Old 9th March 2009, 16:38   #1
Sideways's Avatar
Thanked: 32 Times
Review: Pete's box for the 2.6 CRDE Scorpio
Introdcution
The 2.6 Scorpio CRDE is a pleasure to drive. The turbo kicks in at an early 1300 to 1400 rpm, virtually eliminating any kind of lag which is normally associated with most turbo charged vehicles. Although the engine is dated (Pushrod technology), the folks at Mahindra have done a good job with respect to refinement and relaiability. The engine revs smoothly without any hesitation. On the contrary it seems to be in a hurry to get to max revs. The torque available is more than adequate (so I thought), be it on the highway or on the hills.
Yeh Dil Maangey More
However being perfomance enthusiasts theres always that little more that we crave for. Adding a boost controller to increase the boost did cross my mind several times, but I was not sure if the ecu would cope and compensate for the additonal amount of air. I use the Scorpio on a daily basis and I cannot compromise on reliability. I decided to wait until a reliable solution was available.
A ray of Hope
When Pete's Perfomance introduced Digitial Tuning Boxes for diesel vehicles in India, I called Peter to ask if they had anything for the Scorpio. Unfortunately they did not, but Peter promised to keep me updated on any further developments. As promised Peter called and informed me that a team from PSI Technologies, the inventors of the magic BLUE BOX (I wonder what it is with the colour blue, first Viagra, now tuning box !!!), were in India to carry out tests on the Scorpio. A few days later, I was informed that Pete's Performance had officially launched a tuning box for the Scorpio. I decided to wait it out for a little more time before taking the plunge. As I have mentioned before, reliability was of prime importance. However, just like all the other Products Pete's Performance markets, they seemed to have done their homework well. People who had installed the tuning box in their Scorpio's only had good things to say. It was time to make the phone call.
The Magic Blue Box arrives
I was IMPRESSED.
A lot of care has taken overall.
Packaging is of excellent quality. The instruction booklet has clear and precise instructions on installation procedures and the Do's and Dont's. The photgraphic illustration on installation procedure is an added bonus and eliminates any possibility of installing the box in a way it's not meant to be.
The box itself is made of high quality plastic and is supplied with a wiring loom specific to the vehicle in which the box is to be installed. A nice high quality Pete's decal is also included in the box.
Installation
Installation takes about 10 minutes, most of which is spent removing and refitting the engine cover. There are 3 connectors on the wiring loom. The main connecotr goes into the tuning box. The connector on the fuel rail is diconnected and attached to the second connector on the loom and the third connector is attached to the fuel rail in place of the original connector. I used a couple of Tie ups to secure the tuning box to the metal braket which holds the fuse carrier in the engine bay. The heat in the engine bay will not affect the working of the tuning box. However care must be taken to isolate the box from water while washing the engine bay.
Testing Method
I did not use any fancy gizzmos and gadgetery to determine perfomance. A simple stopwatch was used. There is always more margin for error if testing is done with standing starts. The way the clutch is released, and the amount the accelerator is depressed will always vary from run to run. Therefore I decided on testing with a rolling start instead. The method was fairly simple. The vehicle would be slotted into first gear with the speed held at 20 kmph. The stop watch would be started. Gears would be shifted up at the 3000 rpm mark from 1st to 4th. The watch would be stopped when the vehicle reached 100 kmph on 4th gear.
I chose to shift up at 3000 rpm, because this is the most useable rpm in city driving conditions. I have not tested the vehicle on the highway as yet.
An isolated road with a good surface devoid of any other vehicles, human beings and animals (hard to come by, but we found one, never the less) was identified for the test runs.
Note: - Throttle postion for every gear at 100% i.e. pedal to the metal.
Performance
Without the Box - 3 runs - 16.4, 16.3, 16.5 - Average - 16.4 seconds
With the Box - 3 runs - 13.4, 13.2, 13.3 Seconds - Average - 13.3 seconds
Thats more than 3 seconds knocked off - I was freaking out - Unbeleiveable but true.
Conclusion - Go baby Go
The box is worth every cent. Like I mentioned earlier, the jeep is fast as it is, but trust me, the Pete's box gives it that extra punch, and the additonal power and torque is fantastic. You will find yourself down shifting much less often, as the new power is on tap and instantaneous. Even while crusing, when you squeeze the accelerator either to overtake or increase your speed, theres absolutely no hesitation or laziness - Simply awesome.
Theres no overheating or any other negetive effect. If decently driven the jeep will return the same milage if not more (on account of lesser down shifting). I would however recomend using a better engine oil. The oil which the Mahindra service centres use is worse than human faeces (to avoid being infracted I have used language as per board rules, but I hope everyone gets the message)
I am not sure if installation of the box voids the warranty. I haven't bothered to check with the dealership and I don't intend to. I will remove it when the jeep goes for service and re install when it's back.
