Old 21st March 2011, 15:09   #256
devarshi84's Avatar
Thanked: 213 Times
Re: Engine swap/Performance mods in Lancer
P.S. : Is it ok to give out VIN number if asked by a parts supplier?
devarshi84 is offline
Old 21st March 2011, 15:32   #257
Amey's Avatar
Thanked: 253 Times
Originally Posted by devarshi84 View Post
Is the guy who sourced the head from you based out of India?
Your help is extremely appreciated. Thank you.
I had a talk with him and he wasn't very enthusiastic about the DOHC MIVEC head swap for the 4G15 because he said, you would require a standalone to run the setup properly and gains are really not worth all these efforts.
Instead he recommended a normal DOHC swap along with some different/aggressive cams to make a nice peppy NA build.
Thats what he feels.
This guy owns a tuning shop by the name LLT Racing in Australia and specializes in Mitsubishi cars.
He is the one who sent me my Head.
Amey is offline
Old 21st March 2011, 17:44   #258
VJ_MAVRICK's Avatar
Thanked: 34 Times
Great thread Amey and kudos to your R&D and getting things done meticulously stage wise is simply an eye opener and especially for noob's like me.
I will try to flag you sometime in Pune and after more than year's hibernation your thread had brought me back to life on the forum. Cheers and as already hinted by many here this thread is like the bible of all lancer mods.
VJ_MAVRICK is offline
Old 21st March 2011, 23:45   #259
Amey's Avatar
Thanked: 253 Times
Completed some major work today. Had sent the block for sleeving.Got it back this morning and began the final Engine build in this project (Hopefully)
Here are a few pics of the bottom end getting ready,
Engine swap/Performance mods in Lancer-img_20110317_163557.jpg
Engine swap/Performance mods in Lancer-img_20110317_163603.jpg
Engine swap/Performance mods in Lancer-img_20110317_163835.jpg
Engine swap/Performance mods in Lancer-img_20110317_174202.jpg
Engine swap/Performance mods in Lancer-img_20110321_170941.jpg
Engine swap/Performance mods in Lancer-img_20110321_180855.jpg
Engine swap/Performance mods in Lancer-img_20110321_181035.jpg
Engine swap/Performance mods in Lancer-img_20110321_185124.jpg
Engine swap/Performance mods in Lancer-img_20110321_185135.jpg
Forged internals are in finally Now comes the DOHC Head.That will complete the engine build.
Will update as and when there is further progress.
Thats all for now.
Amey is offline   (1) Thanks
Old 23rd March 2011, 03:51   #260
hey,is the person in the picture trying to measure ring gap with the feeler gauge,what ring gap did you keep? p2w clearance? hone pattern? just asking for info,hope you spoke to your piston supplier for clearance and hone pattern,anyways like always best of luck with this great build,cheers,happy revving
dragger is offline
Old 23rd March 2011, 09:07   #261
Amey's Avatar
Thanked: 253 Times
The recommended ring end gap for top ring was 16 thou and for the 2nd ring was 17.5 thou.
We have kept around 10-12 for top and 13-14 for the 2nd one.
p2w clearance is around 3 thou. permissible according to Wiseco is 3.5 thou.
Amey is offline
Old 23rd March 2011, 11:07   #262
Ricky_63's Avatar
Thanked: 520 Times
Amey, each time I visit your thread & see the passion going into the build with HUGE doses of research, I am truly amazed with your perseverance and passion.
The way you are going into details may be a bible for many a people, who aspire to own or build fast/er cars but do not know where to begin.
Kudos to you, hope the net result amply compensates your effort.
Cheerio
Ricky_63 is offline
Old 29th March 2011, 00:10   #263
its good to know you were in touch with the company for details like ring gap and p2w clearance,any reason you are running tighter gaps than recommended? are you not looking to push that much boost that would require such clearances or reason's like excessive blow by? hone pattern used? anyways all the luck with this build,your sure going to have a quick car once its all done,please pay as much or more attention to the tune as you did while assembling the engine,cheers,happy revving..!
dragger is offline
Old 29th March 2011, 17:35   #264
Amey's Avatar
Thanked: 253 Times
I wont be running high boost on a regular basis.Maybe around 8-10 psi max. One of the reason for keeping conservative clearances is that I dont want excessive oil consumption.
