Old 14th April 2017, 18:10   #136
Jaggu's Avatar
Thanked: 17,282 Times
Re: Best Windshield Washer Fluid?
Are you sure the film you are referring to is not condensation on the windshield due to the dew? Even in rains the humid climate outside can cause such condensation on the windshield for a short while, this usually goes off if you are driving at higher speeds say 20-30 kmph.
Jaggu is offline
Old 14th April 2017, 18:16   #137
Sheel's Avatar
Thanked: 15,099 Times
Kitchen glass cleaner like Prill or Vim and or car wash in the reservoir, has worked for me.
Sheel is offline   (1) Thanks
Old 15th April 2017, 04:54   #138
intoxicangel's Avatar
Thanked: 11 Times
Yup, its not condensation, its clearly old staining that becomes visible with water on the windscreen.
Kitchen glass cleaners haven't helped, neither the car wash in the reservoir.
Infact I even scrubbed the windscreen using a sponge with just the concentrates.
intoxicangel is offline
Old 15th April 2017, 05:15   #139
drpullockaran's Avatar
Thanked: 388 Times
Originally Posted by PratikPatel View Post
I have been using washer concentrates from Ford for past 10 years. One pouch mixed with water is good for one tank full of washer fluid. Cost about Rs. 75/- per pouch. It's very good at cleaning.
The active ingredient in all windshield washers is pure synthetic edible vinegar or diluted acetic acid that is 8% by strength mixed in distilled water. The one used in the kitchen for cooking which does not leave a residue on drying.. Use one tablespoon for 1 liter of filtered water. Do not use acetone or other chemicals as it will kill rubber parts and seals. If you constantly travel behind trucks and buses with diesel soot/oil mix accumulating on your windshield then 2 tablespoons of vinegar. If you have Teepol cleaner with you then reduce the synthetic vinegar by 1/2.
drpullockaran is offline   (5) Thanks
Old 15th April 2017, 07:43   #140
GrammarNazi's Avatar
Thanked: 3,499 Times
Re: Old car - cloudy windshield when it rains
Originally Posted by intoxicangel View Post
I have seen other posts related to this, but I really haven't found a post that talks about what can be done for old oil/road films that make the windscreen quite cloudy and spotty when it rains....
The issue I am facing is purely when it rains or early in the morning when the dew needs to be wiped off the windscreen. Wiper blades are new & smooth on the surface, but there is either a really old coat of road film/oil film/staining of the windscreen which makes it extremely hard to see through the glass at such times. Otherwise, when the sun is out and the wipers are not running, no issues what so ever.
What all have I tried?
- Toothpaste scrub
- Hot water scrub
- IPA cleaning
- Glass scrub with a deep cleaning glass liquid
Results
Pretty much, just marginal improvements for a while and then we are back to square one.
My question, what can be done for something like this other than replacing the windscreen (which is an expensive affair here even with windshield cover with the insurance)?
Please try scrubbing a handful of crushed leaves of Jatropha plant on the wind-screen. I have come across many cabbies who've confirmed they use it & that it helps.
It sounds weird I guess, but please try it. AFAIK the cabbies were quite serious. Its biological name is Jatropha Curcus You can google the images of how it looks. The plant used to be easily found along the highways, but since its used for bio-diesel, you may come across a grown plant only occasionally.
GrammarNazi is offline
Old 15th April 2017, 08:31   #141
SunnyBoi's Avatar
Thanked: 4,460 Times
Looks like you have had water spots and they've etched the windshield as they're not going despite your efforts in cleaning. You can try getting the glass polished, if that doesn't work then you will have to change the glass.
SunnyBoi is offline
Old 8th June 2017, 23:57   #142
sumeethaldankar's Avatar
Thanked: 3,660 Times
I am using Prokleaner fluid in the reservoir but have noticed at night the windscreen becomes hazy. Will be emptying the reservoir and will be using plain water. Anyone had same issue ?
sumeethaldankar is online now   (1) Thanks
Old 9th June 2017, 00:02   #143
jbpanda's Avatar
Thanked: 575 Times
While the Maruti GA Screenwash which comes for ₹ 15.00 each is very good and I use it regularly. Apart from that I remember when I was a kid our driver used to rub the tobacco from a filterless cigarette on the wet glass of our Ambassador and it worked wonders. The wipers appeared to be more efficient in cleaning the glass and it substantially reduced water retention on the glass even during very heavy rains.
jbpanda is offline
Old 22nd June 2017, 12:47   #144
sagarpadaki's Avatar
Thanked: 6,791 Times
WaveX windshield washer fluid
I am using this brand of washer fluid for the past 6 months. Adding about 15 ml for a tankful of water.
Although it cleans well it causes heavy staining wherever the left over fluid runs after use on the body panels. The fluid is blue color. This causes staining. This is terrible in case of light color cars, especially white!
The manufacturer recommends 100ml for a tankful of water. This is overkill and is aimed to finish the product faster.
Overall, not recommended . There are better options.
sagarpadaki is offline
Old 22nd June 2017, 12:52   #145
adg_andy's Avatar
Thanked: 315 Times
I am using Proklear and have no such issues, although I would highly recommend the ones available at Shell outlets (Sonax if I recall correctly). They are wonderful.
adg_andy is offline   (2) Thanks
Old 18th June 2018, 20:07   #146
lemedico's Avatar
Thanked: 2,348 Times
Ordered these concentrate tablets off aliexpress.com. One dollar for a pack of 6 and free shipping.
Dilute 1 tablet in 4 litres of water for your windscreen washer reservoir.
Works good. Really cheap and so far, no complaints!
lemedico is offline   (3) Thanks
Old 30th January 2020, 12:14   #147
Thanked: 12,175 Times
Infractions: 0/2 (11)
Shell petrol bunks sell these windshield cleaners, and they're really good. Reading the fine print, I understand these are imported from Amsterdam
Sebring is offline   (6) Thanks
Old 30th January 2020, 12:56   #148
Thanked: 2,861 Times
If you don't mind, could you post the picture of the ingredients side?
mvadg is offline
Old 30th January 2020, 13:07   #149
mpksuhas's Avatar
Thanked: 8,403 Times
Can you please share the cost & dilution ratio ?
I use the Sonax (Best Windshield Washer Fluid?)one and am happy with that. However, it is bit expensive.
mpksuhas is offline   (2) Thanks
Old 30th January 2020, 15:13   #150
Oh, I'm traveling. Shall do that very soon. But, It should be available online right. I use Sonax all the time, but this was too tempting. Dilution ration is 1:10. Pricing was under 300, so it's a good buy.
Sebring is offline   (2) Thanks
