Old 21st January 2010, 02:03   #406
Zenster's Avatar
Thanked: 100 Times
Originally Posted by UniqueMods View Post
nice tacho. nice to see it all worked for you. install is good and clean.
where is the oil flow sensor attached ? to which part.
UM
Well I got the Tach and Voltage Sensor connected at EVO and the Oil pressure at my regular MASS. From what the mech told me, i think it is connected inplace of the original sensor. So now the Red Indicator on the center console doesn't glow. I have to look for reading and make sure it doesn't drop or rise too much. Hope this helps.
Originally Posted by gpa View Post
Zenster,
From where did you pick up this piece? It looks really nice! Great to know that you've configued almost all the gauges to work!
Do let me know from where you picked it up in BLR, so i can get one too. Have been looking for a good tach for my Alto for months now.
Thanks in advance.
gpa
Thanks GPA glad you liked it. As the prev post says, I got it from the classifieds in Team-bhp sold to me my Hyderabad based member. It didn't work on his 3 cyl M800 so I got it and works like a charm.
All works and the temperature sensor isn't complicated just that it will take time to drill the exact hole etc for the sensor etc. Will get it done in my next service.
Well about getting a tach for you Alto, Kingofmyworld can give you more details on what he has installed and then you can look for that model. Or you can just call or visit Satya's place in Cambridge layout, Indiranagar and i'm sure he can work something out. PM me if you need his contact details.
Zenster is offline
Old 24th January 2010, 13:58   #407
anky's Avatar
Thanked: 115 Times
Just Fit wagonR or Alto vxi speedo to alto.
I have fitted wagonR vxi speedo to my alto and it has a tach and light on remainder built in no mods reqd direct fit.
anky is offline
Old 25th January 2010, 20:57   #408
Thanked: 88 Times
hey all,
I am new at this posting. Can anyone tell me if I can Fit a tacho meter on my Vista TDi? Pls do let me know!
boohooper is offline
Old 9th March 2010, 10:01   #409
devrajman's Avatar
Thanked: 118 Times
Finally.....SunPro CP7901
Finally after 6 months of wait, im getting my tachometer this weekend. Its SunPro CP7901!
Amazon.com: Sunpro CP7901 Super Tachometer II - Black Dial: Automotive
I want to try DIY install. I have Carb Zen. How difficult it is?
Any BKMs which I can follow for a proper install. Any Zen veterans here who can guide me with wiring points specific to Zen.
Thanks in advance.
devrajman is offline
Old 9th March 2010, 23:55   #410
abishek2222's Avatar
Thanked: 166 Times
I am planning on getting a voltmeter fixed into my Sierra, Auto gauge. this should be straight forward Right,or should i be looking for something different as its a diesel engine
abishek2222 is offline
Old 15th March 2010, 21:17   #411
devrajman's Avatar
Thanked: 118 Times
My Carb Zen gotta Tachometer!!
I completed the installation of Sunpro tachometer. Its 3CP7901 -3/8"
I ordered from US costed me Rs. 1800/-
My mechanic took 300 rs for installation. He was quiet clean with installation. Worked the first time I cranked the engine.
Placement is good, does not hinder vision but is at quick spot to see.
Tach is good, smooth pointer operation. No fancy colors considering its cost. However size is big enough for clear readings.
I once pumped for a sec to 7000 RPM Didn't have guts to do it again for video!
Below are couple of pics a short video.
Please let me know your feedback!
devrajman is offline   (1) Thanks
Old 16th March 2010, 12:34   #412
sumeethaldankar's Avatar
Thanked: 3,447 Times
Hi that's a really neat tacho.Doesn't seem to have a shift light but thats fine.What's the red mark at the 3000 RPM position?
sumeethaldankar is offline
Old 17th March 2010, 08:20   #413
devrajman's Avatar
Thanked: 118 Times
Thanks!
The red mark can be set at any RPM, usually to mark danger RPM or time-to-shift RPM.
Old 17th March 2010, 11:08   #414
ghostrider's Avatar
Thanked: 506 Times
Guys,
I've been trying to get an Autogauge diesel tacho fitted to my LDi for months now, with no success. The guy I bought it from couldn't do it, Four Seasons (Mumbai) couldn't do it, and MASS (Vitesse Mumbai) couldn't do it.
Anyone know someone who can do this, or has had this done?
Help would be much appreciated.
ghostrider is offline
Old 17th March 2010, 11:21   #415
Gansan's Avatar
Thanked: 5,680 Times
Where did you get this done and what was the cost? Please post pics, I want to fix it for my Alto as well!
Gansan is online now
Old 17th March 2010, 11:22   #416
Captain Slow's Avatar
Thanked: 2,095 Times
devrajman
The tacho looks really nice. Is that a carb Zen? where did you get this fixed? its time to get one of these for my trusty esteem.
Captain Slow is offline
Old 17th March 2010, 11:36   #417
devrajman's Avatar
Thanked: 118 Times
Originally Posted by Captain Slow View Post
devrajman
Thanks. Yes, its a Carb Zen. Any MASS/accessory guy can do it. Just be around inspecting the installation.
Old 18th March 2010, 17:43   #418
anky's Avatar
Thanked: 115 Times
Gansan
Hi I purchased the speedo of wagon r from market at opera house mumbai and fitted it myself . very easy no mods reqd just remove dash and clip on the new speedo. total 8 screws ... 4 fo dash and 4 of speedo.ps i have service manual so it was easy.
anky is offline
Old 24th March 2010, 00:00   #419
nc1bad's Avatar
Thanked: 17 Times
hi guys, i am trying to install an aftermarket tach all by my self, i think 13BB unit runs on dual coil so i need to connect the tach to the ecu signal wire. If anyone has installed a tach in their MPFI Esteem i would appreciate any pics or guidance. thanks
nc1bad is offline
Old 24th March 2010, 07:59   #420
b_ambat's Avatar
Thanked: 113 Times
Hi friends, anybody tried fitting a non alternator tachometer for diesel car.
b_ambat is offline
