Old 25th September 2012, 14:21   #901
amrisharm's Avatar
Thanked: 331 Times
Re: The Zen Modifications Thread
Hi guys, I am a proud owner of a 2005 ZEN Lx. I bought it 2nd hand a year ago from a relative of mine as i knew it was a well kept car and I was in need of a 2nd car. Anyways the time has come for my car to get new tyres. I just wanted to get advice from the forum about a few questions I have which are as follows:
1) Should I upsize to R13's? Will I have to modify the suspension and shockers if I upsize to this size? As I know the earlier zens were equipped with factory fitted R13.
2) Also will fuel mileage and passenger comfort be affected if I upsize?
3) Are alloy wheels available for the Zen in both R12 and R13? I am more interested in trusty brands like Neo etc rather than cheap chinese imports.
4) The car is used on broken roads 50% of the time due to the bad condition of roads in and around the hills of darjeeling (thats where I live). So is and upsize to R13's recommended for someone like me. And Also should I go for Alloys?
My heart says Upsize to R13's with Alloys, but considering the usage of the car on bad roads, my head says stick to R12's and maybe R12 alloys. So could someone make suggestions please.
Thanx guys,
Amrish
amrisharm is offline
Old 22nd October 2012, 11:03   #902
Zen2001's Avatar
Thanked: 1,573 Times
Thanx guys,
Amrish
Sticking with R12 gives you a better chance of a comfortable ride on broken roads as you can go for the "taller" 140/80 tyres, which are not available in R13. However, availability may be an issue as most cars on the road today have R13 or above.
Zen2001 is offline   (1) Thanks
Old 22nd October 2012, 12:19   #903
fiat_tarun's Avatar
Thanked: 3,908 Times
Thanx guys,
Amrish
Yes, You do get 12" alloys, although you have very limited choice. In 13" you get much more options. I have 12" plati alloys on my Zen. I got them at 10K for 4.
fiat_tarun is online now   (1) Thanks
Old 22nd October 2012, 13:43   #904
breezydrive's Avatar
Thanked: 128 Times
As a ZEN owner for the last 1.45 lac km (10 years), my advise simple would be:
"If you want the peace of mind, stick to 145/80 tyres on 12" rims"
These tyres are best suited for ZEN's suspension, particularly on bad roads.
breezydrive is offline   (1) Thanks
Old 22nd October 2012, 18:39   #905
nick17s's Avatar
Thanked: 103 Times
Hi I am using 12" Alloys with 155/70 Michelin XM1+ tires..Car runs pretty well, as good as stock,infact handling is better than stock..No harm to shocks and steering smoothness !
nick17s is offline
Old 23rd October 2012, 14:48   #906
Thanked: 128 Times
That is a wrong downsize, Overall dia. (OD) becomes less and the car oversteers. I was using that size earlier but later on shifted to 155/65 on 13" rims.
145/80 R12 -OD 536.8 mm
155/65 R13 - OD 531.7 mm
155/70 R12 - OD 521.8 mm
Old 25th October 2012, 15:30   #907
nick17s's Avatar
Thanked: 103 Times
I dont think so, because before installing the tire, alloys I read on tbhp forums that 155/70/12 is a good upgrade and do check this link out..
http://www.1010tires.com/tiresizecal...?action=submit
nick17s is offline
Old 16th December 2012, 14:54   #908
pramodkumar's Avatar
Thanked: 2,267 Times
Infractions: 0/1 (7)
Lovely mod Done on a zen..
Their details.
https://www.facebook.com/pages/The-H...40871682638048
Disclaimer: I am not commercially linked with them, just found this interesting and thought of posting it here (video taken by me)
pramodkumar is offline
Old 16th December 2012, 18:15   #909
speedsatya's Avatar
Thanked: 740 Times
145/80r 12 give a decent ride , but not the ones That gimme confidence on the highways.
I had 155/65r13 for 1000kms only to throw them away in exchange for Bridgestone Potenza GIII 165/60R13. Rims are 5J
Driven 2.09L kms since then and I have no complaints
speedsatya is offline
Old 21st December 2012, 14:40   #910
S_U_N's Avatar
Thanked: 418 Times
I am planning to get our Zen modified. The aim is to change it completely so that it does not look like a Zen at all, but more like a Beetle.
My budget is 1.5 lac. The entire body of the car has rust and needs to be repaired.
Can someone point where I should begin?
Any recommended places in Pune?
S_U_N is offline
Old 26th December 2012, 20:53   #911
Zen2001's Avatar
I've been thinking of this for quite some time and also did a rough "trial" of the same.
I am contemplating swapping the locations of indicators and parking lights in my type 1 zen. I am also thinking of using LED DRLs instead of the old tungsten filament parking bulbs. The issues and questions I face are:
1. Wattage of the 2 types of bulbs and their holders are different - parking lamp 5W [T10] and indicators 21W [bayonett type]
2. Direct swap of the indicator bulb with its holder and wiring to the parking lamp housing is not possible due to the different holder configurations. Which means that I have to look for a T10 type 21 W rated bulb [or a 21W T10 LED substitute] which will fit directly in the parking lamp socket, and I only need to rewire it to the indicator wires. But, is this [21W T10 bulb] available or will I have to make do with the 5W by adding a series resistor?? [This will be necessary to prevent the bulb from going kaput, besides ensuring that the rate of blinking more or less remains the same!]
3. What is the wattage rating of ready-made LED DRLs available in the current scenario? If they are 5W, then I could just wire them to the parking lamp wires. Also, I am looking for a type that will fit inside the rectangular slot of the indicator lamps in the front bumper.
I know these are too many [??trivial] pre-conditions, but any help in this matter will be appreciated. Thanks
Zen2001 is offline
Old 26th December 2012, 21:38   #912
Check my previous post. What you are thinking has been done before by them. Check their facebook page. There is a number. Call him and give him my refrence, he might be able to help you.
Pramod
pramodkumar is offline   (1) Thanks
Old 23rd February 2013, 08:40   #913
Thanked: 266 Times
Exedy daikin clutch for zen
I have come to the zen party a bit late. I am probably the last bhpian to start work on one. Finally got hold of a nice zen. So.....
Please can someone let me know where I can lay my paws on an exedy clutch. Regular or stage one will do. I have looked around. None seems to have one. Put in an mgp clutch and its ok. But I would like to put in an exedy
53BHP is offline
Old 7th April 2013, 21:48   #914
zacky1st's Avatar
My Zen Carbon modified for Hill Climb Racing and Autocross.
ZAC Motorsports
zacky1st is offline   (1) Thanks
Old 7th April 2013, 21:50   #915
zacky1st's Avatar
ZAC Motorsports
zacky1st is offline   (4) Thanks
