. But, are these available in India? And how much for a pair?
#2 - also easy to implement but lesser light
#3 - light as good (if not better) as #1, but installation more complicated. Which brand/model to go for?
An additional factor to consider - I would like to smoke/tint the headlamps slightly, to complement the black colour of the car. Keeping this in mind, which option would be ideal? (Note:no Xenons/HID)
I drive mainly in the city, but there are quite a few badly lit stretches in my commute, so let's assume that I need some quality lighting.
Thanks for your inputs!
Old 3rd June 2007, 22:28   #432
tsk1979's Avatar
Thanked: 22,924 Times
Philips extreme power is supposed to be the best, but only if you can get originals. More than half of philips bulbs in the market are fakes. The workmanship gives away.
IF you can't get that the Osram silverstar(+50%) is the next best option
tsk1979 is offline
Old 3rd June 2007, 22:54   #433
razor4077's Avatar
Thanked: 299 Times
Will the +50% illuminate well with a bit of smoking/tinting on the headlamps?
And, any idea how much the X-treme power costs in India? A pair comes for above 1600+ in UK (after converting from GBP). Read somewhere that bulbs are normally cheaper here...
Old 4th June 2007, 00:10   #434
tsk1979's Avatar
I doubt you will find extreme power in India, atleast not genuine ones
tsk1979 is offline
Old 4th June 2007, 00:26   #435
razor4077's Avatar
Thanked: 299 Times
@tsk: thanks... i'll hunt around a bit, maybe give the Philips rep here a call. will post the prices/availability if i find out.
and, sorry i'm repeating myself... but do u have any idea about the effect of tints?