Bottom end is ready and so is the Head. Now waiting for a few things like Tappet cover, idler pulley, timing belt, injectors, adjustable cam gears,coil packs,ignition leads to arrive in my hand.Once these are here, Will plonk the engine in.
The stuff is already in Mumbai so hopefully in a week or so, we should be able to bring her to life again.
Amey is offline
Old 4th April 2011, 15:10   #265
Amey's Avatar
Thanked: 253 Times
A few minor updates :
Ok so my engine is almost ready with the new Head installed along with forged internals.
The final engine build is nearing completion.
While we wait for a few minor parts like oil seals, we get the tappet cover painted, didnt want that dirty,used look of bare aluminum tappet cover. We also got the flywheel faced since we had pulled out the engine anyway.
A few parts also arrived, new coil packs,ignition leads,idler pulley,OE 275cc injectors.This should make my ECU happy now.
Engine swap/Performance mods in Lancer-img_4091.jpg
Engine swap/Performance mods in Lancer-img_4092.jpg
Engine swap/Performance mods in Lancer-img_4096.jpg
Engine swap/Performance mods in Lancer-img_4105.jpg
Engine swap/Performance mods in Lancer-img_4112.jpg
Engine swap/Performance mods in Lancer-img_4122.jpg
Engine swap/Performance mods in Lancer-img_4125.jpg
Old 5th May 2011, 17:45   #266
Amey's Avatar
Thanked: 253 Times
Finally !!!!!!!
Engine swap/Performance mods in Lancer-img_20110505_135146.jpg
Got the last but most awaited parcel. Received Exedy HD Clutch, Jasma Adjustable Cam Gears, Cam oil seals,rocker cover seal,Gates Timing belt. Now I can get on with finishing the final engine build and plonk back the engine.
If things go as planned, in a weeks time, the car should be back in action with a DOHC Head swap and Forged Internals done
Will keep this thread updated.
Old 11th May 2011, 00:36   #267
Amey's Avatar
Thanked: 253 Times
Almost there
Engine swap/Performance mods in Lancer-243048_10150180241705965_534770964_7610858_3525950_o.jpg
Engine swap/Performance mods in Lancer-img_20110510_130344.jpg
Engine swap/Performance mods in Lancer-img_20110510_130336.jpg
4G94 Block + 4G93E DOHC Head + Forged Internals. = 2L DOHC Engine hungry for some boost.Lol
Yeah baby!
Amey is offline   (2) Thanks
Old 11th May 2011, 01:25   #268
Born2Slow's Avatar
Thanked: 49 Times
Truly amazing work Amey. I have a question for you thou. If your planning to turbocharge the motor does it matter that much whether its a dohc or sohc regarding the engine breathing part as long as you have 16 valves, or is it that you need some flexibility in the cam timings. Sorry if the question has been asked before.
Born2Slow is offline
Old 11th May 2011, 10:47   #269
Ricky_63's Avatar
Thanked: 520 Times
Originally Posted by Amey View Post
Almost there
Attachment 543038
Attachment 543039
Attachment 543040
Yeah baby!
Wow the visuals are amazing !! It looks like a new engine - great patience & great work..so when does it hit the road ??
Ricky_63 is offline
Old 11th May 2011, 13:06   #270
gaurav_chopra04's Avatar
Thanked: 574 Times
Drool pics man, very nice built. So, time for a turbo ? what boost you plan to run this thing on.
Forged internals can take 14 PSI and above. I mean I was surprised to read RPWs details of 4G94, where it said that the stock internals can also take up to 14 PSI of boost, ofcourse depending upon intercooler and tuning and an upgraded gasket.
gaurav_chopra04 is offline
