Old 7th March 2025, 21:15   #181
sagarpadaki's Avatar
Thanked: 6,791 Times
Amazon basics washer fluid
I am using Amazon basics washer fluid for the past 1 month. Earlier was using Proklear washer fluid for past many years before this
I find the product to be excellent in terms of cleaning the grime and oil film from the windshield. The cleaning ability is a couple of notches better than Proklear.
I would recommend this. One observation is that mentioned dilution ratio is too strong. IIRC the bottle says 1:50. I found it too soapy. 1:100 is ideal.
https://amzn.in/d/6USI1Ut
sagarpadaki is offline   (2) Thanks
Old 8th March 2025, 15:26   #182
Thad E Ginathom's Avatar
Thanked: 29,941 Times
Re: Best Windshield Washer Fluid?
I like Proklear because it not only cleans but is like a glass treatment, making water bead and run away more effectively. I keep a spray bottle with some in it for cleaning the other windows.
Previously, I was using a VAG product that I would get from VW A-S-S. Perhaps it was just something cheap rebranded, but it did clean well. But now I stick with ProKlear. Anyway, long out-of-warranty, we havn't visited VW Service for quite a few years.
Thad E Ginathom is offline   (1) Thanks
Old 21st April 2025, 16:14   #183
Thanked: 27 Times
I have started using the sonax wiper fluid . Have to say that it’s extremely good compared to the previous ones I was using (mostly Maruti and Hyundai labelled ones )
sankz21 is offline   (1) Thanks
Old 21st April 2025, 17:34   #184
rajeevsulu's Avatar
Thanked: 3,037 Times
After reading Thad"s post above,I have switched to Proklear and find it very effective. My car is a Thar and the windshield is speckled with a lot of insects. Proklear does a very good job.
rajeevsulu is online now   (2) Thanks
Old 21st April 2025, 20:25   #185
trinity0114's Avatar
Thanked: 344 Times
Can Quick Detailer diluted with soft water be used as wiper washer fluid?
trinity0114 is offline
Old 21st April 2025, 21:27   #186
Thanked: 249 Times
I have spoken to a couple of service advisors of Maruti service centre, they have asked me to use tap water or Bisleri (not borwell water). They gave me some sachets of shampoo which apparently is not available in shops. This sachet can be used with soft water for washer fluid.
Linuskm is online now
Old 21st April 2025, 23:05   #187
Glad to know that you like it.
I used to use the stuff from VW, but then I stopped dealer service. I went on to an additive from Wurth, which was excellent, but very expensive and hard to find. Then, at some point, I took a recommendation from this forum (where else? ) for the Proklear.
Whilst I expect that actual glass surface treatments are way better, I like that Proklear makes the rain bead nicely, as well as being a decent cleaner.
Old 22nd April 2025, 00:25   #188
straight6's Avatar
Thanked: 305 Times
I recently started using the Sonax and its excellent.
straight6 is offline   (1) Thanks
Old 22nd April 2025, 10:32   #189
CarNerd's Avatar
Thanked: 3,146 Times
Infractions: 0/1 (5)
I don't know if it's the best but I purchased this Foxcare Windshield Washer 500ml for ₹119 on Meesho: https://www.meesho.com/foxcare-winds...00-ml/p/4k3g7t
I'm satisfied with it and remember that delivery will take longer than Amazon or Flipkart.
CarNerd is offline   (1) Thanks
