Old 18th February 2009, 20:05   #211
badboyscad's Avatar
Thanked: 483 Times
ok guys, finally got a glowshift tacho for the alto, now i need some help regarding its installation.
Doubt:
The instruction says that the green wire should be connected to tacho signal. My doubt is, should it be connected to ECU or somewhere else such as the ignition coil?
Please throw some light.
badboyscad is offline
Old 18th February 2009, 20:18   #212
amit_mechengg's Avatar
Thanked: 2,263 Times
finally u got the TACHO. the wiring diagram is somewhat wrong according to me. it says put the yellow to the positive of that battery.
connect as per my guidelines and it works perfect.
1. First disconnect your battery terminals.
2. Connect the Black wire to a suitable ground. there are many grounds in engine bay and dashboard.
3. Connect the Red wire to the ignition switch i.e on accessories mode. if you connect directly to the battery the tacho always remains on and the light in the tacho meter will always glow.
4. connect the GREEN(signal wire) to he negative of the ignition coil which is there in the engine bay. Please see the pics in earlier posts.
5. Connect the Yellow to the parking light signal. i.e when u put on the parking lights the backlights on the tacho glow.
Happy revving.
i hope this clears all your doubt.
P.S - My mechanic was very clever enough not to slice a single wire. he got all the connections from the fuse box under the dashboard on the drivers side. i was very happy with his technique.
amit_mechengg is offline
Old 18th February 2009, 20:35   #213
badboyscad's Avatar
Thanked: 483 Times
@amit : thanks for the quick reply. Please point out the negative terminal in the below pic.
And please post of a pic of these connections, if possible.
Old 18th February 2009, 21:07   #214
please check the circled red screw. this is negative of the coil. i will try to post the pics. but the thing is even i havent seen the connections below the dash. the mechanic showed great patience by lying on his back and going deep inside the dash.
Old 20th February 2009, 18:42   #215
badboyscad's Avatar
Thanked: 483 Times
Installed the tachometer this afternoon. Works nice and looks nice too. I have set the shift light at 2500rpm for now. Special thanks to amit for answering my queries.
Old 20th February 2009, 19:22   #216
looks nice. i too wanted a black color. which make is it. i have autogauge written on the front dial. have u drilled any holes in the dash?
Old 20th February 2009, 20:32   #217
badboyscad's Avatar
Thanked: 483 Times
It is a Glowshift gauge - Tinted 7 Color 3 3/4 Tachometer w/ Shift Light
No holes were drilled, the electrician stuck it to the dashboard using some good double sided tape, it is really strong.
Old 20th February 2009, 20:41   #218
the whole construction and the dial and the rpm setter exactly looks like autogauge. how much did the glowshift cost you. i got the autogauge for 2300
Old 20th February 2009, 20:50   #219
badboyscad's Avatar
Thanked: 483 Times
$54 which translates to around rs:2600 . The tacho was bought in the US.
Old 20th February 2009, 21:23   #220
Tacho really looks cool, I guess the same can be fitted in a M800? Am I correct? Please do let me know. Also, the procedure would ne the same.
Any gusses where to get this tacho in Chandigarh and how much wud it cost?
Also badboyscad, Does this tacho mentions that it is built for a 3 cylinder engine? Or it simply gets fixed on any number of cylinders i.e 4,6,8 ???
After going thru all these posts I have started to die to get 2 of them, one for my M800 and other one for my Alto.
911turbo is offline
Old 21st February 2009, 00:03   #221
badboyscad's Avatar
Thanked: 483 Times
I guess it can be fitted to the 800 too, because both are 3 cylinder engines.
No idea about 3 cylinder tacho availability in chandigarh
My tacho has an adjustable switch for 2,3,4,6,8 cylinder engines. I 've set it to 3.
Old 18th March 2009, 02:12   #222
After lot n lot of research in the city ...I finally got to know a dealer who is selling an autoguage tacho for 2K, but without shift light... Is it worth the price ????
Plz advise...
911turbo is offline
Old 18th March 2009, 11:03   #223
yatinchoubal's Avatar
Plz advise...
what is the size of the tacho?
If the size is 3 1/2 inch, and without shift light, then it costly.
General price range for tacho of same size with shift light and seven color display would cost you in the range of 2100-2400
yatinchoubal is offline
Old 23rd March 2009, 22:16   #224
Its 3 3/4. but he says with shift light + single color display for arnd 3.5K. Im not planain to spend that much, but I'm very keen to get it.
Please advise me some dealer or retailer in Delhi who sells Auto Guage or Glow shift tachs and also what would be the approx cost.
911turbo is offline
Old 23rd March 2009, 22:56   #225
Can anyone help me getting it at a less cost..
911turbo is offline
