Old 13th January 2011, 12:39   #316
SumitBahl's Avatar
Thanked: 232 Times
Re: My Modded Swift : "Sports Mind"
Originally Posted by Sportsmind View Post
Yes it is a small unit the size (1"x2"). It can be placed inside the third brake module using a double sided tape.
Where can I buy the flasher and for how much?
Eagerly waiting for the turbo install to complete.
SumitBahl is offline
Old 13th January 2011, 12:52   #317
Sportsmind's Avatar
Thanked: 32 Times
Find the ordering link for the flasher:
International Order Form
You can check which kind of module you require. There are three options. You can pay via paypal.
Cheers...
Sportsmind is offline
Old 13th January 2011, 22:55   #318
SumitBahl's Avatar
Thanked: 232 Times
Cheers...
I will check the available options.
Old 14th January 2011, 00:35   #319
Re: Tacho upgraded.
Upgraded my Auto gauge tachometer to the latest Digital Pro shift tube system. It is a stunning product and different from the common tacho's. Product details: Auto Meter: DPSS
Shall update with pictures on the drive soon....
Dude how much did this Tacho cost ?
Did you order from US.
My friend is coming back next week, wanted to check ur feedback before i ask him to get one.
prasanna_gem is offline
Old 14th January 2011, 10:47   #320
Sportsmind's Avatar
Thanked: 32 Times
Re: Tacho upgraded.
It retails on ebay motors: Level 1-112USD, Level 2-131USD,Level 3-179USD. I had got the level 2 for 100USD from a person who was selling it on ebay, as he had sold his car. It is great stuff to have on your dash and has plenty of options. I still havent got the time to do the complete settings. At present it is set on regular tacho mode with a single shift point set for all gear levels. I have to still get the RPM shift points for different gear shifts.
Old 15th January 2011, 11:20   #321
Sportsmind's Avatar
Thanked: 32 Times
Digital tachometer video
Find the vdo for the autometer level 2 digital tacho on my drive:
http://www.youtube.com/user/vivekv20.../0/dXKf5LiUPqM
Old 17th January 2011, 10:27   #322
Sportsmind's Avatar
Thanked: 32 Times
Image of full LED third brake lamp. With the flasher it gives a F1 look.
My Modded Swift : "Sports Mind"-dscn0229.jpg
Last edited by .anshuman : 17th January 2011 at 19:12. Reason: Back to back posts within 20mins. Please use edit button if posting again within 20 mins. Thanks
Old 17th January 2011, 12:48   #323
Sportsmind's Avatar
Thanked: 32 Times
"Sports Mind"- video 1
With so many demands for a video on my drive. I got this one which covers most of the features my fellow bhpians have been asking me for a long time.
Old 17th January 2011, 15:01   #324
knp
Thanked: 44 Times
wow!! Amazing work that you have put in your car, especially, it was a like a light show to me
knp is offline
Old 17th January 2011, 15:38   #325
prince85's Avatar
Thanked: 123 Times
absolutely amazing bro! The kahtec module looks too good with the led third brake light, is the kahtec you using the one with delay?
And whats the graphic equalizer kinda lights flashing on the rear glass? looks interesting and really hot....could you put up some details of the same?
Once again, heartiest congratulations to you mate.
Your swift really really stands out
prince85 is offline
Old 17th January 2011, 16:30   #326
Sportsmind's Avatar
Thanked: 32 Times
The Kahtec module I have now on my drive is the standard version without the delay.
The sound activated EL sticker is from Taiwan. Refer their online shop: T-qualizer flashing t-shirt,el light cap/hat,el cold light sources products,el flashing car sticker,solar products,sound control t shirt
cheers...
Old 17th January 2011, 19:03   #327
prince85's Avatar
Thanked: 123 Times
cheers...
thanks a load for the link bro.
btw, i noticed that your center mounted brake lamp flashes for a while and then goes solid. Isnt the kahtec standard version meant to keep flashing?
Also how did you do the center lamp LED transplant? It jus looks incredible.
prince85 is offline
Old 17th January 2011, 21:25   #328
Sportsmind's Avatar
Thanked: 32 Times
The standard version flashes six times and then goes solid. It does not keep flashing continously. Every time you apply the brake it flashes.
Not to clear which center lamp you mentioned.
Old 17th January 2011, 22:28   #329
prince85's Avatar
Thanked: 123 Times
Ok. Thanks for the info bro. I was always under the impression that the kahtec standard version would keep the third high mounted stop lamp continuously flashing. But now thanks to you, i know better.
And regarding the LED treatment query, it was with regards to the same High mounted stop lamp in your ride which you have now converted into LED. I was wanting to do a similar LED transplant to my SX4 third brake light. Any leads would be awesome help.
cheers
prince85 is offline
Old 18th January 2011, 10:26   #330
naveen.raju's Avatar
Thanked: 9,484 Times
Excellent mods. Wat's in store next?
naveen.raju is offline
