Old 20th May 2014, 22:44   #301
sabsubs's Avatar
Thanked: 327 Times
Originally Posted by Red Liner View Post
I have been told that the ff50 provide a throw off 70 meters. Is that good enough? I could not get the numbers for 700ff. The 3003 extreme series are rated for an insane...hold your breath 190 meters! They also cost a cool 11k!
Hi Red Liner, I think 70 meters is very less. What do you think? I also read that FF50 is just a fog lamp. So would it be suitable for highway drives? Let me find out more details for 700ff.
sabsubs is offline
Old 21st May 2014, 06:30   #302
akshay4587's Avatar
Thanked: 4,547 Times
Re: The Hella Experience - 500 FF
Great, that seals it. Am getting the 50FF. Will still wait for your pictures this evening and get suitably wow'ed
Now to find these things in Bangalore.
Didn't get a chance yesterday.
Will put them up in a day or two.
akshay4587 is offline
Old 21st May 2014, 06:41   #303
Red Liner's Avatar
Thanked: 18,442 Times
you should see this:
The 700ff are pencil beams. The 50ff are not. They are more spread out and give you instant near visibility of the road and the corners. My biggest issue on highways has been my inability to see what is 30 meters ahead me under the bright glare of oncoming vehicles when they just pass me. Call them a 90/100 kit on steroids.
Last night in the city, my stock headlamps were absolutely ineffective. These aux lamps would have been very handy in the city, but wouldn't have killed oncoming cars or bikers.
700ff will scare oncoming violators. Will also attract more attention when parked. Is made in India and is priced at 3500 bucks. Honestly I hate these things.
50ff is fully imported from Germany and is priced at 7k. Is inconspicuous and does not attract attention. Is for near sighting and not for long distance throw. These are not pencil beams. See video above.
I would really like to see akshay4587s snaps to see if my thinking is correct.
Waiting with impatience! :-P
Red Liner is offline   (1) Thanks
Old 21st May 2014, 10:11   #304
sabsubs's Avatar
Thanked: 327 Times
I came across 2 variants of FF50.
a. http://www.myhellalights.com/index.p...ies/ff-50-fog/
b. http://www.myhellalights.com/index.p...0-series/ff50/
One is FF50 and the other is FF-50-Fog. These two have different beam patterns. The second one has pencil beams and the first one is more spread.
If you read the specification, the beam pattern for the first is Fog and the for the second is driving. Is there a difference in FF50. Which one are we looking at now?
@akshay4587, which one did you install on your car.
sabsubs is offline   (1) Thanks
Old 21st May 2014, 10:31   #305
Red Liner's Avatar
This is the one we're looking at for sure: http://www.myhellalights.com/index.p...0-series/ff50/
Because, thats the only one that comes in Blue! And only Blue's imported into India. Just an assumption now. A good way to reconfirm is to use the part number: 008283861
Now that you say this, I think the BMW is running on the 50FF Fog's and not the regular 50FF!
Picture 1: This is the lighting pattern of the 50FF.
Picture 2: Pattern of 50FF Fog (which is what the BMW has got I think)
Picture 3: 700FF pattern.
The principal issue with the 700 FF is that it will be mounted on the bumper and WILL affect oncoming traffic. Switching on/off these lamps every 5 odd minutes is not something I want to do on the highway.
The 50FF's will sit extremely low, within the bumper housing at about 1 foot from the ground, and hence will only light up the road and should not affect oncoming traffic.
I am also toying with the idea of throwing away the supposedly crap Hella wiring harness and relays which come appropriate for the 55w lamps, and get a 90/100 compatible Root's wiring harness and relay and upgrade to 100 watt bulbs for the 50FF. Would like to know if this should be okay.
Red Liner is offline   (2) Thanks
Old 21st May 2014, 11:14   #306
Red Liner's Avatar
Okay, so apparently the roots relay will not work with these FF50's. Gawd. Let's see if the wiring and relays can handle the 100 watt bulbs. Maybe I'll even drive it stock for a while and see what happens first.
Old 21st May 2014, 22:19   #307
akshay4587's Avatar
Took a few pictures of one of the 50FF's the one on the driver's side is out of focus.Will fix it over weekend.The Hella Experience - 500 FF-imageuploadedbyteambhp1400690842.398888.jpg
Sent from my iPhone using Team-BHP
akshay4587 is offline   (2) Thanks
Old 21st May 2014, 22:35   #308
sabsubs's Avatar
Thanked: 327 Times
Thank you very much akshay4587. The light throw is very good. I will be mainly doing highway drives. So is FF50 more suitable for highways than 700FF? I am planning to get FF50 installed on Saturday so if you could confirm by then it would be very helpful. Thanks.
sabsubs is offline
Old 21st May 2014, 23:30   #309
batterylow's Avatar
Thanked: 957 Times
I am also planning to install 700ff this weekend. Have been quoted 6200 for the lights and the wiring, the price does not include the clamps that have to be fabricated to mount the lights (650 rs max). So I should be looking at a total bill of close to 7 thousand including a pair of 100W osrams. My purpose is also highway drives so does 700ff make sense over 50ff?
batterylow is offline
Old 22nd May 2014, 08:31   #310
akshay4587's Avatar
I have not used 700FF,but got 500FF on my Linea(Check few pages back you will find pics).700FF is just the bigger cousin of 500FF.On my highway drives i have found 500FF(with stock bulbs),just about adequate,nothing exceptional.
50FF's are way better than 500FF.
akshay4587 is offline   (1) Thanks
Old 22nd May 2014, 13:15   #311
batterylow's Avatar
Thanked: 957 Times
Hello Akshay, from the pictures you have posted it looks like the 50FF mimic the spread of the high-beams. Would it not be redundant ? Please shed some "light".
Thanks in advance.
BL
Old 22nd May 2014, 14:09   #312
akshay4587's Avatar
Thanks in advance.
BL
Not in my case,since in the thar the headlamps are positioned high up.
Once i switch on all the lights,it pretty bright.Will try to post the image.
Old 22nd May 2014, 14:31   #313
batterylow's Avatar
Thanked: 957 Times
That would be very kind of you akshay.
Thank you.
Old 1st June 2014, 22:00   #314
Red Liner's Avatar
Hella 50ff alone switched on. Am pretty stoked with these lights.
Old 2nd November 2015, 17:32   #315
Jaguar's Avatar
Thanked: 2,719 Times
Reinstating an old thread. I dropped one of my 500FFs (yes dropped while removing it from the car) and broke it. Does anyone know where to get a single piece replacement? Even used one would do.
Or else, if anyone is looking for a single piece of 500 FF, they know whom to contact.
Jaguar is online now
