Old 1st August 2009, 00:28   #76
Raccoon's Avatar
Thanked: 116 Times
Originally Posted by tsk13 View Post
No idea if its genuine, but its definitely overpriced. its above the MRP... whereas I just got a tin below the MRP (from a shop in Poona).
Raccoon is offline
Old 3rd August 2009, 14:57   #77
pratim's Avatar
Thanked: 58 Times
cost of waxoyl underbody coating?
Originally Posted by Sunilrj View Post
Pratim, Congrats on the ANHC. the 4K is for the body paint protection. the underbody coating is of hardwax. not a must have but a good to have..as it provides an additional layer of protection. the same hardwax protects against speed breakers, NVH etc.
What would be the cost for a waxoyl hard wax underbody coats? I have been asked Rs. 4000/- or so.!!
pratim is offline
Old 3rd August 2009, 16:32   #78
Sunilrj's Avatar
Thanked: 590 Times
its about 3800- 4500 depending on the vehicle
Sunilrj is offline
Old 3rd August 2009, 19:31   #79
Thanked: 268 Times
Never heard of underbody Waxoyl ? Are you sure about it ? Might be normal under-body coating ?
mithun is offline
Old 3rd August 2009, 19:46   #80
gpa
gpa's Avatar
Thanked: 345 Times
+1 to that. Be sure you check the brand before you get it applied. Else, it will turn out to be a sheer waste of your money.
gpa is offline
Old 3rd August 2009, 19:49   #81
The Art of grooming is not the products alone ,
It is a winning combination of Superior products, Trained professionals &
the application method.
Abrasives, protectants, sealants & gloss can all be effectively used to give that superb showroom finish or harm your paints.
A good job will come from a professional who will explain you in detail what will work for your car. Frequent use of any material can dmage your exterior
Ron&Walters is offline
Old 3rd August 2009, 21:31   #82
Sunilrj's Avatar
Thanked: 590 Times
please visit : WAXOYL Homepage > Products > Hardwax . i dont suggest products if i dont try them out myself and unless am satisfied with the quality / durability!
Sunilrj is offline
Old 3rd August 2009, 21:32   #83
Sunilrj's Avatar
Thanked: 590 Times
well said Ron& walters. your username sounds like some MNC
Sunilrj is offline
Old 4th August 2009, 00:09   #84
frankmehta's Avatar
Thanked: 3,667 Times
i have a free teflon coating on my fiesta (which I shall book in the next 2-3 days)
should I do it? Or just throw the coupon away?
frankmehta is offline
Old 4th August 2009, 01:25   #85
Raccoon's Avatar
Thanked: 116 Times
Unless you know for sure what they are using, and that they are using the right procedure, and you get it done under your nose, I'd think its safer to throw away the coupon without a second thought.
Raccoon is offline
Old 4th August 2009, 14:06   #86
Originally Posted by greenhorn View Post
Have read that paint sealants do a better job than waxes on solid whites. Where can I get hold of these 'paint sealants'
Autoglyms Super resin polish
Fantastic on solids .
Old 4th August 2009, 14:13   #87
Hi FM,
you will need to check if its genuine Dupont Teflon, else you can also decide on going for after market paint protection.
Old 4th August 2009, 23:47   #88
I got the Dupont Teflon coating done on my white punto from reliance
auto zone Ambience mall gurgaon
paid around 2500.
At first the guy applied some amway rubbing compound and then he applied the teflon coating( red in color)
The bottle had the name Dupont written on it.
Any idea how long will this coating last before I can go in for Waxoyl coating. Where in Delhi/Gurgaon Can I get the waxoyl coating done?
Dheeraj
dhir_d is offline
Old 5th August 2009, 00:28   #89
Parm's Avatar
Thanked: 899 Times
In India a vehicle like Gypsy, Gurkha, Jonga, Marshal, Judo, Major etc are all called JEEP!
Bajaj, LML, Honda Activa, etc are all called Scooters!
different motorcycles are called Bikes!
similarly people have started selling Teflon Coatings to car owners who cant tell between a polish and glaze, Wax and polish, Sealant and a Coating!
whenever you are offered a Teflon Coating, make sure to ask for the brand name of the coating, is it a permanent coating, is it DUPONT Coating?
Parm is offline
Old 12th August 2009, 01:17   #90
Thanked: 385 Times
My car is showing off its swirl marks after my driver ruined the paint and the swirls are even more worse at night under the street lights. So, i plan to get professional help.
Should i go for 3m swirl removal? Or anything else?
3M India: Minor Scratch/Swirl Removal
akshay_b is offline
