Old 9th July 2009, 18:04   #451
prsnck's Avatar
Thanked: 81 Times
Originally Posted by MissionAbler View Post
I recently got 13 inch, 5 spoke, gun metal finish, hijoin alloys for my Zen. Here are the pictures:
Attachment 23057
Attachment 23058
By looking at the grill, could you please tell me whether it is a type 1 or type 2 grill? My exterior mod wishlist includes mat black pillars, black side panels, tail antenna, grill replacement, subtle spoiler, and fog lamps. Then I shall move to engine and interior design. By the way, I have got Sony HU with USB port and it has been reliable so far.
Hi MissionAbler,
Can you let us know what is the tyre profile used. Looks stunning with that rubber and Hijoin alloys.
rgrds
prsn
prsnck is offline
Old 9th July 2009, 21:02   #452
k_shanz's Avatar
Thanked: 75 Times
Originally Posted by Zenster View Post
Point taken Shanz and saw your baby without the flaps and on removing them soon. BTW, i read on your garage that you have stiffened suspension...Could you please enlighten me of how its done and whats involved. What are the tradeoffs and benefits if the same etc. Awaiting your resposne..
I got it done from Coimbatore. I got custom springs which exactly work like stock but a little increment in height for the springs. When it is fixed to the stock shocks the spring become much more stiffer than the OE ones. Thats it!
Am planning for a Height Adjustable one for both the front and rear.
k_shanz is offline
Old 4th August 2009, 11:06   #453
prince_pervez's Avatar
Thanked: 53 Times
My zen mechanic said, the AC gas top up would cost around 2K, with cleaning and nitrogen gas treatment/checking. Is this correct?
Last time I did it for 900 INR. Please throw some light on this. have the prices increased ?
prince_pervez is offline
Old 4th August 2009, 11:10   #454
Thanked: 25 Times
I don't know what nitrogen gas treatment / checking is, but 2k sounds a bit too much, unless he's completely cleaning up the entire AC system. Usually Gas top up cost about 700-900/ INR.
musicmanaman is offline
Old 4th August 2009, 11:21   #455
Thanked: 53 Times
Thanks @musicmanaman, now that you have cleared my doubt, I'll ask him what else other than the gas top up he is gonna do. I told him to clean the blower fan if it is choked, but thats it. Let me call him and talk to him. Will keep you guys posted.
Old 4th August 2009, 11:24   #456
Thanked: 25 Times
Usually the evaporator coil is also taken out and cleaned, this is under the dash board on the paasenger side, this is critical to cooling, if it is clouged then the cooling goes down.
Old 4th August 2009, 15:00   #457
archat68's Avatar
Thanked: 642 Times
I have a year 2000 Zen. It needs refilling of AC compressor gas. But the problem is here in Kolkata, the AC service people are saying that the AC gas (R12) is now banned and the new gas can not be used in the older compressor directly. The compressor needs some additional fittings for filling the new gas which costs 6-7 K.
The Delhi guys in TBHP are saying that the old gas is available - but one has to search hard for it. I'm unable to find it in Kolkata.
Any pointer guys?
archat68 is offline
Old 4th August 2009, 22:15   #458
Thanked: 330 Times
I recently got my ZEn ac serviced where the Gas was changed from the R12 to r134 and it was all for a total of 1500 included all the service and the new compressor oil aswell.
the whole setup may need just a brand new bottel to hold the gas thats all,
desideep is offline
Old 4th August 2009, 22:20   #459
Thanked: 53 Times
Just asked my mechanic. He said some ring had to be replaced due to which there was leakage in the AC system. Will have to see what he replaced. Also he topped up gas and did some testing with nitrogen.
Old 4th August 2009, 22:47   #460
archat68's Avatar
Thanked: 642 Times
How is the cooling after the change? My local mechanic is telling that even if the change is done - the cooling will be far less and the compressor will not last long as the pressure of the R134 is much higher than the R12.
Also, can you please check and tell me what are changed during the the service?
archat68 is offline
Old 4th August 2009, 22:54   #461
Thanked: 330 Times
Thats true the coolling is not as good as r12 but i may be going for some more mods to the AC. this summer is almost gone in the current weather the AC seems to be working fine. my uncle got the AC done for my 800 and belive it or not the Car does not feel stressed when the AC is switched on and the coolling is a lot better than the old times as for ZEN. lets see that involves a change in the Compressor and the pullies lets see that would be for next summers.
desideep is offline
Old 5th August 2009, 22:21   #462
Thanked: 53 Times
Just got the car back. Engine compression test is normal. Clutch is fine. A/C Gas topped up. They do some nitrogen gas testing to find any leakages in the system. They changed something called 'o' ring in the pipings. They cleaned the A/C outlet of all the dirt. A/C performance has increased but not by a lot, but sufficiently enough.
Got 90/100 bulbs fitted. The effect is nice. The alignment of the bulbs is also such that most of the light is on the road. I still have the Phillips Extreme power with me.
All fluids topped up. They asked me to get the stock tyres changed after 5K kms (for the first time.)
Everything feels tighter and nicer after the service.
Thanks.
Old 6th August 2009, 18:13   #463
NOS Power's Avatar
Thanked: 81 Times
Any pointer guys?
archat, same issue with me.
well my mech quoted me 3.5 - 4K for the whole job. he says only jali (duplicate) R12 gas is available that too for Rs. 1700. he also mentioned that the cooling is slightly worse with the new gas. have decided to get it done prior to next summer.
incase you come across something regarding it please let me know.
NOS Power is offline
Old 6th August 2009, 19:35   #464
archat68's Avatar
Thanked: 642 Times
Sure mate.
Actually I'm also in a dilemma about what to do? I'm thinking that I'll give a try with the R134 gas. I think it is better to change the whole AC unit to a newer one instead of spending 6-7 K on the old AC.
BTW does anybody has any idea about the cost of a AC unit (compressor+condenser+cooling coil etc) for Zen?
archat68 is offline
Old 13th August 2009, 12:50   #465
archat68's Avatar
Thanked: 642 Times
Converted the AC of my '99 Zen to suit the new R134 gas instead of the old R12 (banned and unavailable in Kolkata). Costed 7K to me. The cooling is fantastic now.
archat68 is offline
