Old 6th June 2008, 13:09   #1
vishnuvijay's Avatar
What does H1, H3, H4, H7 etc specifications of bulbs mean?
Helooo guys.
Which is better?
vishnuvijay is offline   (1) Thanks
Old 6th June 2008, 13:17   #2
Akshay1234's Avatar
Thanked: 12,914 Times
they are all different bulb sizes. there isnt any better or worse. it just depends on which size your car has. h4 has both high and low beam built into one. h7 and h1.etc have only 1 beam.
Akshay1234 is offline   (4) Thanks
Old 6th June 2008, 13:24   #3
than you akshay, that was quick.
you mean h4 has a main bulb and also a pilot bulb along with it?
Old 6th June 2008, 13:24   #4
Akshay1234's Avatar
no h4 is one bulb with 2 filaments.
Old 6th June 2008, 13:27   #5
then what is a bulb along with a pilot bulb called ?
will blue light increase illumination at night ?
Old 6th June 2008, 13:30   #6
S600BENZ's Avatar
Thanked: 12 Times
No thats not true. It has only 1 filament, but has something like a reflector built into the bulb which moves when you shift the stalk in the car and thus changes the focus from High Beam to Low Beam.
S600BENZ is offline
Old 6th June 2008, 13:32   #7
Akshay1234's Avatar
i dont think thats right. thats what happens in hi/lo HIDs. i dont think normal h4 halogens have this moving reflector thingy.
Akshay1234 is offline   (1) Thanks
Old 6th June 2008, 13:33   #8
in a headlight there are two bulbs. the main bulb and a pilot/park bulb. right? so do these come as one set or do we buy them seperately?
Old 6th June 2008, 13:33   #9
badboyscad's Avatar
Thanked: 483 Times
they are different types of bulbs:
What does H1, H3, H4, H7 etc specifications of bulbs mean?-nokyaacticwhite_chart.jpg
badboyscad is offline   (6) Thanks
Old 6th June 2008, 13:35   #10
thank you.
so that means the main bulb and the pilot/park bulb don't come as a set and that you'll have to buy them seperately ?
Old 6th June 2008, 13:36   #11
Akshay1234's Avatar
i have seen them as a set by philips. i thin they were blue vision. but you do also get the pilot bulbs separately for around rs150 or so for 2 leds.
Old 6th June 2008, 13:36   #12
Chevy_lover's Avatar
Thanked: 130 Times
H4 Xenon has two filaments. One for high beam and one for low beam.
Please see this link. http://www.morepower.com.au/images/H...%201%20(2).jpg
Chevy_lover is offline
Old 6th June 2008, 13:40   #13
can guys tell me which type of bulbs (H1, H4 etc) fits
1. OHC
2. Wagon R
Old 6th June 2008, 13:40   #14
X-Machine's Avatar
Thanked: 29 Times
Probably the following article & pic will be of some help:
Osram Philips Bosch - H1 H4 H7 - Auto Lamp Headlight Bulbs Images
X
X-Machine is offline
Old 6th June 2008, 13:45   #15
Blue Thunder's Avatar
Thanked: 398 Times
This is right.
No, S600BENZ, you are wrong there.
In the H4 bulb, as akshay1234 has mentioned, there are two filaments : one for the high-beam, and the other for the low-beam.
Blue Thunder is offline
