Originally Posted by fine69 I am currently driving with stock headlamps on my swift ldi and had bought off the regular fog lamps too. However, now i wish to upgrade both. Headlamps - planning for Philips 100/90 or 100/80 and would try to restrict the usage on highway driving only so that
1. they last long
2. don't blacken the headlamp cover in the front with excessive usage Foglamps - the foglamps should replace my city driving in nights and if at all I use the headlamps it should strictly be on low beam and for a little time.
now from what I have researched and searched over t-bhp I have a few questions:
1. I understand that I need to purchase (a) philips rally 100/90 bulbs (b) relay - would hella 40 amps be a good choice? (c) ceramic holder - any brand? (d) anything else that I missed?
If not a good place in delhi/ncr where I could procure all these items from?
2. Fog lamps in Maruti are H8 type, right? What kind of power am I looking at in the fog lamps that I purchase so that they somewhat replace headlamp usage in city driving? Where would I be able to procure these powerful H8 type foglamps in delhi/ncr?
3. Are foglamps adjustable so that they provide focused light which is enough for city driving?
4. Would separate hella-type relay be required for these foglamps too if I go above a certain wattage?
5. Does 100/90 really blacken the headlamp insides? |
Also branded wires ![Stupid](https://www.team-bhp.com/forum/images/smilies/Sign stupid.gif)
Make sure everything stand up to the quality. Ceramic holder is another key component.
I would suggest you not to go for powerful fogs since you already have powerful headlights. You can go in for the OEM fogs. They are quite good for city drive.
No. They are not.
Yes. (I think so).
This is a common problem that many have reported. I had personally used higher rated bulbs in my Swift but that was just for 1 month or so. Then switched over to HIDs. If you use it during a long run, it will blacken your headlights. Also, the plastic coating on the headlamp unit will start to peel. This is because a lot of heat is trapped inside the unit. I felt the difference.
I would suggest you to go for HID if you can stretch your budget.
I have posted my car's light output some few messages back.
Cheers.! |
