Old 2nd April 2019, 20:19   #2266
condor's Avatar
Thanked: 16,861 Times
Re: Front windscreen sunfilm?
Originally Posted by sanchari View Post
I have a Jazz too and looking for films to block out the Hyderabad sun. How much will CR70 cost for all windows? Did you get only the windscreen done for your Jazz?
Jazz having a large front screen, the cost will be on the higher side - even for just the front. If you want CR70 for all windows, I guess you are looking at at least 15k.
Note - I am not aware of exact prices of 3M sun film
condor is online now   (1) Thanks
Old 3rd April 2019, 05:21   #2267
ashishk29's Avatar
Thanked: 1,474 Times
I got the front windscreen only done.
For all glasses, that would go up to above 20k.
One budget friendly option would be cr70 on front glass, and re70 on all others.
But if you ask for my opinion, you don't need it on all glasses. On other glasses you can use magnetic shades, and the temperature becomes much more manageable very easily. That's the route i opted personally.
I use magnetic shades on the rear glasses.
ashishk29 is offline   (1) Thanks
Old 3rd April 2019, 06:21   #2268
Thanked: 549 Times
Thanks! Any suggestion for good quality magnetic shades for Jazz?
sanchari is online now
Old 3rd April 2019, 10:20   #2269
ashishk29's Avatar
I got them off of Amazon.
Autopearl Premium Quality Zipper Magnetic Sun Shades Car Curtain For - Honda New Jazz - Set Of 4 Pcs https://www.amazon.in/dp/B019C2ZAUG/..._NTdPCbHN0ZGBD
The magnets are decently strong, and the zipper opens up sufficient enough to allow using windows at parking lots and toll booths. Please note it didn't open up 100%, only able 50% diagonally.
Old 3rd April 2019, 11:01   #2270
Thanked: 549 Times
Does anyone have good recommendations for Garware sun film installers in Hyderabad? Also does anyone have experience with the 3M center near Nanakramguda circle (near ring road)?
Old 3rd April 2019, 14:37   #2271
Thad E Ginathom's Avatar
Thanked: 29,962 Times
I won't use magnetic shades due to reduced visibility.
Old 9th April 2019, 20:07   #2272
Dhruv29's Avatar
Thanked: 1,273 Times
I got my Gen-1 i20 windscreen and side windows tinted with 3m CR70 from 3m outlet. It costed my approx 18,000 for the same. I have to say it did make a lot of difference during daytime driving. On the negative side, it does leave a greenish tint when viewed under sunlight.
Dhruv29 is offline   (1) Thanks
Old 12th April 2019, 10:54   #2273
Mr. Nobody's Avatar
Thanked: 636 Times
I am thinking to go for Garware ice cool grey as it has 79% visibility so will be barely visible than the 70% that most other companies have. Is it worth going for it to help improve ac performance in my Grand i10? I will install it on all windows except front windscreen. Will not installing on front windscreen make it useless?
Mr. Nobody is offline
Old 14th April 2019, 10:04   #2274
SoumenD's Avatar
Thanked: 6,810 Times
Got CR70 fit on my front windscreen over the weekend. Cost me about 10k (They said that Honda Jazz takes an XL sized film)...
Did you get a chance to check the visibility at night? Does it cancel oncoming traffic lights (specially the ones using high beam instead of dipper).
SoumenD is offline
Old 14th April 2019, 10:07   #2275
condor's Avatar
The Front & rear windshields do let in a lot of heat. It does help to get film on these two. And having it on front windshield also helps reducing glare in bright conditions (afternoon esp).
Old 14th April 2019, 11:33   #2276
Thanked: 601 Times
Can you share some daylight pictures? And what's the police attention like in Gurgaon and Delhi?
rayjaycleoful is online now
Old 14th April 2019, 21:59   #2277
Dhruv29's Avatar
Cops are not lookin into sunfilms as of now but they’ll definitely ramp up checks as heat increases. After 9 years, bit the bullet and got it installed because i20 1.2 seriously lacks A/C cooling due to small capacity compressor. I had no option but to get the film installed.
You can compare it to Baleno which have UV blocking side glass. I’ll post some pictures soon.
Old 14th April 2019, 22:01   #2278
Thanked: 212 Times
Have CR70 on mine. It doesn't cancel the high beam, but makes it a little easier on the eyes. The nasty ones will still cause momentary blindness.
Vysakh is offline   (1) Thanks
Old 15th April 2019, 11:06   #2279
Dhruv29's Avatar
CR-70 does leave a greenish tint on the window which will be more pronounced on cars with light shade paint.
Dhruv29 is offline   (8) Thanks
Old 15th April 2019, 21:21   #2280
Thanked: 601 Times
Attachment 1868320
Attachment 1868321
Looks great! And even darker with the nets
Black cars do need sunfilms
rayjaycleoful is online now   (1) Thanks
