Old 14th April 2005, 15:11   #1
shazikon's Avatar
Thanked: 26 Times
Iridium spark plugs
Guys,
Where in Bangalore can i get Iridium spark plugs and better wires for the plugs? Rats have stripped a couple of cables leading to the spark plugs in my car. How much would a NGK/DENSO plug cost if available??Does it come with any warranty? appreciate any help on this.
thanks,
-shaz
shazikon is offline
Old 14th April 2005, 15:19   #2
speedsatya's Avatar
Thanked: 741 Times
ngk iridium plugs are available in mumbai for 500rs /piece/
ngk platinum plugs can be got for 125rs/piece,though not sure on this.
speedsatya is offline
Old 14th April 2005, 17:05   #3
Rudra Sen's Avatar
Thanked: 6,863 Times
shazikon,
Check with Hot Tracks (Anil) at Residency Road
Rudra Sen is offline
Old 14th April 2005, 17:19   #4
lamborghini's Avatar
Thanked: 5,934 Times
Guys,
i know its a bit foolish question to ask but how are iridium plugs different from the normal ones and how do they benefit the car.
lamborghini is offline
Old 14th April 2005, 17:20   #5
xstream_nos's Avatar
one more question...are iridium plugs available for bikes as well... for CBZ..., Karizma...???
xstream_nos is offline
Old 14th April 2005, 17:45   #6
hey i am a performance parts stockist here in mumbai...i'm sure since i can source them out in mumbai there must be a lot of ditributors there in bangalore for performance plugs...well NGK and SPLITFIRE are really good...you can also go in for MSD Ignition if your budget lets you do that..and also use high density igntion wires from Splitifre or MSD Ignition..i Stock splitfire plugs for 3,200 for a set of 4..and ignition wires from Splitfire for 6,000 with the rubber head bolts and the copper plates and entire mounting...so do pm me if you need any help or info...cheers...!!
dragger is offline
Old 14th April 2005, 19:06   #7
iceman91's Avatar
Thanked: 36 Times
dont think you need iridium plugs unleess you have high performance engines. a good set of platinums are more than sufficient.
but if you still insist on it. anil has a set with him. or else dom can get a set for you.
iceman91 is offline
Old 14th April 2005, 20:00   #8
Vulken Auto's Avatar
Thanked: 385 Times
Originally Posted by iceman91
dont think you need iridium plugs unleess you have high performance engines. .
high performance engines??
signature change??
Vulken Auto is offline
Old 14th April 2005, 20:31   #9
viper's Avatar
Thanked: 20 Times
hey dragger, where in mumbai are you and how do i contact you
viper is offline
Old 14th April 2005, 23:04   #10
Hey guys,
can anyone tell me the benefits of iridium spark plugs?
Old 15th April 2005, 00:43   #11
khanak's Avatar
Thanked: 370 Times
Originally Posted by lamborghini
Hey guys,
I looked it up and this is what I found
Iridium is a precious metal that is 6 times harder and 8 times stronger than platinum, it has a 1,200=F higher melting point than platinum and conducts electricity better. This makes it possible to create the finest wire center electrode ever. Prior till now, spark plug manufacturers have favored platinum for their long life or performance spark plugs due to its high melting point, also the technology did not exist to machine and bond iridium on a spark plug electrode(at least in a cost effective manner). Champion spark plugs had already made an iridium industrial application spark plug, but it still sells for over a hundred dollars per plug. Just now is the technology available to effectively use iridium in a spark plug for automotive applications. The strength, hardness and high melting point of iridium make it very well suited for a fine wire plug. The primary iridium plug manufacturers at this time are Denso with a 0.4mm center electrode and NGK with a 0.7mm center electrode. Both are the best performance plugs on the market for traditional automotive use and many racing applications.
SIDENOTE: Thus far the tech's we have spoken with report no problems using iridium plugs with Nitrous.
Source :
Sparkplugs.com
khanak is offline
Old 15th April 2005, 01:12   #12
hey buddy viper i'm located at colaba...i'll pm you my number then you can call...as and when you want..cheers....!!
dragger is offline
Old 25th May 2005, 17:35   #13
Prithvi's Avatar
Thanked: 26 Times
Hi!
I have a Accent GLS 1.3 SOHC and want to improve the performance of it. I was thinking I will do the following:-
1. Use Iridium sparkplugs from OWS.
2. Already have a K&N stock replacement filter.
3. Use a 32-bit ECU instead of the 16-bit one.
4. Use Magnocore KW8.5 spark plug wires.
5. Use a 4-2-1 Header.
6. Use a performance muffler.
7. Use front & rear struct bars etc.
Pls correct me where wrong. Can you pls help me in upgrading the performance of my accent. I am in Bangalore.
My brakes are lousy:
Need to use DBS GOLD rotors with original brake pads. Nearly killed myself doing 170 once.
Prithvi is offline
Old 25th May 2005, 18:23   #14
viper's Avatar
Thanked: 20 Times
Hey Buddy,
Good plans. I dont think you will find any marked improvement in performance by fitting the plugs and wires. A conical K&N with a nice intake will work better than the OE replacement. Exhaust + Muffler will give you 8-10% power and strut braces will definitely improve your handling especially high speed cornering.
Cannot comment on the ECU but you would be better of with a stand alone fuel management or get a piggy back computer and have your existing ecm remapped. Try Dominic in Banglore for the same.
Viper
viper is offline
Old 25th May 2005, 18:27   #15
Prithvi's Avatar
Thanked: 26 Times
Hi! Viper,
Thanks for the fast responce. Can I have Dom's number if possible.
Rgds
Prithvi
Prithvi is offline   (1) Thanks
