Old 21st March 2014, 10:22   #481
Thanked: 23 Times
Re: How does your car smell
Originally Posted by torque!! View Post
I recently came across a Gel air fresher from Odonil - yes the same brand that makes 'air freshers' for bathrooms. The Gel variety is very similar to the more expensive Gel car freshers available in the market. I tried the Citrus fragrance and loved it.
Assuming that you are using this for sometime now, will the smell fizzle out after using for some days or does it stay as it was on day 1?
DriveToLive is offline
Old 25th May 2014, 20:21   #482
Thanked: 31 Times
how is areon ken new car fragrance, is it worth a try?
or any other alternative to it i like fresh fragrance in car any inputs ?
sonil.luthra is offline
Old 4th June 2014, 15:36   #483
mp417's Avatar
Thanked: 800 Times
Update:
Got the air freshener today. It looks authentic from the packaging and the gel content inside the tin can. The Squash gel odour smells pretty good, more like fresh lime but a fruity variant of it.
One of those rare things that is Made in Japan, is affordable, readily available and not something that is related to electronics!
Hi Gannu_1,
Could you please post some more details? How many days it lasted? Where have you fixed it in car? Is there any adjustment to reduce/increase the fragrance?
I am planning to buy My Shaldan from eBay as want to try out something different than Ambi-pur.
mp417 is offline
Old 4th June 2014, 16:02   #484
Gannu_1's Avatar
Thanked: 20,668 Times
Originally Posted by mp417 View Post
Hi Gannu_1,
Easily lasted me for close to 5 months and there was still some content left in the can when I disposed it off. The car had a nice citrus fragrance but I got bored of it eventually. There is a spring mechanism inside the can that pushes the contents upward as it gets consumed.
I had kept it in the round cubby hole ahead of the gear lever. To stop the can from rattling, I used some Scotch Brite pad:
How does your car smell-scotchbriteheavydutyscourerpads_4ce3d71e7c154.jpg How does your car smell-105-md_e.jpg
Cut it to the shape of the can's bottom and kept it in the cubby hole.
Opted for another freshener this time - Dr. Marcus - Senso Deluxe and I concur with whatever he has to say:
Originally Posted by ashm99 View Post
Bought Dr Marcus Senso Deluxe Ocean Gel Car Perfume from HyperCity..Smells awesome !!! Just like Davidoff Cool Water !!
I have a bottle of Cool Water and can confirm that the fragrance is similar.
Gannu_1 is offline
Old 5th June 2014, 10:45   #485
PapaBravo's Avatar
Thanked: 3,525 Times
I use the Glade gel freshener is the car. It gives a very fresh smell every time I enter the car. It is also relieves me of the worry of liquid freshner spoiling my interiors. It is also Value for money at ~ Rs. 50 approx.
PapaBravo is offline
Old 5th June 2014, 10:50   #486
mayankk's Avatar
Thanked: 8,613 Times
I picked up these godrej musk soaked cardboard ones from an HP pump, 10 bucks a pop.
They were doing a pretty good job, till I left my car in the sun for about 10 hours.
I sneezed all the way back home.
Have you ever broken a bottle of perfume in your room, how it smells to high heaven for months?
Just like that, only instead of the bottle, it seemed like a barrel , and instead of the room, it seemed like my sinuses!
mayankk is online now   (1) Thanks
Old 5th June 2014, 17:28   #487
Thanked: 200 Times
Just a small tip..
I keep few pieces of camphor , you get two types, one flat slab type & tablet type small ones. Flat ones are good for keeping inside the car.
Just make 3 small pieces & put it under front seat, middle row & boot space in the night while parking & when all the windows are closed. You would get fresh fragrance in the morning & you would have this fragrance through out the week.
Most people like it as it has natural fragrance (my experience...)
Ananth
Ananth_shukti is offline
Old 5th June 2014, 17:41   #488
dass's Avatar
Thanked: 941 Times
Attachment 1247192
Is this available online? Can you post a link if possible?
dass is online now   (1) Thanks
Old 6th June 2014, 10:20   #489
PapaBravo's Avatar
Hi dass,
I do not buy it online. I tried to Google it but couldn't find any online store selling these. These are readily available at Spencer's modern format stores.
Old 6th June 2014, 10:49   #490
sivadas's Avatar
Thanked: 238 Times
After using 'My Shaldan' for many years, recently shifted to 'Charcoal' as suggested by Shibin of Petes. Though a bit expensive, I found it quite good. It has active charcoal based gel which seems to be working well to deodorize the car. Gives a pleasant feel while entering the car.
sivadas is offline
Old 6th June 2014, 13:22   #491
archat68's Avatar
Thanked: 642 Times
Originally Posted by sivadas View Post
T It has active charcoal based gel which seems to be working well to deodorize the car.
Active charcoal being a chemical doesn't know how to distinguish between bad smell and good smell. So, *if* it deodorizes your car it will also remove any smell produced by the perfume .
archat68 is online now   (1) Thanks
Old 6th June 2014, 15:06   #492
sivadas's Avatar
Thanked: 238 Times
This one is from Valvoline. What ever, it leaves some nice fragrance. Here is the description.
The new range of luxury air fresheners from Valvoline bring smooth scents in fantastic design.
The premium fragrances are being sourced from France and Japan.
Try it out once to really indulge in the luxury of perfume while driving.
Activated charcoal provides powerful deodorizing in any environment. The embedded fragrance provides the masking effect.
Makes your home or car refreshing with a unique smell.
sivadas is offline
Old 11th June 2014, 14:53   #493
Thanked: 74 Times
AERON IS SELLING EXPIRED PRODUCTS !
Bough AERON a few days back and I noticed it was smelling somewhat stale ! The MRP label did not mention any date of Expiry. Out of curiosity, I peeled the MRP label and was SHOCKED to see that the product had EXPIRED long back !!
The Importer (Amritras India, Delhi) has very cleverly put the MRP label over the Expiry Date so that he could probably hide it and sell off his dead-stock !
So all the Aeron users, beware and think twice before you are buying the products ! I will never buy Aeron in my life again, as I do not want to inhale expired products and get sick nor want to encourage such unprofessional importers with malicious intent who deliberately cheat their customers !
ashm99 is offline   (1) Thanks
Old 13th June 2014, 09:23   #494
KarthikK's Avatar
Thanked: 12,773 Times
While I agree with you on staying away from expired products, to be honest I don't think it is fair to generalize about the manufacturer Areon directly. This could very well be a one-off case where this particular importer was hoarding (and getting rid of) expired products, probably due to built-up inventory. I have been using Areon since years now and have always found their products to be far superior and long lasting compared to MyShaldan and other gel-based economy car perfumes. I always purchase my perfumes through eBay sellers.
If this dealer you bought from was on eBay, I would suggest you drop a negative feedback to the dealer on eBay and ask him to send you a free replacement. Most eBay sellers are wary about getting negative feedback / reputation on the site and will go to any lengths to sort out customer dissatisfaction.
P.S - about inhaling expired perfumes - nothing really toxic / harmful about it, except that it might give a funny, foul smell if terribly past the expiry date
KarthikK is offline   (2) Thanks
Old 13th June 2014, 14:18   #495
Thilak29's Avatar
Thanked: 3,662 Times
I am experimenting with Odonil Gel after trying various cheap/expensive options.
Seems like VFM.
Thilak29 is offline
