As I mentioned earlier I have been using the remap on my fabia for last 18000kms now. Car has done 23000kms. During my second service I had made a complain of low pick up and mileage. This mainly happened coz of DPF(Diesel partical filter), EGR valve, and intake manifold choked due to carbon/soot.
Once they cleaned it during 2nd service with chemical cleaning, the pick up has improved tremendously. Much better than day one I had got the remap one. Mileage has gone high too by 15% or so.
The carbon accumulation is common with diesel cars. More so it happens often due to unburnt fuel and when you can see your car smoking under heavy acceleration. This is nothing but the unburnt fuel. With tuning box is some cars there is heavy smoke that is noticed initially. This is coz tuning box mainly changes fuel mapping to generate more power. Excessive smoke will lead to early soot/carbon.
My ECM has been diagnosed thoroughly during this process to check for errors. Luckily it has not been detected till now.
Compared to Remap a tuning box is always safer option but than everything has it's negative. Just like with remap there are chances of it being detected, tuning box there are chances of seeing excessive smoke.
There are advantages and disadvantages of whether it's remap or tuning box.
Tuning box being safer option, no doubt a remap would give better drive ability with changes to turbo boose as well. It all depends on what you looking for.
Here is a link that talks all about the VW diesel engine, their characteristics, modification, precaution and all.
The below link explains the carbon accumulation and care to be taken.
Cleaning the intake manifold of carbon build up Difficulty
I have tried both Diesel and hispeed diesel and have not noticed any change in performance. Hi speed diesel uses additives which are not healthy for PD engines. The injectors may become prone to stickiness and may be in longer run damage the fuel pump or so. I noticed more smoke coming out when used with hi speed diesel.
