Old 25th August 2008, 13:32   #136
abhik's Avatar
Thanked: 13 Times
Your in Gurgaon itself just drive down to his workshop, i think he has some of em up for sale, go grab one.
abhik is offline
Old 25th August 2008, 14:17   #137
Thanked: 32 Times
There is already a l o n g thread on this:
http://www.team-bhp.com/forum/modifi...chometers.html
hrag is offline
Old 28th August 2008, 23:19   #138
sumeethaldankar's Avatar
Thanked: 3,664 Times
Ok Guy's here's the pics of my tacho.Sorry about the poor quality night pic.Wonder what the button in the center is for doesnt seem to change the color as somebody on the thread said.
sumeethaldankar is offline
Old 28th August 2008, 23:23   #139
ibm_jennifer's Avatar
Can I install one more Tacho with Shift light in MY SAFARI(Its already having a Pricol)
ibm_jennifer is offline
Old 29th August 2008, 10:41   #140
abhik's Avatar
Thanked: 13 Times
Ya you could but it will just be for show! Why do you want another one anyways?
abhik is offline
Old 29th August 2008, 10:44   #141
abhik's Avatar
Thanked: 13 Times
Does the bright red glow at night hamper night driving? The bright red would be blaring on your face at night and might be a distraction after some time.
There are similar looking tachos which are smoked out.
abhik is offline
Old 29th August 2008, 11:14   #142
c10
c10's Avatar
Thanked: 9 Times
Sure, You can !!
JAW Shift Lamp - assist's you shift on the RPM you set..(This does not require a Tacho, google for image)
Best part is, with this product you can set the glow lamp to different RPM's on different gears.. &
I got this from HK a month ago & installatation took few mins..
Will post the Pic soon..
c10 is offline
Old 29th August 2008, 11:58   #143
Thanks Friends. I planned to buy a Digital Tachometer with Shift light.
So If I install the new Tacho, Will my Old tacho work? So I will have two tachometers - one digital & one analog(just for show!)
Old 29th August 2008, 12:33   #144
im_srini's Avatar
Thanked: 491 Times
Hi Sumeet, if on pressing the button in question, the needle swings to a particular RPM - your tach has peak RPM memory recall. As it says, it indicates the highest RPM you've revved your engine to... A handy feature in case your car's shared by others (demonstrated by Robert Duvall in "Days Of Thunder")
im_srini is offline
Old 29th August 2008, 13:15   #145
abhik's Avatar
Thanked: 13 Times
Spot On! you would have 2 tachos, both working. So the add-on would just be for show.
abhik is offline
Old 29th August 2008, 19:47   #146
Nope.. nothing happens to the needle when i press the middle switch.
Old 29th August 2008, 19:48   #147
Its not that bright ...doesn't cause much distraction...but only when the shift light comes up only when it glows too much.
Old 30th August 2008, 14:23   #148
amit_mechengg's Avatar
Thanked: 2,263 Times
the shopkeeper had told me that the middle push button is to change the color of the display.
@sumeeth , i think so that function is not working in your case. i doubt that the tacho is faulty. please ask the dealer once.
amit_mechengg is offline
Old 30th August 2008, 19:29   #149
nc1bad's Avatar
Thanked: 17 Times
tach for safari
hey incase you are buying for the safari kindly note:
The tach in safari gets its feed from the alternator, not ecu. Many tachs are for petrol engines and wont work on diesel vehicles. So before buying make sure its for diesel engines.
nc1bad is offline
Old 30th August 2008, 19:57   #150
rider60's Avatar
Thanked: 56 Times
Originally Posted by rider60 View Post
okay now i have a query here and i NEED HELP!
take a look at think linky
the autoguage says they have tachos for diesel and their dealer ship is in India too but they have not put up the address of the dealer now i am help less can some one give me pointers to the same?
Product Detail
Products
Company
guys need the pointer badly for my SWIFT LDI! please!
now thats exactly what i have been searching for the past few days rather months i pmed psycho, autopsyche, and viper no reply from them at all its been more than 2 days since i did this and my luck is really not favoring me so just cant seem to find a tachometer for the diesel.
i found the diesel tacho only from auto guage no other brand if any other brands makes a tacho for diesel please do let me know.
even a need a tacho for a 4 cylinder car, same as you safari ibm, so if by any chance you find one please let me know and i will do the same if find one first.
EDIT: try the links in the first quote, they will lead you to the diesel tachos from autoguage.
rider60 is offline