The box retails for Rs.28,000 inclusive of taxes (printed on the box). Get one today if you have the money, start saving up if you don't.
Please drive safely within the required speed as prescribed under the law.
Happy motoring.
Sideways is offline
Old 9th March 2009, 16:45   #2
theMAG's Avatar
Thanked: 1,820 Times
Thats a very scientific review Farhan. Would this new box also work on other non-Euro common-rails in the Indian market?
theMAG is offline
Old 9th March 2009, 16:45   #3
Ardy's Avatar
Thanked: 87 Times
Good Review ...
Please update the FE figures as well. Did you think about replacing air filters as well?
PS: I have the tuning box on my Octavia which I fitted recently ... The overall FE has really not changed, but the FE on 1st & 2nd gear driving has changed. I have also replaced my air filters with Green Cotton.
Ardy is offline
Old 9th March 2009, 16:45   #4
jkdas's Avatar
Thanked: 1,495 Times
Impressive numbers. Thought Mansidea would pick one up sometime back.
And, dont you think better air filter will help? Or one can skip it?
jkdas is offline
Old 9th March 2009, 16:52   #5
Sideways's Avatar
Thanked: 32 Times
Thanx guys.
@ Maggie - Nope, not as far as I know, but Pete can clarify that better than I can.
@ Ardy - I haven't tested for fuel efficiency. I was travelling and returned only on the weekend. Will test and update. The filter has not been changed. The stock filter is a foam one and I am sticking with it for the moment. Warranty becomes void in the Scorpio if the air filter element is changed - Go figure.
@ J.k. - I am sure it will, but read as above.
Sideways is offline
Old 9th March 2009, 16:54   #6
rjstyles69's Avatar
Thanked: 845 Times
Farhan that's something really nice to read straight from the horse's mouth, a very 1st on team-bhp. Great review there !!
rjstyles69 is offline
Old 9th March 2009, 16:55   #7
kpzen's Avatar
Thanked: 1,881 Times
Sir,
Congratulations for getting the box! I feel its completely worth it after experiencing it in my Getz for 8000kms.
What filter are u using ?
kpzen is offline
Old 9th March 2009, 16:58   #8
suman's Avatar
Thanked: 281 Times
Farhan, nice & objective review (as expected ), thanks! Those are impressive numbers. So the 2.6 becomes a real stonker now & outflies the Hawk
suman is offline
Old 9th March 2009, 17:58   #9
Sideways's Avatar
Thanked: 32 Times
Thanx Suman, it's very different now, in a very nice way. Faster than the MHawk ?, I don't know, but would like to find out.
Sideways is offline
Old 9th March 2009, 18:03   #10
pulsar56's Avatar
Thanked: 343 Times
Nice description there.
Now, I am wondering, what will be the outcome of a pete's box on a mHawk?
pulsar56 is offline
Old 9th March 2009, 18:25   #11
ramkya1's Avatar
Thanked: 434 Times
Sideways,
Great review, objective and exciting. Will wait for more inputs from your experience before I'd take a plunge.
Thanks for sharing,
(Just talked to Ms.Bina @ Pete's, cochin; they are arranging for someone to brief me tomorrow morning @ Ahmedabad on the box; told me its a truly plug & play thing )
--Ramky
ramkya1 is offline
Old 9th March 2009, 18:27   #12
Thanked: 571 Times
Nice review and at 13~ second, man, what a sting!
I would be just a tad concerned about the braking.
Originally Posted by pulsar56 View Post
...Now, I am wondering, what will be the outcome of a pete's box on a mHawk?
Same thought here!
HappyWheels is offline
Old 9th March 2009, 18:42   #13
Technocrat's Avatar
Thanked: 2,704 Times
Congrats Farhan
Btw from what I have heard the actual effect take some time to show up, did you get these figures immediately after installing the box?
Technocrat is offline
Old 9th March 2009, 18:48   #14
Sideways's Avatar
Thanked: 32 Times
Originally Posted by ramkya1 View Post
Sideways,
Thanks for sharing,
--Ramky
Wow, that was quick, trust me Ramky, i have said all I need to say. I am very happy with the product.
This is something I need to seriously work on now. After the installing the box, the brakes feel even more inadequate.
Originally Posted by Technocrat View Post
Congrats Farhan
No not really. The test was done back to back, with and without the box. I should do another test now to see if the performance has gotten any better. Probably over the weekend sometime.
Cheers.
Sideways is offline
Old 9th March 2009, 19:02   #15
Jaggu's Avatar
Thanked: 17,161 Times
A very good review Sideways!
How much has your vehicle run till date (odo reading in total)? Is there different tune/map for Scorp, if so which one are you running?
Last but not the least some info regarding the better oil would be helpful, what is the rating and spec?
Jaggu is offline
