Old 2nd November 2010, 12:49   #1
k.chandiok's Avatar
upgrading Punto Petrol to T-jet 1.4
Hi Experts,
Fiat has launched the T-jet and I've heard it is the best petrol available in it's segment. I will go in for a test drive this weekend and see for myself how much fun it is.
I've heard the only important change is addition of a turbocharger. I want to know if I can upgrade my 1.4 petrol Punto emotion pk to the T-jet by getting the turbocharger installed to my engine.
Please help.
Thanks,
Kshitij
k.chandiok is offline
Old 2nd November 2010, 13:02   #2
GreenDay's Avatar
Thanked: 116 Times
The T-Jet is not a FIRE engine with a Turbo! Its a all new engine, which is imported for use in Linea in India.
Instead you can think of buying a T-Jet itself!
GreenDay is offline
Old 2nd November 2010, 14:41   #3
k.chandiok's Avatar
Really? The displacement is exactly same so i thought that Fiat has just added the turbocharger. I still think it is not a completely new engine...a turbocharger and new modifications thats it.
Old 2nd November 2010, 16:45   #4
CPH
Thanked: 36 Times
The T-Jet is a FIRE engine. The block is identical with the 1.4 normally aspirated engine, which is a bored out 1.2 block.
@ k.chandiok - nfortunately it is not as easy as just bolting on a turbo. You nee to sort out the oild and water feed for the turbo. The inlet manifold needs changing. Additional sensors need wiring in. you have to clone the ECU or go stand alone. The exhaust manifold needs changing as well as the down pipe to make it work.
The lobe separation angles on the cam have to be changed and the pistons, conrods and crank has to be chanegd to the turbo ones. The normally aspirated moving parts aren,t strong enough for the torque.
To sum it up it is doable, but by the time you have done it you will have spent more money than selling your car, paying the difference for getting a new T-Jet and do some performance tuning.
also you will have no warranty
Last edited by GTO : 4th November 2010 at 10:57. Reason: CPH, please avoid mentioning that you're a professional tuner in every thread!!
CPH is offline
Old 3rd November 2010, 12:55   #5
k.chandiok's Avatar
ok so net net I cannot upgrade my punto to T-Jet.
What other options do I have to make my engine more fun while not compromising on the fuel economy?
Old 3rd November 2010, 13:43   #6
CPH
Thanked: 36 Times
A proper AIR is a good start. Stay clear of K&N. Add a re-map specifically for the AIR.
The re-map with the right AIR will give you about 15% more peak power and oodles more bottom end torque and it will set you nback about 27k for both together.
Back box will give you around another 3bhp when done correctly.
Further modifications are possible but it will get expensive.
CPH is offline
Old 3rd November 2010, 14:30   #7
amoghchaphalkar's Avatar
Thanked: 718 Times
Very few. A remap at the most (as CPH has already suggested). But then that is going to set you back by a few thousands. You could as well save that money for fuel and change the way you drive (ignoring the fuel economy) to derive more fun from the engine !!
Have you tried revving / redlining the 1.4 ? It is immense fun !!
amoghchaphalkar is offline
Old 4th November 2010, 10:58   #8
Thanked: 321,356 Times
Yes & No. Same block, but new head + internals (as told by Fiat India at the launch).
GTO is offline
