Old 22nd September 2009, 13:10   #331
devrajman's Avatar
Thanked: 119 Times
So what is our next best option. Im looking for tacho in max 1500/- price range.
devrajman is offline
Old 22nd September 2009, 13:15   #332
bigmoose85's Avatar
Let me know once you install it, Devraj.
bigmoose85 is offline
Old 22nd September 2009, 13:18   #333
gpa
gpa's Avatar
Thanked: 345 Times
The next best option is to get a tacho outside and fit it as a DIY project. Amit has posted a detailed way to get it fitted on the Alto in another thread and its fairly easy if you follow the wiring.
Am not sure if you will get a reliable brand in the ~Rs. 1,500 price bracket why not stretch your budget by another Rs. 1,000 and get a good tacho?
Perhaps we can work together to source out a good brand in Bangalore if you are keen.
By the way, don't you have a Zen?
gpa
gpa is offline
Old 22nd September 2009, 13:33   #334
devrajman's Avatar
Thanked: 119 Times
2.5K is slightly heavy on pocket. Im not looking for something too fancy. I need a dial that tells me numbers
Yes. I have a carb Zen :-)
Old 22nd September 2009, 13:47   #335
lilMonSter's Avatar
Thanked: 33 Times
alto tacho
here is a tacho i have in my alto. cast me about 4000 with the shift light. although it does not require a shift light as the meter changes color and beeps at the shift point you set for it. try looking for something similar for your alto.
attaching a few pictures.i dont really like the huge rpm meters. i think they are too big for an alto. sorry about the image quality, phone camera.
bOoM!
lilMonSter is offline
Old 22nd September 2009, 14:25   #336
bigmoose85's Avatar
Hey. That looks cool, man. devrajman and gpa can try this.
Old 22nd September 2009, 14:36   #337
gpa
gpa's Avatar
Thanked: 345 Times
Alrighty then, you can settle on a slightly lower one. I think the Autoguage ones come in at ~/<Rs. 2,000 and are fairly good!
The problem with cheaper ones is that they konk out fairly early and you have no choice but to replace them.
gpa is offline
Old 25th September 2009, 13:29   #338
amit_mechengg's Avatar
Thanked: 2,263 Times
go for autogauge 2" without shift light. costs around 1500 rs
amit_mechengg is offline
Old 25th September 2009, 21:52   #339
archat68's Avatar
Thanked: 642 Times
You can Pricol made no-frill tach in around 1K. They are available for both 3 and 4 cylinder cars.
archat68 is offline
Old 25th September 2009, 22:09   #340
Thanked: 96 Times
Originally Posted by mclaren1885 View Post
to all you guys out there..how much will the tachos from autometer the one with the gear shift indicator cost..i think the ones i found out from a few shops are highly overpriced..so any idea of their estimates..and is it ok to put neons for zen because the shopkeeper says due to the bad roads it will easily break..any methods to prevent the breaking and how much will these neons cost..
instead you can go for LED strips. Consume less current and long lasting.
gaddiwale is offline
Old 1st October 2009, 00:02   #341
motionfreak's Avatar
Thanked: 68 Times
Installed this tacho in my Palio
AutoGauge AGTASMSWL270-60 60mm tachometer 0-10,000 RPM
Wiring
white : -ve of induction coil
black : ground black wire
red : ignition switch ( key) purple-red wire
orange : +ve of battery Purple-yellow wire
white : instrument light switch ( parking/H-light switch) yellow black wire
Check out the video. download the attachment and remove the " .doc" from the file name extension.
motionfreak is offline
Old 1st October 2009, 10:17   #342
recshenoy's Avatar
Thanked: 256 Times
@motionfreak, how much it costs?
recshenoy is offline
Old 1st October 2009, 18:57   #343
Thanked: 68 Times
I bought it from a friend for 1.5K. don't know about the new one. may be 3K.
Old 6th October 2009, 16:18   #344
motomaverick's Avatar
Thanked: 989 Times
Hello all, I am pretty new to cars, I have recently purchased a zen lx 2004 model. After driving around in bikes for the past 5 years got used to tachometers, hence, was looking for a cheaper solution for a add-on tacho.
How much will a ritz or a-star tacho cost? I am in bangalore, which place will be best to perform this mod. I was planning to place it just besides to the instrument console on the left side, i.e. between the ac vents and instrument console so that the viewable area is not hampered.
motomaverick is offline
Old 21st October 2009, 02:06   #345
thegame's Avatar
I need to install a tachometer in my Spark. Its a four cylinder engine, and I know for a fact that none of the variant in Spark comes with a the stock tacho.
Has anyone had any experience on installing an after-market RPM meter in Spark? How easy or difficult is it? I can source a tacho easily in Bangalore. I want to know how to install it in Spark.
thegame is offline
